path: root/c/src/lib/libc/Makefile.am (follow)
* 2001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-081-0/+1
| | | | | | | * configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support.
* 2000-11-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-301-1/+1
| | | | | | | * include/rtems/Makefile.am: Added termiostypes.h. * libc/Makefile.am: Removed termiostypes.h. * libc/termios.c: Changed include of "termiostypes.h" to <rtems/termiostypes.h> since that is an RTEMS specific header file.
* 2000-11-25 Antti P Miettinen <antti.p.miettinen@nokia.com>Joel Sherrill2000-11-251-1/+1
| | | | | | * libc/termios.c, libc/termiostypes.h: Task driver driver model and line discipline support from Thomas Doerfler <Thomas.Doerfler@imd-systems.de>.
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-011-25/+1
| | | | | | | | | | | | | | | | | | | | | | | * include/Makefile.am, include/rtems/libio_.h, libc/Makefile.am, libc/assoc.c, libc/assocnamebad.c, libc/base_fs.c, libc/cfsetispeed.c, libc/cfsetospeed.c, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/closedir.c, libc/dup2.c, libc/error.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fpathconf.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/ioctl.c, libc/libio.c, libc/libio_sockets.c, libc/link.c, libc/lseek.c, libc/malloc.c, libc/mallocfreespace.c, libc/mknod.c, libc/mount.c, libc/newlibc.c, libc/no_libc.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/tcsetattr.c, libc/telldir.c, libc/ttyname.c, libc/ttyname_r.c, libc/umask.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. * include/rtems/Makefile.am, include/rtems/.cvsignore: New file. * include/rtems/assoc.h, include/rtems/error.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h: New/moved files.
* 2000-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-251-1/+1
| | | | | | | | | | | | * libc/ioman.c: Moved to libfs. * libc/Makefile.am: Removed ioman.c as part of moving it to libfs. * libc/base_fs.c: Removed include of imfs.h and reworded comment to avoid being IMFS specific. * libc/libio.h: Removed prototype of IMFS_ops since it should not be in this file. * libc/mount.c: Removed IMFS specific configuration information. * libc/unmount.c: Removed include of imfs.h and reworded comment to avoid being IMFS specific.
* 2000-10-18 Chris Johns <ccj@acm.org>Joel Sherrill2000-10-181-12/+3
| | | | | | | | | | | | | | | | | * libfs created. * libc/deviceio.c, libc/imfs_getchild.c, libc/imfs_readlink.c, libc/imfs.h, libc/imfs_gtkn.c, libc/imfs_rmnod.c, libc/imfs_chown.c, libc/imfs_handlers_device.c, libc/imfs_stat.c, libc/imfs_creat.c, libc/imfs_handlers_directory.c, libc/imfs_symlink.c, libc/imfs_debug.c, libc/imfs_handlers_link.c, libc/imfs_unixstub.c, libc/imfs_directory.c, libc/imfs_handlers_memfile.c, libc/imfs_unlink.c, libc/imfs_eval.c, libc/imfs_init.c, libc/imfs_unmount.c, libc/imfs_fchmod.c, libc/imfs_initsupp.c, libc/imfs_utime.c, libc/imfs_fcntl.c, libc/imfs_link.c, libc/memfile.c, libc/imfs_fdatasync.c, libc/imfs_mknod.c, libc/miniimfs_init.c, libc/imfs_free.c, libc/imfs_mount.c, libc/imfs_fsunmount.c, libc/imfs_ntype.c: Moved to libfs/src/imfs. * Makefile.am: Modified to reflect above.
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-181-1/+1
| | | | | | | * libc/Makefile.am: Added mallocfreespace.c. * libc/mallocfreespace.c: New file based on work by Nick Simon <Nick.SIMON@syntegra.bt.co.uk> which he included in malloc.c. * libc/libcsupport.h: Added prototype for malloc_free_space().
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-4/+5
| | | | * libc/Makefile.am: Include compile.am
* Patch from Chris Johns <cjohns@cybertec.com.au> to add fchdir()Joel Sherrill2000-06-301-1/+1
| | | | functionality to libc and update TODO.
* Added printk as a generic, shared routine.Joel Sherrill2000-06-121-1/+2
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-20/+13
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-081-2/+0
* Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff fromJoel Sherrill2000-01-311-1/+0
| | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams
* Patch rtems-rc-19991117-9.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-221-0/+127
to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib."
