* gdbsci/Makefile.am: Remove all-local: $(ARCH).
* scitab/Makefile.am: Remove all-local: $(ARCH).
* trap34/Makefile.am: Remove all-local: $(ARCH).
* hw_init/Makefile.am: Remove all-local: $(ARCH).
* PCI_bus/Makefile.am: Remove all-local: $(ARCH).
* tod/Makefile.am: Remove all-local: $(ARCH).
* shmsupp/Makefile.am: Remove all-local: $(ARCH).
* nvram/Makefile.am: Remove all-local: $(ARCH).
* pci/Makefile.am: Remove all-local: $(ARCH).
* universe/Makefile.am: Remove all-local: $(ARCH).
* irq/Makefile.am: Remove all-local: $(ARCH).
* motorola/Makefile.am: Remove all-local: $(ARCH).
* openpic/Makefile.am: Remove all-local: $(ARCH).
* residual/Makefile.am: Remove all-local: $(ARCH).
* vme/Makefile.am: Remove all-local: $(ARCH).
* ide/Makefile.am: Remove all-local: $(ARCH).
* dlentry/Makefile.am: Remove all-local: $(ARCH).
* flashentry/Makefile.am: Remove all-local: $(ARCH).
* canbus/Makefile.am: Remove all-local: $(ARCH).
* scv64/Makefile.am: Remove all-local: $(ARCH).
* sonic/Makefile.am: Remove all-local: $(ARCH).
* liblnk/Makefile.am: Remove all-local: $(ARCH).
* fatal/Makefile.am: Remove all-local: $(ARCH).
* consolex/Makefile.am: Remove all-local: $(ARCH).
* spurious/Makefile.am: Remove all-local: $(ARCH).
* 3c509/Makefile.am: Remove all-local: $(ARCH).
* ne2000/Makefile.am: Remove all-local: $(ARCH).
* wd8003/Makefile.am: Remove all-local: $(ARCH).
* Makefile.am: Fix stupid typo in previous patch.
* Makefile.am: Fix preinstallation of include/coverhd.h.
PR 510/bsps
* irq/irq.h: Add extern C wrapper.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac: Remove RTEMS_CHECK_CPU.
* ChangeLog: Add (missed in previous commits).
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* acinclude.m4: Reflect changes to bootstrap.
* configure.ac: Remove RTEMS_CHECK_CUSTON_BSP.
* configure.ac: Use AC_PATH_PROG(PERL,perl) instead of
RTEMS_PATH_PERL.
* comm/uart.h: Add extern "C" guards.
* pci/pcibios.h: Ditto.
PR 502/bsps
* console/outch.c: Add support for a few ANSI escape sequences to make
libetcl happy.
PR 503/bsps
* clock/ckinit.c, include/bsp.h, startup/efi68k_tcp.c, timer/timer.c:
Do not include DP8570A.h from bsp.h but still install it. This avoids
polluting the namespace.
* include/bsp.h: Replace stringification madness to pick up bare.h
(Doesn't work with gcc >= 3.3) with a somewhat cleaner madness.
* Makefile.am: Correct path to mvme16x_hw.h.
* vectors/Makefile.am: Fix header installation.
PR 497/bsps
* bootloader/head.S: Disable code that returned to the firmware when
the loader starts.
Reflect changes to bsp.am.
* include/bsp.h: Add copy of ../shared/include/bsp.h (Violates BSP
coding standards).
* irq/Makefile.am: Fix header installation.
* motorola/Makefile.am: Fix header installation.
* openpic/Makefile.am: Fix header installation.
* pci/Makefile.am: Fix header installation.
