* | 2005-03-03 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2005-03-03 | 1 | -1/+1 |
| | | | | | | PR bsps/771 * configure.ac: Remove reference to arm_bare_bsp in AC_CONFIG_SRCDIR. Use ../arm instead. | ||||
* | arm_bare_bsp | Ralf Corsepius | 2005-03-03 | 1 | -2/+0 |
* | Add missing line. | Eric Norum | 2005-03-03 | 1 | -0/+1 |
* | Add some more EPICS notes. | Eric Norum | 2005-03-03 | 1 | -0/+6 |
* | 2005-02-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-02-25 | 19 | -1716/+12 |
| | | | | | | | | | | | | * arm_bare_bsp/.cvsignore, arm_bare_bsp/ChangeLog, arm_bare_bsp/Makefile.am, arm_bare_bsp/bsp_specs, arm_bare_bsp/configure.ac, arm_bare_bsp/clock/clockdrv.c, arm_bare_bsp/include/.cvsignore, arm_bare_bsp/include/bsp.h, arm_bare_bsp/include/registers.h, arm_bare_bsp/include/tm27.h, arm_bare_bsp/irq/bsp_irq_asm.S, arm_bare_bsp/irq/bsp_irq_init.c, arm_bare_bsp/irq/irq.c, arm_bare_bsp/irq/irq.h, arm_bare_bsp/start/start.S, arm_bare_bsp/startup/bspstart.c, arm_bare_bsp/startup/exit.c, arm_bare_bsp/startup/linkcmds: Removed. | ||||
* | 2005-02-24 Jay Monkman <jtm@lopingdog.com> | Jay Monkman | 2005-02-25 | 3 | -2/+46 |
| | | | | | | | PR 751/bsps * startup/linkcmds: Cleanup. * network/network.c: Added hardware initialization code. | ||||
* | 2005-02-24 Jay Monkman <jtm@lopingdog.com> | Jay Monkman | 2005-02-25 | 18 | -0/+2366 |
| | | | | | | | | | | | * acinclude.m4: Added csb350 to list of BSPs. * csb350/Makefile.am, csb350/README, csb350/bsp_specs, csb350/configure.ac, csb350/times, csb350/clock/clockdrv.c, csb350/console/console-io.c, csb350/include/bsp.h, csb350/include/tm27.h, csb350/network/network.c, csb350/start/regs.S, csb350/start/start.S, csb350/startup/bspclean.c, csb350/startup/bspstart.c, csb350/startup/linkcmds, csb350/timer/timer.c: New BSP. | ||||
* | 2005-02-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-02-18 | 2 | -59/+14 |
| | | | | * console/keyboard.h: Add include file and cleanup file header. | ||||
* | 2005-02-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-17 | 2 | -5/+9 |
| | | | | * startup/bspstart.c: Eliminate rtems_unsigned32. | ||||
* | 2005-02-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-17 | 12 | -10/+53 |
| | | | | | | * startup/bspstart.c: include <rtems/powerpc/powerpc.h>. Use PPC_MINIMUM_STACK_FRAME_SIZE instead of CPU_MINIMUM_STACK_FRAME_SIZE. | ||||
* | 2005-02-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-17 | 4 | -4/+19 |
| | | | | | | * start/start.S: include <rtems/powerpc/powerpc.h>. Use PPC_MINIMUM_STACK_FRAME_SIZE instead of CPU_MINIMUM_STACK_FRAME_SIZE. | ||||
* | Cosmetics. | Ralf Corsepius | 2005-02-16 | 9 | -31/+34 |
* | 2005-02-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-16 | 22 | -11/+55 |
| | | | | * configure.ac: Remove argument from RTEMS_PPC_EXCEPTIONS. | ||||
* | Remove (moved to libcpu). | Ralf Corsepius | 2005-02-15 | 11 | -2957/+0 |
* | 2005-02-15 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-15 | 2 | -1/+5 |
| | | | | * flashentry/flashentry.S: #include <rtems/powerpc/powerpc.h> | ||||
* | 2005-02-15 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-15 | 2 | -3/+8 |
| | | | | | * cpu.c: Use _CPU_MSR_GET instead of _CPU_MSR_Value (Unify old/new exception processing API). | ||||
* | 2005-02-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-15 | 4 | -50/+20 |
| | | | | | * startup/spurious.c: Merge ppc603 and ppc603e. Remove digits (Unused). | ||||
* | 2005-02-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-15 | 2 | -18/+5 |
| | | | | * cpu.c (ppc_exception_vector_addr): Merge ppc603 and ppc603e cases. | ||||
* | Remove some now-unused declarations. | Eric Norum | 2005-02-14 | 1 | -1/+0 |
* | Don't cache flash. | Eric Norum | 2005-02-14 | 2 | -5/+5 |
* | 2005-02-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-14 | 7 | -0/+13 |
| | | | | * cpu.c, cpu_asm.S, irq_stub.S: #include <rtems/powerpc/powerpc.h>. | ||||
