* configure.ac: Add RTEMS_BSPOPTS_*(LOAD_RTC_AT_START),
RTEMS_BSPOPTS_*(BSP_DEBUG), RTEMS_BSPOPTS_*(UARTDEBUG),
remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* configure.ac: Add bspopts.h.
* include/.cvsignore: Add stamp-h* and bspopts.h*.
* include/Makefile.am: Add bspopts.h.
* pci/Makefile.am: Append -O2 to AM_CFLAGS.
* bootloader/Makefile.am: completely reworked.
* configure.ac: Add AM_PROG_AS.
* Makefile.am: Made to compile again.
* startup/linkcmds: Added _init, and _fini symbols.
* .cvsignore: New file.
process was captured as PR50.
* ppc403/console/console405.c ppc403/tty_drv/.cvsignore,
ppc403/tty_drv/Makefile.am, ppc403/tty_drv/tty_drv.c,
ppc403/tty_drv/tty_drv.h: New files.
* Makefile.am, README, configure.ac, old_exception_processing/cpu.c,
old_exception_processing/cpu.h, ppc403/Makefile.am,
ppc403/clock/clock.c, ppc403/console/Makefile.am,
ppc403/console/console.c, ppc403/ictrl/ictrl.c, ppc403/ictrl/ictrl.h,
ppc403/timer/timer.c: Modified.
* vectors/align_h.S: Added ppc405 support.
* startup/spurious.c: Added ppc405 support.
* include/bsp.h: Increase the interrupt stack size to 16K.
* ChangeLog, Makefile.am, README, bsp_specs, bsp_specs.dl, configure.ac,
times, dlentry/.cvsignore, dlentry/Makefile.am, dlentry/dlentry.S,
include/bspopts.h.in, include/coverhd.h, startup/.cvsignore,
startup/Makefile.am, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, startup/linkcmds.dl, startup/setvec.c,
wrapup/.cvsignore, wrapup/Makefile.am: New files that are
part of the new gen405 BSP.
This modification is a submission of the modifications necessary to
* acinclude.m4: Added gen405 BSP.
* ChangeLog: Removed bogus comment on edit of generated file.
* aclocal.m4: Added gen405 BSP.
This fix is in response to test results reported by Jerry Needell
<jerry.needell@unh.edu> for the SPARC/ERC32 and tracked as PR80.
* include/bsp.h: TM27 was not running properly because the ERC32
and LEON cannot nest interrupts at the same level. The BSP test support
had to be modified to support using two different interrupt sources.
* startup/Makefile.am: Do NOT use the standard bootcard.c.
NOTE: With this fix all test including the mptest ran as expected.
* start/start.S: Use __mcpu32__ instead of mcpu32 and change sense
of conditional so cpu32 does not attempt to use 68000 style
interrupt vectoring.
* network/Makefile.am: Fix improper use of $(srcdir) in VPATH.
* startup/linkcmds: Remove explicit force of output format.
* include/bsp.h: Modify Install_tm27_vector() so this BSP will link tm27.
* startup/linkcmds: Fix definition of .init and .fini sections so this
BSP will properly link with new __USE_INIT_FINI__ support.
* .cvsignore, include/.cvsignore: Add more entries.
* .cvsignore: Add more entries.
* New BSP for MCF5206eLITE evaluation board BSP.
* ChangeLog, README, bsp_specs, configure.ac, console/console.c,
console/.cvsignore, i2c/i2c.c, i2c/i2cdrv.c, i2c/.cvsignore,
include/bsp.h, include/bspopts.h.in, include/coverhd.h,
include/ds1307.h, include/i2c.h, include/i2cdrv.h, include/nvram.h,
include/.cvsignore, nvram/nvram.c, nvram/.cvsignore, start/start.S,
start/.cvsignore, startup/bspclean.c, startup/bspstart.c,
startup/gdbinit, startup/init5206e.c, startup/linkcmds,
startup/linkcmds.flash, startup/.cvsignore, times, tod/ds1307.c,
tod/todcfg.c, tod/.cvsignore, tools/.cvsignore, tools/configure.ac,
tools/runtest, tools/changes, wrapup/.cvsignore, .cvsignore:
New files.
* acinclude.m4: Added mcf5206elite.
New files.
