* Makefile.am: Add transform and bsptools_bindir hacks.
* startup/linkcmds: Added __EH_FRAME_BEGIN__ and __EH_FRAME_END__
to remove problems linking empty main(){} with BSP.
* bootloader/em86real.S: Fix syntax error in comment near line 1185.
* bootloader/Makefile.am: Install bootloader.o.
Install bootloader/bootloader.ppcboot.lds.
* vectors/Makefile.am: Install bsp/vectors.h.
* include/Makefile.am: Fix preinstallation.
* bootloader: Eliminate $(INCLUDES).
* startup/bspstart.c: Per PR252 removed hack that tripled size of
RTEMS Workspace when POSIX is configured. This was probably done to
account for confdefs.h missing some application requirements.
* Makefile.am: Fix oversights in previous patch.
* startup/Makefile.am: Reformat.
* rtems.S: Remove.
* Makefile.am: Reflect having removed rtems.S. Use AM_CPPFLAGS
instead of INCLUDES (Latest automake standard).
* start/Makefile.am: Fix bug in previous patch.
Really add bsplib_DATA = $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o.
Fix bsplib_DATA = $(PROJECT_RELEASE)/lib/rxgen_romld$(LIB_VARIANT).o.
(Didn't make it into cvs at 2002-07-20 :( )
* start/Makefile.am: Eliminate PGMS.
bsplib_DATA += $(PROJECT_RELEASE)/lib/except_vect_332_ROM$(LIB_VARIANT).o
bsplib_DATA += $(PROJECT_RELEASE)/lib/ram_init$(LIB_VARIANT)
bsplib_DATA += $(PROJECT_RELEASE)/lib/ram_init_FW$(LIB_VARIANT)
Add bsplib_DATA = $(PROJECT_RELEASE)/lib/rxgen_romld$(LIB_VARIANT).o.
* start/Makefile.am: Remove leftover from eliminating PGM.
Add bsplib_DATA += $(PROJECT_RELEASE)/lib/start16$(LIB_VARIANT).bin.
* startup/Makefile.am: Add bsplib_DATA = linkcmds device-tree.
* startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds-le.
* startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds.rom
linkcmds.rom2ram.
* startup/Makefile.am: Add bsplib_DATA = linkcmds ghlinkcmds.
* startup/Makefile.am: Add bsplib_DATA = linkcmds rom debugger.
* startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds_ROM.
* startup/Makefile.am: Add bsplib_DATA = linkcmds gdbinit
linkcmds.flash.
* startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds.prom
linkcmds.bootp.
* startup/Makefile.am: Add bsplib_DATA = linkcmds ramlink romlink.
* bsp.am: Add bsplib_DATA = bsp_specs.
* irq_bsp_irq_asm.S: Update to reflect irq_asm modifications.
* irq/irq_asm.S: Significant rework in attempt to make interrupts
work. They appear to be very close to correct but not 100%.
* start/start.S: Added SWI_Handler.
* irq/bsp_irq_asm.S: Disable code to touch PIC.
* console/console.c: Others on the rtems-users list have expressed
concern about this run-time selection, so I've enclosed the changes
in a #ifdef RTEMS_RUNTIME_CONSOLE_SELECT conditional.
