PR 338/filesystem
* console.c: Side-effect of fixing reentrancy problem with
rtems_io_lookup_name() (API change).
* shmdr/Makefile.am: Add .h files to PREINSTALL_FILES not
TMPINSTALL_FILES.
* startup/Makefile.am, startup/linkcmds, startup/linkcmds-le,
startup/linkcmds-le.coff: Fix to work around truncated section names.
* startup/linkcmds: Fix to work around truncated section names.
* startup/linkcmds, startup/linkcmds.rom, startup/linkcmds.rom2ram: Fix
* startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Fix to
* include/DP8570A.h, include/bsp.h, start/start.c,
startup/efi68k_tcp.c: Rename tcp_init() to bsp_tcp_init()
to avoid conflict with TCP/IP stack internal routine.
* shmdr/Makefile.am: install mpci.h and shm_driver.h.
Eliminate OBJS.
* wrapup/Makefile.am: Fix typo in CPU_PIECES handling.
* console/sci.c, include/mrm332.h, startup/linkcmds,
startup/linkcmds_ROM: Various updates to make this run properly
from ROM.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* startup/linkcmds-le, startup/linkcmds-le.coff: Add FreeBSD sysctl()
sections.
* startup/linkcmds.rom, startup/linkcmds.rom2ram: Add FreeBSD sysctl()
sections.
* startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Add
* startup/linkcmds.dl: Add FreeBSD sysctl() sections.
* ChangeLog: Add FreeBSD sysctl() sections.
* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* wrapup/Makefile.am: Reflect changes to libcpu/sh/*.
* shmdr/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* hw_init/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* liblnk/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shmsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* scitab/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* gdbsci/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* trap34/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* tty/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* configure.ac: Add BSPOPTS (WORKSPACE_MB, HEAPSPACE_MB).
* ChangeLog: Fix ChangeLog-entry.
* 3c509/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ne2000/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* wd8003/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* startup/linkcmds: Shifted .init, .fini to match better with
crtbegin/crtend linking.
* bootloader/head.S: Added support for optional debug via PPCbug.
Also turn off mmu/caches for the bootstrap phase, which seems to
cause trouble with the 603. The cpu init functions in the bsp
get all that stuff going properly.
* bsp_specs: Added crtbegin/crtend and INIT_FINI for C++ support.
* linkcmds: Added .init, .fini & related sections.
* i2c/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* nvram/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* tod/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* consolex/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* console/Makefile.am: Eliminate C_O_FILES.
* fatal/Makefile.am: Don't include @RTEMS_BSP@.cfg.