* aclocal.m4: Removed. Should not have been in CVS.
* README, console/console.c, hw_init/hw_init.c, include/bsp.h,
startup/bspstart.c, startup/linkcmds: Minor fixes post merge.
* tools: New subdirectory.
* tools/Makefile.am, tools/runtest: New files.
* startup/linkcmds: Added _init and _fini.
* aclocal.m4: Regenerated.
* configure.ac, include/Makefile.am, irq/Makefile.am,
vectors/Makefile.am: Updated to autoconf 2.52.
* include/.cvsignore: Added newly generated files.
* include/bsp.h: Added include of bspopts.h.
* vectors/Makefile.am: Remove bogus VPATH.
* .cvsignore, configure.ac, configure.in, console/.cvsignore,
include/.cvsignore, network/.cvsignore, start/.cvsignore,
startup/.cvsignore, wrapup/.cvsignore: Added .cvsignore
files and other files missed in previous commit.
* mpc8260ads added as new BSP. tm27 reported not to run
at this time.
* ChangeLog, Makefile.am, README, aclocal.m4, bsp_specs,
clock/.cvsignore, clock/Makefile.am, clock/p_clock.c, configure.in,
console/Makefile.am, console/console.c, include/Makefile.am,
include/bsp.h, include/coverhd.h, irq/.cvsignore, irq/Makefile.am,
irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c,
network/Makefile.am, network/README, network/if_hdlcsubr.c,
network/if_hdlcsubr.h, network/network.c, start/Makefile.am,
start/start.S, startup/Makefile.am, startup/bspstart.c,
startup/cpuinit.c, startup/linkcmds, startup/setvec.c, times,
vectors/.cvsignore, vectors/Makefile.am, vectors/vectors.S,
vectors/vectors.h, vectors/vectors_init.c, wrapup/Makefile.am:
New files.
* acinclude.m4: Added mpc8260ads subdirectory.
* Makefile.am, README, configure.ac, new_exception_processing/cpu.h,
shared/include/cpu.h, shared/include/cpuIdent.c, shared/src/cache.c:
Added mpc8260 support.
* bootcard.c: Use __USE_INIT_FINI__ since USE_INIT_FINI
pollutes the application namespace.
* timerstub.c: New stub file for BSPs that don't have timer hardware.
* timer: New subdirectory.
* timer/Makefile.am: New file.
* timer/.cvsignore: New file.
* Makefile.am: Modified to reflect above.
* configure.ac: Ditto.
* include/bsp.h: Stubs to let tm27 compile and link.
* wrapup/Makefile.am: Ditto.
* include/zilog/Makefile.am: Remove.
* include/motorola/Makefile.am: Remove.
* include/sys/Makefile.am: Remove.
* include/Makefile.am: Handle subdirs, require automake-1.5
* startup/Makefile.am: Remove AC_CFLAGS, HZ.
* console/.cvsignore: New file.
* configure.ac: Added support for START_HW_INIT.
* console/Makefile.am: Removed VPATH.
* include/Makefile.am: Added missing ramdisk.h to include_HEADERS.
* startup/linkcmds: Do not force output format to coff-sh.
* startup/linkcmds-le: Comment out force of output format and add
comment questioning need to have special linkcmds for little endian.
* wrapup/Makefile.am: Add ramdisk to list of BSP_PIECES.
* acinclude.m4: Add gensh4 and simsh4.
* configure.ac: Remove AC_SUBST(CPU_CLOCK_RATE_HZ), add
START_HW_INIT-support macros, add console/Makefile.
* Makefile.am: Add console SUBDIR.
* hw_init/Makefile.am: Fix C_FILES, remove AM_CPPFLAGS/HZ.
* include/bsp.h: Comment out SH4_CPU_HZ_Frequency.
* startup/bspstart.c: Comment out SH4_CPU_HZ_Frequency.
* startup/linkcmds: Comment out OUTPUT_FORMAT for coff
compatibility.
* wrapup/Makefile.am: Add console to BSP_PIECES.
* console/Makefile.am: New.
* console/console.c: Moved from libcpu/sh/sh7750/sci/console.c.
* start/start.S: Fixed typo.
* clock/p_clock.c, startup/bspstart.c: Fixed typo.
* console/inch.c: Fixed typo.
