path: root/c/src/lib/libc/__gettod.c (follow)
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-10/+9
| | | | | | | | | | | | | | | | | | | | | | | | overhaul of the RTEMS system call interface. This base file system is the "In-Memory File System" aka IMFS. The design and implementation was done by the following people: + Joel Sherrill (joel@OARcorp.com) + Jennifer Averett (jennifer@OARcorp.com) + Steve "Mr Mount" Salitasc (salitasc@OARcorp.com) + Kerwin Wade (wade@OARcorp.com) PROBLEMS ======== + It is VERY likely that merging this will break the UNIX port. This can/will be fixed. + There is likely some reentrancy/mutual exclusion needed. + Eventually, there should be a "mini-IMFS" description table to eliminate links, symlinks, etc to save memory. All you need to have "classic RTEMS" functionality is technically directories and device IO. All the rest could be left out to save memory.
* Corrected so it returns the correct date. Previously was getting the numberJoel Sherrill1998-06-181-11/+28
| | | | | | of seconds since 1988 from RTEMS and not adding in the 1970-1988 correction factor. Plus removed checks for data/time set since POSIX does not permit this call to fail. GNAT 3.12 depends on this.
* Should have included <rtems.h> before checking for ifdef RTEMS_UNIX.Joel Sherrill1998-03-271-2/+2
| | | | Bug report from Olivier Hainque <hainque@inf.enst.fr> on SPARC Solaris 2.6.
* Solaris port updates from Chris JohnsJoel Sherrill1998-01-231-1/+1
* Uncommented gettimeofday_r to resolve missing symbol.Joel Sherrill1997-09-211-2/+0
* posix support initially addedJoel Sherrill1995-09-261-2/+2
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* Fully tested on all in-house targetsJoel Sherrill1995-05-241-16/+35
* Initial revisionJoel Sherrill1995-05-111-0/+84
