* | Clean up from Aleksey Romanov (Quality Quorum <qqi@world.std.com>). | Joel Sherrill | 1998-06-25 | 1 | -26/+3 |
| | | | | | | | Here are his comments: I removed all unnecessary stuff from start16.s - setting idt and setting 16-bit stack using .code32 istructions. | ||||
* | Removed blank lines and bad debug stuff | Joel Sherrill | 1998-06-22 | 1 | -20/+0 |
* | Spacing changes. | Joel Sherrill | 1998-06-18 | 1 | -3/+3 |
* | Corrected compilation problems. | Joel Sherrill | 1998-06-16 | 2 | -13/+21 |
* | Added initialization of css routines. | Joel Sherrill | 1998-06-16 | 1 | -1/+3 |
* | Added css_iface -- assumes ../include/dy_supplied. | Joel Sherrill | 1998-06-16 | 4 | -2/+210 |
* | Adding interrupt handling routine. | Joel Sherrill | 1998-06-13 | 1 | -5/+15 |
* | Removed bad comments. | Joel Sherrill | 1998-06-13 | 1 | -7/+0 |
* | Added IRQ information. | Joel Sherrill | 1998-06-13 | 1 | -2/+31 |
* | Updated to add -qrtems_debug and -qnolinkcmds. | Joel Sherrill | 1998-06-13 | 1 | -2/+7 |
* | Added support for -qrtems_debug flag. | Joel Sherrill | 1998-06-04 | 1 | -1/+3 |
* | Removed PPC_Get_timebase_register() as this is now provided by the PowerPC | Joel Sherrill | 1998-06-03 | 1 | -19/+0 |
| | | | | port itself. | ||||
* | Update from Pedro Romano <pmcnr@camoes.rnl.ist.utl.pt> with an attempt | Joel Sherrill | 1998-06-03 | 2 | -15/+39 |
| | | | | to fix start16.s. It does not work locally. | ||||
* | Update from Pedro Romano <pmcnr@camoes.rnl.ist.utl.pt> which replaces C++ | Joel Sherrill | 1998-06-03 | 2 | -9/+208 |
| | | | | versions of these utilities with C implementations. | ||||
* | Changed calculaction for Clock_Decrementer_value to use the | Joel Sherrill | 1998-05-30 | 1 | -2/+4 |
| | | | | BSP_configuration table. | ||||
* | Set console to port 2. | Joel Sherrill | 1998-05-30 | 1 | -2/+2 |
| | | | | Changed #if defined to a #if check for CONSOLE_USE_INTERRUPTS. | ||||
* | Made Debug defination a null routine. | Joel Sherrill | 1998-05-30 | 1 | -0/+5 |
* | clicks_per_usec had to be cut in half (unknown reason). | Joel Sherrill | 1998-05-30 | 2 | -3/+5 |
| | | | | fixed starting address. | ||||
* | Updated to current source and removed warnings. | Joel Sherrill | 1998-05-30 | 22 | -444/+206 |
* | Used shared sbrk.c. | Joel Sherrill | 1998-05-30 | 1 | -61/+0 |
* | Use shared initialization. | Joel Sherrill | 1998-05-30 | 1 | -151/+0 |
* | Rewrote in C to avoid Makefile problems. | Joel Sherrill | 1998-05-30 | 2 | -25/+17 |
* | New files -- from rtems-LM-980406 which was based on an RTEMS from 12/97. | Joel Sherrill | 1998-05-30 | 34 | -0/+5693 |
| | | | | | | This was called the dmv170 BSP in that source tree but since the DMV171 is now obsolete, we have transitioned to the DMV177 and have no intention of checking compatibility with any other models. | ||||
* | Deleted blank lines. | Joel Sherrill | 1998-05-27 | 1 | -6/+0 |
* | Added "speaker on" debug code. | Joel Sherrill | 1998-05-27 | 1 | -0/+12 |
* | Numerous changes including the following: | Joel Sherrill | 1998-05-27 | 3 | -257/+194 |
| | | | | | | | | | | | | + DEBUG_EARLY_START re-added (Eric Valette) + segment register initialization (Aleksey/Quality Quorum) + heap size use correction + more debug printk's + increased heap size. Now works with grub boot on all systems I have access to including desktops and a laptop. This is with the i386-rtems tools. Neither i386-rtemself nor netboot produces a working executable. | ||||
