path: root/c/src/lib/libbsp (unfollow)
2018-05-09sparc64 niagara, usiii: Remove -D options from cfg file and move to bspopts.hJoel Sherrill2-1/+13
Updates #3425.
2018-05-09smdk2410: Move define of CPU_S3C2410 to bspopts.hJoel Sherrill1-2/+5
Updates #3425.
2018-04-27bsp/pc386: Remove bin2boot supportSebastian Huber6-833/+0
Update #3408. Close #3410.
2018-04-26bsp/mcf5206elite: Do not install runtest scriptSebastian Huber5-399/+0
Provide the runtest script only as a part of the sources. This simplifies the build system. Test support should be included in the RTEMS Tester.
2018-04-26bsps: Move documentation, etc. files to bspsSebastian Huber127-12218/+0
This patch is a part of the BSP source reorganization. Update #3285.
2018-04-26bsps: Remove unmaintained times filesSebastian Huber4-765/+0
2018-04-26bsp/sparc64: Move asm.S to bsps and renameSebastian Huber3-19/+2
2018-04-26bsps/mips: Move liblnk to bspsSebastian Huber5-248/+6
2018-04-26bsps/powerpc: Move bsp-start-zero.S to bspsSebastian Huber5-119/+4
2018-04-26bsp/psim: Move align_h.S to bspsSebastian Huber2-440/+1
2018-04-26bsp/haleakala: Move assembler files to bspsSebastian Huber3-322/+2
2018-04-25bsp/qemuppc: Install linkcmds.baseSebastian Huber1-0/+1
Update #3339. Close #3411.
2018-04-25bsps/arm: Remove unused filesSebastian Huber13-17990/+0
2018-04-25bsps: Remove unused u-boot-generic-board-info.hSebastian Huber1-132/+0
2018-04-25bsp/beagle: Move source files to bspsSebastian Huber5-1621/+4
2018-04-25bsp/gumstix: Move fb.c to bspsSebastian Huber2-240/+1
2018-04-25bsp/lm3s69xx: Move ssi.c to bspsSebastian Huber2-171/+1
2018-04-25bsp/lpc176x: Move source files to bspsSebastian Huber13-2426/+13
2018-04-25bsp/lpc24xx: Move source files to bspsSebastian Huber10-1963/+9
2018-04-25bsp/lpc32xx: Move source files to bspsSebastian Huber12-1239/+11
2018-04-25bsp/raspberrypi: Move source files to bspsSebastian Huber7-1591/+4
2018-04-25bsp/smdk2410: Move smc.c to bspsSebastian Huber2-411/+1
2018-04-25bsp/tms570: Move cpucounterread.c to bspsSebastian Huber2-63/+1
2018-04-25bsp/mcf5206elite: Move nvram.c to bspsSebastian Huber2-174/+1
2018-04-25bsp/mrm332: Move interr.c to bspsSebastian Huber1-50/+0
2018-04-25bsp/mrm332: Move spinit.c to bspsSebastian Huber2-97/+1
2018-04-25bsp/gen5200: Move source files to bspsSebastian Huber7-3129/+4
2018-04-25bsp/haleakala: Move mmu_405.c to bspsSebastian Huber2-294/+1
2018-04-25bsp/beatnik: Move source files to bspsSebastian Huber8-2721/+4
2018-04-25bsp/mvme3100: Move flashcfg.c to bspsSebastian Huber2-117/+1
2018-04-25bsp/mvme5500: Move source files to bspsSebastian Huber4-545/+3
2018-04-25bsp/virtex5: Move mmu.c to bspsSebastian Huber2-582/+1
2018-04-25bsp/virtex4: Move mmu.c to bspsSebastian Huber2-568/+1
2018-04-25bsp/gensh4: Move hw_init.c to bspsSebastian Huber2-284/+1
2018-04-24bsps: Move arm-cp15-set-ttb-entries.c to bspsSebastian Huber10-98/+9
2018-04-24bsps: Move arm-cp15-set-exception-handler.c to bspsSebastian Huber9-64/+8
2018-04-24bsps: Move arm-a9mpcore-smp.c to bspsSebastian Huber5-74/+4
2018-04-24bsps: Move arm-pl050.c to bspsSebastian Huber2-117/+1
2018-04-24bsps: Move arm-pl011.c to bspsSebastian Huber2-92/+1
2018-04-24bsps: Move arm-pl111-fb.c to bspsSebastian Huber3-278/+2
2018-04-24bsps: Move arm-generic-timer-clock-config.c to bspsSebastian Huber2-203/+1
2018-04-24bsps: Move arm-a9mpcore-clock-config.c to bspsSebastian Huber4-215/+3
2018-04-24bsps: Move armv7m-cpucounter.c to bspsSebastian Huber2-54/+1
2018-04-24bsps: Move bspreset.c to bspsSebastian Huber5-42/+4
2018-04-24bsps/i386: Move shared files to bspsSebastian Huber11-4283/+8
2018-04-24bsps/m68k: Remove unused filesSebastian Huber2-109/+0
2018-04-24bsps: Move spansionFlash.c to bspsSebastian Huber2-478/+1
2018-04-24bsps: Move intelFlash.c to bspsSebastian Huber2-465/+1
2018-04-24bsps: Move flash.c to bspsSebastian Huber3-911/+2
2018-04-24bsps: Move vpd.c to bspsSebastian Huber3-324/+2
