2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -4/+14 | |
* console/console.c, network/network.c: Removed warnings. | |||||
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -1/+5 | |
* irq/irq.c: Removed warnings. | |||||
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 4 | -1/+11 | |
* network/network.c: Removed warnings. | |||||
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -0/+7 | |
* console/i8042.c: Removed warnings. | |||||
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 7 | -7/+24 | |
* console/console.c, irq/irq.c, network/if_hdlcsubr.c, network/if_hdlcsubr.h, network/network.c, vectors/vectors_init.c: Removed warnings. | |||||
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 6 | -27/+39 | |
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -2/+4 | |
* clock/clock.c: Removed warnings. | |||||
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -0/+5 | |
* console/console.c: Removed warnings. | |||||
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -24/+32 | |
* console/sci.c, spurious/spinit.c: Removed warnings. | |||||
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 6 | -23/+8 | |
* console/console.c, i2c/i2cdrv.c, nvram/nvram.c, startup/bspstart.c, tod/ds1307.c: Removed warnings. | |||||
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -3/+11 | |
* console/console.c, console/m340uart.c: Removed warnings. | |||||
2002-11-04 | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -1/+6 | |
* console/console.c, network/ne2000.c: Removed warnings. | |||||
2002-11-02 | 2002-11-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -2/+7 | |
* console/console.c, start/start.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -31/+31 | |
* console/console.c, start/start.c, startup/efi68k_wd.c: | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -38/+42 | |
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -4/+8 | |
* startup/m68k-stub.c: Removed typos. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 4 | -7/+13 | |
* irq/irq.c, irq/irq_asm.S, startup/bspstart.c: Fixed typos and removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -0/+5 | |
* gnatcommon.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -1/+11 | |
* gnatsupp/gnatsupp.c, startup/spurious.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -5/+8 | |
* clock/ckinit.c, console/console.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -2/+8 | |
* gdbsci/gdbsci.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -3/+5 | |
* start/start.S, startup/hw_init.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -0/+14 | |
* cpu.c: Currently only the mpc8260 BSP supports interrupt nesting. NOTE: These needs to be generalized as the patch is applied to other BSPs. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 4 | -12/+19 | |
* clock/p_clock.c, console/console.c, startup/bspstart.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 6 | -12/+20 | |
* canbus/canbus.c, clock/p_clock.c, console/console.c, network/network.c, startup/bspstart.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -2/+6 | |
* startup/genpvec.c, tod/todcfg.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -5/+10 | |
* mips-stub.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -2/+8 | |
* startup/bspclean.c, startup/bspstart.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -0/+7 | |
* startup/gdb-support.c, startup/linkcmds: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -3/+6 | |
* console/conscfg.c, startup/bspstart.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -199/+203 | |
* startup/m68k-stub.c: Removed warnings. | |||||
* network/network.c, startup/bspclean.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -10/+15 | |
* startup/page_table.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 4 | -2/+15 | |
* startup/bspstart.c: Removed warnings. | |||||
2002-11-01 | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -5/+9 | |
* m68k-stub.c: Corrected typos. | |||||
2002-11-01 | 2002-11-01 Andy Dachs <a.dachs@sstl.co.uk> | Joel Sherrill | 4 | -377/+484 | |
* irq/irq.c, irq/irq_asm.S, irq/irq_init.c: Per PR288, add support for _ISR_Nest_level. | |||||
2002-10-31 | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -2/+7 | |
* comm/i386-stub.c: Fixed places where debug_error() was not called with enough arguments. | |||||
2002-10-31 | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -3/+8 | |
* comm/i386-stub.c: Removed warnings. | |||||
2002-10-31 | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 8 | -4/+21 | |
* bootloader/em86.c, console/inch.c, console/polled_io.c, irq/irq.c, motorola/motorola.c, pci/detect_raven_bridge.c, vectors/vectors_init.c: Removed warnings. | |||||
2002-10-31 | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -76/+81 | |
* m68k-stub.c: Fixed warnings about multi-line strings in asm. | |||||
2002-10-28 | 2002-10-28 Eugeny S. Mints <Eugeny.Mints@oktet.ru> | Joel Sherrill | 2 | -0/+183 | |
* ide_ctrl.c: New file. | |||||
2002-10-21 | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 168 | -254/+760 | |
* .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | |||||
2002-10-09 | 2002-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -0/+5 | |
* .cvsignore: Add autom4te.cache. | |||||
2002-10-04 | 2002-10-04 Jay Monkman <jtm@smoothsmoothie.com> | Joel Sherrill | 2 | -0/+10 | |
* irq/irq_asm.S: Add FIQ support. | |||||
2002-10-02 | 2002-10-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -1418/+4 | |
* rtems-stub-glue.c: Removed should only be common copy. | |||||
2002-09-14 | 2002-09-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -0/+7 | |
* cpu.c: Include declaration of variable i in ifdef USE_SPRG to eliminate warning. | |||||
2002-09-14 | 2002-09-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -0/+9 | |
* clock/clock.c: Per PR257, remove reference to c3x_set_ie. c4x variant should use c4x_set_iie(). | |||||
2002-09-14 | 2002-09-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 10 | -5/+30 | |
* startup/bspstart.c: As part of fixing PR281 on gensh4, a review of all calls to bsp_libc_init() resulted in some cleanup here. | |||||
2002-09-14 | 2002-09-14 Ivan Guzvinec <ivang@opencores.org> | Joel Sherrill | 4 | -4/+12 | |
* include/bsp.h, startup/Makefile.am, startup/bspclean.c: Cleanup so the BSP works. |
