2002-05-17 | 2002-05-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -119/+0 | |
* configure.ac: Remove lib. | |||||
2001-05-25 | 2001-05-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -4/+2 | |
* libc/base_fs.c: Deleted chmod() now that IMFS creates the root node with the desired permissions. chmod() is also not supported by the miniIMFS so this is not allowable. | |||||
2001-05-24 | 2000-05-24 Fernando Ruiz Casas <fernando.ruiz@ctv.es> | Joel Sherrill | 1 | -2/+7 | |
* libc/ttyname.c (ttyname_r): Removed duplicate call to closedir(). * libc/getpwent.c: Create a more robust /etc/passwd and /etc/group. * libc/base_fs.c: Change permissions of files and directories. Now uses octal constants. | |||||
2001-01-25 | 2001-01-25 Fernando Ruiz <fernando.ruiz@ctv.es> | Joel Sherrill | 1 | -4/+2 | |
* Alternate email is correo@fernando-ruiz.com * libc/privateenv.c: New file. * include/rtems/libio_.h, libc/Makefile.am, libc/base_fs.c, libc/unmount.c: Moved default umask, current working directory, root, and links followed count into a structure "user environment" that can then be treated as a unit. This enable giving unique copies of these to individual threads or collection of threads. | |||||
2001-01-08 | 2001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support. | |||||
2000-11-01 | 2000-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* include/Makefile.am, include/rtems/libio_.h, libc/Makefile.am, libc/assoc.c, libc/assocnamebad.c, libc/base_fs.c, libc/cfsetispeed.c, libc/cfsetospeed.c, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/closedir.c, libc/dup2.c, libc/error.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fpathconf.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/ioctl.c, libc/libio.c, libc/libio_sockets.c, libc/link.c, libc/lseek.c, libc/malloc.c, libc/mallocfreespace.c, libc/mknod.c, libc/mount.c, libc/newlibc.c, libc/no_libc.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/tcsetattr.c, libc/telldir.c, libc/ttyname.c, libc/ttyname_r.c, libc/umask.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. * include/rtems/Makefile.am, include/rtems/.cvsignore: New file. * include/rtems/assoc.h, include/rtems/error.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h: New/moved files. | |||||
2000-10-25 | 2000-10-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -3/+4 | |
* libc/ioman.c: Moved to libfs. * libc/Makefile.am: Removed ioman.c as part of moving it to libfs. * libc/base_fs.c: Removed include of imfs.h and reworded comment to avoid being IMFS specific. * libc/libio.h: Removed prototype of IMFS_ops since it should not be in this file. * libc/mount.c: Removed IMFS specific configuration information. * libc/unmount.c: Removed include of imfs.h and reworded comment to avoid being IMFS specific. | |||||
1999-11-17 | Updated copyright notice. | Joel Sherrill | 1 | -2/+1 | |
1999-11-02 | Added support for configuring base filesystem. First attempt at | Joel Sherrill | 1 | -17/+41 | |
a full mount table at initialization. This is the wrong place to mount filesystems 2-n since no device drivers are initialized yet. | |||||
1999-10-26 | Added initial cut at miniIMFS which leaves out memfile and directory | Joel Sherrill | 1 | -0/+7 | |
readdir support. The next step is to add a mount table and configure either the miniIMFS or the full IMFS at the application level. | |||||
1999-06-15 | After comments D. V. Henkel-Wallace <gumby@zembu.com>, the interface to | Joel Sherrill | 1 | -1/+1 | |
mount() was changed to avoid the use of a string as the options. | |||||
1998-12-03 | Modifications for RTEMS_UNIX. | Jennifer Averett | 1 | -0/+2 | |
1998-11-23 | Added base version of file system infrastructure. This includes a major | Joel Sherrill | 1 | -0/+81 | |
overhaul of the RTEMS system call interface. This base file system is the "In-Memory File System" aka IMFS. The design and implementation was done by the following people: + Joel Sherrill (joel@OARcorp.com) + Jennifer Averett (jennifer@OARcorp.com) + Steve "Mr Mount" Salitasc (salitasc@OARcorp.com) + Kerwin Wade (wade@OARcorp.com) PROBLEMS ======== + It is VERY likely that merging this will break the UNIX port. This can/will be fixed. + There is likely some reentrancy/mutual exclusion needed. + Eventually, there should be a "mini-IMFS" description table to eliminate links, symlinks, etc to save memory. All you need to have "classic RTEMS" functionality is technically directories and device IO. All the rest could be left out to save memory. |