* | EPICS has its own log facility so don't bother with LOGSERVER. | Eric Norum | 2005-02-13 | 1 | -1/+0 |
* | 2005-02-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-13 | 2 | -0/+6 |
| | | | | * cpu.c: Add _PPC_MSR_DISABLE_MASK. | ||||
* | Rearrange devLib address spaces. | Eric Norum | 2005-02-12 | 2 | -4/+4 |
* | Add some more system calls. | Eric Norum | 2005-02-12 | 2 | -9/+32 |
| | | | | Improve in-line assembly. | ||||
* | 2005-02-12 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-02-12 | 2 | -1137/+9 |
| | | | | | * pci/pci.h: Remove contents that are duplicates of the pci.h in cpukit and include rtems/pci.h for the base set of PCI functionality. | ||||
* | 2005-02-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-12 | 4 | -2/+10 |
| | | | | * Makefile.am: Fix typo in previous patch. | ||||
* | Remove (Unused) | Ralf Corsepius | 2005-02-12 | 2 | -14/+0 |
* | 2005-02-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-12 | 6 | -88/+8 |
| | | | | * Makefile.am, configure.ac: Remove (Unused). | ||||
* | Remove. | Ralf Corsepius | 2005-02-12 | 11 | -21/+0 |
* | 2005-02-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-12 | 44 | -299/+223 |
| | | | | | | * Makefile.am: Merge-in wrapup/Makefile.am. * wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above. | ||||
* | 2005-02-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-02-12 | 2 | -3/+8 |
| | | | | | * m68kpretaskinghook.c: Correct type of symbols from linkcmds to compile with gcc 4.x. | ||||
* | 2005-02-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-02-12 | 6 | -15/+15 |
| | | | | | * include/bsp.h: Correct type of symbols from linkcmds to compile with gcc 4.x. | ||||
* | 2005-02-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-02-12 | 3 | -1/+8 |
| | | | | | * include/bsp.h, startup/init68360.c: Correct type of symbols from linkcmds to compile with gcc 4.x. | ||||
* | Name changes. | Eric Norum | 2005-02-10 | 3 | -6/+35 |
| | | | | Add some more system calls. | ||||
* | 2005-02-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-10 | 2 | -4/+5 |
| | | | | * vectors/vectors.S: Remove PPC_ABI_POWEROPEN. | ||||
* | 2005-02-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-10 | 3 | -8/+5 |
| | | | | | * dlentry/dlentry.S, flashentry/flashentry.S: Remove PPC_ABI_POWEROPEN. | ||||
* | 2005-02-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-10 | 2 | -4/+4 |
| | | | | * dlentry/dlentry.S: Remove PPC_ABI_POWEROPEN. | ||||
* | 2005-02-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-10 | 5 | -73/+10 |
| | | | | | * cpu.c, cpu_asm.S, irq_stub.S, rtems/score/ppc_offs.h: Remove PPC_ABI_POWEROPEN. | ||||
* | 2005-02-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-09 | 2 | -1/+5 |
| | | | | * vectors/vectors.S: Remove PPC_ABI_GCC27. | ||||
* | 2005-02-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-09 | 5 | -15/+9 |
| | | | | | * cpu.c, cpu_asm.S, irq_stub.S, rtems/score/ppc_offs.h: Remove PPC_ABI_GCC27. | ||||
* | 2005-02-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-09 | 4 | -4/+8 |
| | | | | * vectors/vectors.S: Remove XCOFF support. | ||||
* | Intra-level priorities range from 0 to 7. | Eric Norum | 2005-02-08 | 1 | -1/+1 |
| | | | | Levels range from 1 to 6. | ||||
* | Ensure consistency of 'installed' bitmap. | Eric Norum | 2005-02-08 | 1 | -1/+5 |
* | Set INTC0_ICRx registers properly. | Eric Norum | 2005-02-07 | 1 | -1/+1 |
* | Fix typo. | Eric Norum | 2005-02-05 | 1 | -1/+1 |
* | Clean up the RAM/FLASH sizes/locations are specified. | Eric Norum | 2005-02-05 | 2 | -18/+12 |
* | Fix flash base address. | Eric Norum | 2005-02-04 | 3 | -7/+14 |
| | | | | Enable UART2. | ||||
* | Reformat. | Ralf Corsepius | 2005-02-04 | 1 | -8/+5 |
* | Clean up INTC0 initialization. EPORT1-7 sources are fixed level/priority. | Eric Norum | 2005-02-04 | 1 | -14/+25 |
