* | Corrected so it returns the correct date. Previously was getting the number | Joel Sherrill | 1998-06-18 | 1 | -11/+28 |
| | | | | | | of seconds since 1988 from RTEMS and not adding in the 1970-1988 correction factor. Plus removed checks for data/time set since POSIX does not permit this call to fail. GNAT 3.12 depends on this. | ||||
* | Should have included <rtems.h> before checking for ifdef RTEMS_UNIX. | Joel Sherrill | 1998-03-27 | 1 | -2/+2 |
| | | | | Bug report from Olivier Hainque <hainque@inf.enst.fr> on SPARC Solaris 2.6. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Solaris port updates from Chris Johns | Joel Sherrill | 1998-01-23 | 1 | -1/+1 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | Uncommented gettimeofday_r to resolve missing symbol. | Joel Sherrill | 1997-09-21 | 1 | -2/+0 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 1 | -2/+2 |
* | Support for variable length names added to Object Handler. This supports | Joel Sherrill | 1995-08-23 | 1 | -1/+1 |
| | | | | | | both fixed length "raw" names and strings from the API's point of view. Both inline and macro implementations were tested. | ||||
* | Fully tested on all in-house targets | Joel Sherrill | 1995-05-24 | 1 | -16/+35 |
* | Initial revision | Joel Sherrill | 1995-05-11 | 1 | -0/+84 |
