* clock/clock.c: Per PR257, remove reference to c3x_set_ie.
c4x variant should use c4x_set_iie().
* startup/bspstart.c: As part of fixing PR281 on gensh4, a review
of all calls to bsp_libc_init() resulted in some cleanup here.
* include/bsp.h, startup/Makefile.am, startup/bspclean.c:
Cleanup so the BSP works.
* start/start16.S: Remove unwanted + at beginning of relative
numeric label.
numeric label.
* configure.ac: Remove duplicate timer/Makefile in AC_CONFIG_FILES.
* Makefile.am: Don't use RTEMS_TOPdir in ACLOCAL_AMFLAGS.
* Makefile.am: ACLOCAL_AMFLAGS = -I ../../../../../../aclocal.
* clock/clock.c: Disabled use of fast idle since it seems broken
with gcc 3.2.
* pci/pcibios.c: #include <string.h>.
* console/Makefile.am: Add $(PROJECT_INCLUDE)/rtems to
PREINSTALL_FILES.
* console/mouse_parser.c: Include <string.h> (for strcmp).
* console/vt.c: Include <string.h> (for memcpy).
* wd8003/wd8003.c: Include <string.h> (for memcpy, memset).
* startup/linkcmds: Move .init section after text section so
C+ global constructors work.
* wrapup/Makefile.am: PR217 required that the idle task be moved to
libcpu so it could be more acutely aware of the CPU model. This
file was modified to pick up the idle task from there.
* mips-stub.c: Re-debugged a breakpoint problem, zbreak target
address was a char * which caused the target instruction to not
be fully copied, so the zbreak logic corrupted the original
instruction and didn't insert a valid break instruction.
* start/start16.S: Per PR259, added code to test for video present
before touching the adapter. Eric Norum <eric.norum@usask.ca>
tested this patch.
* console/ps2_mouse.c: Include <string.h> (for abort/exit).
* bootloader/Makefile.am: Fix that crappy Makefile.am once again.
* shmdr/Makefile.am: Use .$(OBJEXT) instead of .o.
* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* PCI_bus/Makefile.am: Use .$(OBJEXT) instead of .o.
* tod/Makefile.am: Use .$(OBJEXT) instead of .o.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* nvram/Makefile.am: Use .$(OBJEXT) instead of .o.
* pci/Makefile.am: Use .$(OBJEXT) instead of .o.
* universe/Makefile.am: Use .$(OBJEXT) instead of .o.
* irq/Makefile.am: Use .$(OBJEXT) instead of .o.
* bootloader/Makefile.am: Use .$(OBJEXT) instead of .o.
* motorola/Makefile.am: Use .$(OBJEXT) instead of .o.
* openpic/Makefile.am: Use .$(OBJEXT) instead of .o.
* residual/Makefile.am: Use .$(OBJEXT) instead of .o.
* dlentry/Makefile.am: Use .$(OBJEXT) instead of .o.
* flashentry/Makefile.am: Use .$(OBJEXT) instead of .o.
* canbus/Makefile.am: Use .$(OBJEXT) instead of .o.
* scv64/Makefile.am: Use .$(OBJEXT) instead of .o.
* sonic/Makefile.am: Use .$(OBJEXT) instead of .o.
* liblnk/Makefile.am: Use .$(OBJEXT) instead of .o.
* fatal/Makefile.am: Use .$(OBJEXT) instead of .o.
* consolex/Makefile.am: Use .$(OBJEXT) instead of .o.
* tools/Makefile.am: Use .$(OBJEXT) instead of .o.
* spurious/Makefile.am: Use .$(OBJEXT) instead of .o.
* i2c/Makefile.am: Use .$(OBJEXT) instead of .o.
