* tools/Makefile.am: Remove AUTOMAKE_OPTIONS.
* gdbsci/Makefile.am: Remove AUTOMAKE_OPTIONS.
* scitab/Makefile.am: Remove AUTOMAKE_OPTIONS.
* trap34/Makefile.am: Remove AUTOMAKE_OPTIONS.
* hw_init/Makefile.am: Remove AUTOMAKE_OPTIONS.
* bootloader/Makefile.am: Remove AUTOMAKE_OPTIONS.
* motorola/Makefile.am: Remove AUTOMAKE_OPTIONS.
* openpic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* pci/Makefile.am: Remove AUTOMAKE_OPTIONS.
* residual/Makefile.am: Remove AUTOMAKE_OPTIONS.
* vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PCI_bus/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tod/Makefile.am: Remove AUTOMAKE_OPTIONS.
* nvram/Makefile.am: Remove AUTOMAKE_OPTIONS.
* universe/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dlentry/Makefile.am: Remove AUTOMAKE_OPTIONS.
* flashentry/Makefile.am: Remove AUTOMAKE_OPTIONS.
* canbus/Makefile.am: Remove AUTOMAKE_OPTIONS.
* scv64/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sonic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* liblnk/Makefile.am: Remove AUTOMAKE_OPTIONS.
* fatal/Makefile.am: Remove AUTOMAKE_OPTIONS.
* consolex/Makefile.am: Remove AUTOMAKE_OPTIONS.
* spurious/Makefile.am: Remove AUTOMAKE_OPTIONS.
* i2c/Makefile.am: Remove AUTOMAKE_OPTIONS.
* debug_ada/Makefile.am: Remove AUTOMAKE_OPTIONS.
* debug_c/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dos_sup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* network_ada/adasockets/Makefile.am: Remove AUTOMAKE_OPTIONS.
* network_ada/Makefile.am: Remove AUTOMAKE_OPTIONS.
* network_ada/listener/Makefile.am: Remove AUTOMAKE_OPTIONS.
* network_ada/tcprelay/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ts_1325_ada/Makefile.am: Remove AUTOMAKE_OPTIONS.
* comm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* io/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 3c509/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ne2000/Makefile.am: Remove AUTOMAKE_OPTIONS.
* wd8003/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tty/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PR139
* configure.ac: Remove stray ';', breaks building with automake-1.6.
* configure.ac: Remove stray ';', PR 139.
* mips-stub.c: Removed warnings.
* start/start.S, startup/bspstart.c: Removed warnings.
* mips-stub.c: Debugged & tweaked the gdb command processing,
zbreak stuff, breakpoint and step code. Implemented 'T' command
support and debugged remote gdb support w/ the Mongoose bsp.
Added the memory segment support.
* memlimits.h: Disabled all contents in favor of memory sement
support. This file could probably go away.
* rtems-stub-glue.c (rtems_gdb_index_to_stub_id()): New routine.
rtems_gdb_stub_get_register_from_context(): Implemented MIPS version.
rtems_gdb_stub_get_offsets(): Implemented MIPS version.
* README: Updated.
* startup/gdb-support.c: Added calls into the mips-support gdb stub
for configuring the memory regions. Any bsp that wants to use the
gdbstub will need to do something similar.
* startup/Makefile.am: Added shared/gdbstub directory to include path.
* ChangeLog: Corrected previous entry.
* shared/gdbstub/README: Added text.
* shared/gdbstub/mips-stub.c: Modified isr install routine to
capture all exceptions.
* start/start.S: Added kseg1 test to enable cache flush code
* bsp_specs: Added -qnostartfile to disable including bsp's start.o
* startup/bspstart.c: Made clear_cache actually work, tweaked cpu
init to only turn on whats needed.
* startup/gdb-support.c: Added calls to uart 2 for gdb stub I/O and
a handy init function.
* console/sci.c, console/sci.h,
console/console.c: Added new SCI driver.
* start/start.c: Removed file.
* start/start.S: New file, the asm portion of the updated start code.
* start/configure.am: Added start.S, removed start.c
* startup/start_c.c: New file, the C portion of the updated start code. Contains most of the code that was in the old start.c.
* startup/configure.am: Added start_c.c to C_FILES.
* include/bsp.h: Added include <rtems/bspIo.h>
* Significant modifications including adding thread support, the 'X'
command, and reorganizing so that target CPU independent routines
could be reused.
* gdb_if.h: Added numerous prototypes.
* mips-stub.c: Added thread support as well as 'X' command.
Also noticed that the 'P' command was from the mips protocol.
* rtems-stub-glue.c: New file. This file contains all generic
support which should be able to be reused on another target CPU.
* startup/Makefile.am: Added rtems-stub-glue.c to C_FILES.
* mips-stub.c (handle_exception): Prototype changed to be an RTEMS
entry point. Added comments about possible need to flush cache.
(mips_gdb_stub_install): New routine.
* startup/Makefile.am: Now compile the gdb stub.
* startup/bspstart.c: Fixed header block.
* startup/gdb-support.c: New file in stub state.
* Makefile, stubinit.S, r46kstub.ld, ioaddr.h: Removed as unused
with RTEMS.
* r46kstub.c: Renamed to mips-stub.c.
* mips-stub.c: New file -- was r46kstub.c.
* memlimits.h: New file was limits.h.
* limits.h: Removed.
* r4600.h: Eliminated need for this file.
* README: Updated.
* gdb_if.h: Added CVS Id.
* mips-stub.c: Attempt to deal with MIPS1 versus MIPS3.
* Merged r46kstub.c into RTEMS distribution without modification.
I got the code from Franz Fischer <Franz.Fischer@franz-fischer.de>
who had used this with an old version of RTEMS with the mips64orion
port of RTEMS. After adding this to the repository, I will tailor
this to work with the RTEMS exception processing model and trim
no longer needed parts.
* ChangeLog, gdb_if.h, ioaddr.h, limits.h, Makefile, mips_opcode.h,
r4600.h, r46kstub.c, r46kstub.ld, README, stubinit.S:
* include/lr33000.h, include/lr330x0.h, include/r3000.h, start/mg5.h:
New files missed in previous commit.
* timer/timer.c: Use rtems/bspIo.h not just bspIo.h.
