significant things:
and PowerPC
same code base.
something indicates this. Eventually this needs to be merged into
gcc.
location in libc.
to do polled IO on a single port with VERY little support code.
by gdb 5.0's i960 simulator) is enough to run hello world.
Gauthier <charles.gauthier@nrc.ca>. The power supply in their
VMEbus cage died so it was submitted at this point. It passes ttcp
which is a really good sign but they would like to do more testing
and cleanup once their hardware is functional again. Please
contact them if you are interested in using or fixing this driver.
As their comments indicate, the performance is actually quite good
even at this point as indicated by the ttcp results.
Please note that this is by no means a final version. The code is still
fairly ugly, and will require some further fixing. On the bright side, what
is attached works. I finally ran the test programs successfully with
optimized code and data cache enabled:
netdemos worked, but failed on the UDP transfer (runs out of buffers).
ttcp worked, with something like 1036 KB/sec Rx, 952 KB/sec Tx.
tftp worked
linkcmds updated, simio references removed, and switch to libchip for
serial ports from simio.
Added a MEMORY_MAP file to capture information about the various
addresses on this board.
In addition, many of the beta patches are now included.
Bob Wisdon <bobwis@ascweb.co.uk> and Chris Johns <ccj@acm.org>
to resolve a random network lockup problem.
ckinit.c:
Occasional network lockups have been noted when the PIT has a higher
interrupt request level than the CPM. The SCC1 bit in the CISR is set
even though the SCC1 interrupt handler is not active. This blocks
interrupts from SCC1 (and all other CPM sources) and locks up the
system. It has not been determined whether the error is within the
68360 or in the RTEMS interrupt support assembler code. The solution,
for now, is to set both PIT and CPM interrupt request levels to the same
value (4).
network.c:
Set CPM transmitter buffer pointer (_tbptr) to beginning of frame
before restarting transmitter. Don't retire transmitter buffer
descriptors belonging to the restarted frame.
that contains:
* Removes MKLIB
handling)
when setting up receive buffer descriptors and when unmasking interrupts.
./bootstrap
that contains:
The workarounds related to the issues with
ppc/helas403 (triggers a nasty bug in automake-2.14) and mcp750.cfg
(Which is basically broken)
patch -p1 < rtems-rc-20000118-6.diff
./bootstrap
Note:
* Though this patch is small, ./bootstrap is absolutely necessary.
* Now your CVS source tree is identical to my local CVS.
that contains:
* The fix for the gen68360/network/Makefile.am
* automatically set permissions to 755 to scripts/buildall and
scripts-ada/buildall (I remembered a trick to achieve this :).
* automake support for libbsp/* and libcpu/* (Attn: This part will
finally break old-style configuration for all non-public cpus)
NOTES:
* This patch has only been tested for a random selection of BSPs (I
haven't rebuilt all toolchains yet).
* This patch is against rtem-cvs as of this morning (MET).
patch -p1 <rtems-rc-20000118-5.diff
cvs rm -f ./c/src/lib/libbsp/Makefile.in
cvs rm -f ./c/src/lib/libbsp/shmdr/Makefile.in
cvs rm -f ./c/src/lib/libcpu/Makefile.in
cvs add ./c/src/lib/libbsp/Makefile.am
cvs add ./c/src/lib/libbsp/shmdr/Makefile.am
cvs add ./c/src/lib/libcpu/Makefile.am
./bootstrap
converted to automake.
that should not have been.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
to make the BSP boot on netboot.
BSP alias on the tools.
information on hardware settings.
that converts the a29k to automake.
This patch contains
* An initial merger of the libcpu/a29k stuff you sent yesterday. AFAIS,
most code inside them seems to be empty stubs. One file even contains a
function called mips_*** which might indicate that this part might
contain mips code or the code the initial porter used as template for
porting. Unfortunately, I don't know anything about the a29k so I can't
comment on the details.
* A dummy bsp_specs to libbsp/29k/portsw
* An update to the automake files related to the a29k.
Note:
* This patch is completely untested, because I don't have a toolchain
for it.
* The files in libcpu/a29k include bsp.h => The libbsp vs. libcpu-issue
hits again.
Some excellent sleuthing by Bob Wisdom <bobwis@ascweb.co.uk> revealed
that an empty mbuf at the end of a packet chain would cause the `retire'
function to blow up. Moving the line of code which bumps the transmit
buffer descriptor pointer fixes the problem. Some additional cleanup of
the sendpacket function was also completed.
because of the conversion to automake and replaced by a Makefile.am.
and memory layout. Next step is to share the same bsp_pretasking_hook.
that converts the libbsp/i386 subdirectory to full automake.
for the gen68360 that let it work with ELF and C++ exceptions. This
was used as the basis for changes to EVERY m68k bsp_specs and linkcmds.
Before this modification is over, the layout of the starting stack,
heap, and workspace will likely be modified for every m68k BSP. Then
they will all be very similar.
that fixes the following problems:
1. Removing bogus ';' in some configure.in (cosmetical fix)
2. Moves GAS_CODE16 checks to libbsp/i386/*/configure.in (essential fix)
#2 was responsible for the gcc/binutils-2.9.5 choking while building for
the pc386.