* | Moved rtemsReboot() to console/inch.c. | Joel Sherrill | 1998-05-27 | 1 | -14/+0 |
* | Deleted HEAP_SIZE constant. | Joel Sherrill | 1998-05-27 | 1 | -5/+0 |
* | Removed illegally formatted comments. | Joel Sherrill | 1998-05-27 | 1 | -4/+4 |
* | Moved rtemsReboot() to here from exit.c. This appears to have been | Joel Sherrill | 1998-05-27 | 1 | -0/+12 |
| | | | | necessary because a patch did not apply cleanly. | ||||
* | UNIX port now builds and runs cleanly with both C++ support enabled | Joel Sherrill | 1998-05-22 | 1 | -1/+0 |
| | | | | and disabled. | ||||
* | Added call to console_reserve_resources back in. | Joel Sherrill | 1998-05-22 | 1 | -0/+6 |
* | Added main() which did not require C++ support. A different main | Joel Sherrill | 1998-05-22 | 2 | -2/+66 |
| | | | | is used based on whether C++ is enabled or disabled. | ||||
* | Added bare bsp from Chris Johns <cjohns@plessey.com.au>. | Joel Sherrill | 1998-05-21 | 7 | -3/+316 |
* | Corrected license notices per Eric's permission | Joel Sherrill | 1998-05-21 | 2 | -34/+12 |
* | New file from Eric Valette | Joel Sherrill | 1998-05-21 | 2 | -0/+152 |
* | Remove --start-group/--end-group pair to support non-GNU ld's. | Joel Sherrill | 1998-05-21 | 1 | -2/+2 |
* | Patch from Ralf Corseipus to fix latent configure problems suddenly triggered: | Joel Sherrill | 1998-05-20 | 6 | -273/+209 |
| | | | | | | | | | | | | | | | | | | | | | | | The breakdown: * CC_FOR_TARGET and CXX_FOR_TARGET were not correctly re-read from autoconf's configuration cache (config.cache) * If <target>-[gcc|g++] was not found while running configure, the config macros tried to use other (wrong) compilers (e.g. cc). Changes: * New RTEMS_PROG_CC macro (aclocal/prog-cc.m4). * New RTEMS_PROG_CXX macro (aclocal/prog-cxx.m4) * Moved a shell script fragment from configure.in to a new m4-autoconf macro (New file: aclocal/tool-prefix.m4) * Minor changes to configure.in I tested it with linux/posix (native gcc/primary libc) and sh-rtems/gensh1 on a linux host and didn't notice any bugs related to the problems mentioned above. There seem to be more bugs with the posix bsp, but I consider them minor as the build run completed successfully. It is just too late for me to attempt to fix them now. | ||||
* | New file from Pedro Romano | Joel Sherrill | 1998-05-18 | 1 | -0/+178 |
* | Update from Ralf Corsepius. | Joel Sherrill | 1998-05-18 | 1 | -0/+8 |
* | Updates from Pedro Romano. | Joel Sherrill | 1998-05-18 | 2 | -10/+14 |
* | New file. | Joel Sherrill | 1998-05-18 | 2 | -1/+26 |
* | Cleaned up to remove warnings. | Joel Sherrill | 1998-05-11 | 1 | -2/+1 |
* | Switched to termios callback structure. | Joel Sherrill | 1998-05-04 | 3 | -43/+70 |
* | Corrected and added sections to link cleanly under powerpc-rtems (ELF). | Joel Sherrill | 1998-05-04 | 2 | -17/+30 |
* | Removed warning for unnecessary reference to start as entry point. | Joel Sherrill | 1998-05-04 | 1 | -1/+1 |
* | Patch from Eric Norum to switch to termios callback structure and | Joel Sherrill | 1998-05-04 | 1 | -15/+85 |
| | | | | add support for changing the baudrate. | ||||
* | Corrected and added sections to link cleanly under i386-rtemself. | Joel Sherrill | 1998-05-04 | 1 | -35/+44 |
* | removed warning for implicit declaration of idtsim__exit() | Joel Sherrill | 1998-05-02 | 2 | -0/+4 |
* | removed warning for implicit declaration of resolve() | Joel Sherrill | 1998-05-02 | 1 | -0/+1 |
