Modifications for RTEMS_UNIX.
PROBLEMS
can/will be fixed.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
With this in place, it is possible to fdopen a TCP stream socket and
getc/fprintf/etc. on the STDIO stream!
to lib/include.
(Sapporo, Japan) submitted the extended console driver for the
MVME162LX BSP and the POSIX tcsetattr() and tcgetattr() routines.
This device driver supports four serial ports, cooked IO, and
provides a portable base for Zilog 8530 based console drivers.
be resolved.
