<raguet@crf.canon.fr> to make their patches work together.
Here is a patch for KA9Q stack.
This patch contains an Ethernet Driver for Western Digital,
some fixes for the UDP and TCP protocols (for endian conversion)
and some little programs which allow the test of UDP and TCP
sockets via Ethernet.
I have tested that on an Intel machine. If someone can test it
on a big-endian machine, ...
of theses targets...
libchip, libio, and termios efforts.
Tested all four ports. MC68681 as both polled and interrupt. Z8530 as
polled only.
This routines could be enhanced to determine if the SCC is present
since it appears from the DY-4 manual that a status registers indicates
this.
Deleted CSS interface related items.
Added items required to access DMA Control and Status Register so we
could figure out dynamically what the clock speed of the SCC really is.
RS-422 converter. We now see the TD light blink when typing
characters in HyperTerminal and when the board is reset we see
the RD light blink. This leads us to believe the cabling is
basically right.
* c/src/lib/libbsp/sh/gensh1/scitab - NEW DIRECTORY
Location for building the table generated by shgen
register access routines.
Added proper headers to routines.
interrupt vector can be shared by multiple chips of varying types.
compilation section which used CONSOLE_USE_INTERRUPTS to switch all
ports between interrupt and polled mode.
c/src/lib/libbsp/i386/pc386/console/console.c
__assert() modified so it prints on selected console instead of
PC console
c/src/lib/libbsp/i386/pc386/console/inch.c
inch_sleep() modified, so it does not depend upon tmacros.h
c/src/lib/libbsp/i386/pc386/pc386dev/GDB.HOWTO
description updated
c/src/lib/libbsp/i386/pc386/startup/exit.c
last output before call to exit() will be printed properly on
serial console
c/src/lib/libbsp/i386/pc386/startup/irq.c
re-submitted bug fix for problem in irqs over 7.
with this ROM monitor.
to polled.
"if defined".
and eliminate warnings.
to fill in the configuration table.
libchip/serial.
for the z85c30 found on the DMV177. This effort started with the
console driver from the Radstone PPC2. But some simplifications were
made in the hope that console.c can be made a shared file at some point
in the near future.
Split the debugio from console. This was done so at some point in the
future printk support as is found in the pc386 BSP can be shared
across all BSPs.
Geoffroy Montel <g_montel@yahoo.com>.
sent an example bare bsp but we have not decided how to integrate it yet.
<qqi@world.std.com>). Unfortunately after merging these,
the pc386 will not boot using grub for for. It still does not
work using netboot for me. Here is his summary of changes:
rtems/c/src/lib/libbsp/i386/pc386/Makefile.in
Added support for new sub-directory
rtems/c/src/lib/libbsp/i386/pc386/bsp_specs
Made possible to build COFF image
rtems/c/src/lib/libbsp/i386/pc386/console/console.c
Added support for serial consoles, selectable by patching
binary image, added __assert(), use _IBMPC_inch_sleep()
instaed of _IMBPC_inch()
rtems/c/src/lib/libbsp/i386/pc386/console/inch.c
Added _IMBPC_inch_sleep()
rtems/c/src/lib/libbsp/i386/pc386/console/outch.c
Oops - just formatting
rtems/c/src/lib/libbsp/i386/pc386/include/Makefile.in
Added support for new files
rtems/c/src/lib/libbsp/i386/pc386/include/bsp.h
Added support for new features
rtems/c/src/lib/libbsp/i386/pc386/include/pc386uart.h
New file: definitions for serial ports
rtems/c/src/lib/libbsp/i386/pc386/include/pcibios.h
New file: definitions for PCI BIOS
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/Makefile.in
New file: makefile in new directory
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub-glue.c
New file: i386-stub interface
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub.c
New file: i386-stub itself
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pc386uart.c
New file: serial ports
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pcibios.c
New file: PCI BIOS support
rtems/c/src/lib/libbsp/i386/pc386/start/start.s
Commented out DEBUG_EARLY stuff, everything is working fine
rtems/c/src/lib/libbsp/i386/pc386/start/start16.s
Cleaned up
rtems/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
Added call to console_resereve_resources
rtems/c/src/lib/libbsp/i386/pc386/startup/exit.c
rtems/c/src/lib/libbsp/i386/pc386/startup/ldsegs.s
Fixed typo in comments
rtems/c/src/lib/libbsp/i386/pc386/tools/Makefile.in
Changed to reflect cnages in code
rtems/c/src/lib/libbsp/i386/pc386/tools/bin2boot.c
Trivialized, problem - I do not know how to make patch
remove obsolete files - there are a lot of them there
rtems/c/src/lib/libbsp/i386/pc386/tools/binpatch.c
New file: utility to do binary patches
rtems/c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in
Added support for new directory
rtems/make/custom/pc386.cfg
Add COFF image building
