commit them.
like signal dispatching.
correct Information block.
+ variable length messages
+ named devices
+ debug monitor
resulted in no output when the output was redirected until this was done.
Redirection is important because runtest redirects test output.
Added support for numerous environment variables which make it easier
to run a multi-node system using a single executable and to tailor
the size of the workspace and heap.
the count to "1" to indicate availability.
Interrupt support was added.
Problem where newlib's errno "overrides" that set by system calls
was addressed.
Fixed bug which resulted in all nodes using the same semaphore although
an array of semaphores was allocated.
+ c/src/lib/libc/support/generic/malloc.c did not initialize the
sbrk amount
+ _Thread_Handler in c/src/exec/rtems/thread.c left a window
during the begin extension which could result in a context switch
fixed places which did not correctly distinguish between an
CPU_isr and a CPU_isr_entry.
IDLE task priority changed from 0 to 255 during initialization.
