* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* configure.ac: Add BSP_BOOTCARD_OPTIONS.
* configure.ac, clock/clockdrv.c, startup/bspreset.c: Adjust clock
initialization for clock tick so rtmonuse test now runs on Skyeye.
Joel added configure magic and place holder in bspreset.c for Skyeye
hardware reset device support.
* Makefile.am: Fix typo.
* Makefile.am: Complete update to current style.
* README.IceCube: Correct mkimage addresses.
* setvec.c: Add CVS Id.
* start/start.S: copied gcrt1.S and macros.inc from avr-libc.
Change from call main to call boot_card for RTEMS.
* start/macros.inc: New file.
* shared/irq/irq.h, shared/irq/irq.c, shared/irq/irq_init.c: Converted
to use generic interrupt support.
* shared/irq/irq-config.h: New file.
* Makefile.am, preinstall.am: Update for generic interrupt support.
* Makefile.am: Switch to shared routine.
* startup/setvec.c: Removed.
* Makefile.am: Eliminate unused routine.
* Makefile.am: Update to current style.
* bsp_specs: Fix warning for _start.
* start/start.S: Proper attribution for origin.
* startup/bspstart.c: Add Skyeye bsp_reset() on Skyeye.
* include/.cvsignore: New file.
* include/bspopts.h.in: Removed.
* umon/umonrtemsglue.c: Add console device that uses MicroMonitor to do
actual input and output. This driver should work on any board that
uses MicroMonitor.
* umon/umoncons.c: New file.
* Makefile.am, configure.ac, console/uarts.c: Add console device that
uses MicroMonitor to do actual input and output. This driver should
work on any board that uses MicroMonitor.
* startup/linkcmds, startup/linkcmds.csb637: Move .init section from
the front of the executable so the start label has the first
instruction in the executable.
* console/ps2_mouse.c: Fix inconsistent spacing.
* vmeUniverse/vmeUniverse.c, vmeUniverse/vmeTsi148.c:
include <rtems/pci.h> instead of <bsp/pci.h>.
* umon/umonrtemsglue.c: Add flag to ensure that it umon connection is
initialized twice, it is safe.
* umon/monlib.h: Add umon.h to be installed as <rtems/umon.h> so umon
.h files are modified as little as possible.
* umon/umon.h: New file.
* Makefile.am, preinstall.am: Make an RTEMS specific umon.h wrapper
include file.
* Makefile.am: Re-add basic console code.
* Makefile.am: Add MicroMonitor support.
* Makefile.am, preinstall.am: Add MicroMonitor support.
* startup/umonsupp.c: New file.
* umon/README, umon/cli.h, umon/monlib.c, umon/monlib.h, umon/tfs.h,
umon/tfsDriver.c, umon/umonrtemsglue.c: New files.
* ide/ide.c: Format the data output in DEBUG mode.
* Makefile.am: Compile the shared bspinit.c.
* network/network.c: Attempt to support csb637 PHY.
* startup/linkcmds: Fix spacing.
* network/tsec.c, network/if_tsec_pub.h:
implemented multicast support.
* configure.ac, include/bspopts.h.in: Add ON_SKYEYE option to at least
enable fast idle mode. Also added some standard BSP options.
* startup/bspstart.c: Eliminate unused variables.
* acinclude.m4: New Gumstix BSP.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, console/uarts.c, include/bsp.h, include/bspopts.h.in,
include/tm27.h, start/start.S, startup/bspstart.c, startup/linkcmds,
startup/memmap.c: New files.
* Makefile.am, configure.ac, preinstall.am, console/uarts.c,
include/bsp.h, startup/memmap.c: Add support for /dev/fbcons which is
a console type output only device to print to the LCD screen. The
video controller (SED) and fonts are copied from MicroMonitor and
proper attribution is made in those files and confirmed by Ed Sutter.
* console/fbcons.c, console/font8x16.h, console/sed1356.c,
console/sed1356_16bit.h, include/sed1356.h: New files.
* Makefile.am: Fix breakage having been introduced in previous patch.
* ide/ide.c: Add initialisation code to reset the IDE devices and
to probe them and display their model numbers. Also add code to
display the probing to aid bring up new hardware.
* ide/idecfg.c: Add the --ide-show command to show probing type
accessing when finding devices on the configured IDE buses.
* Makefile.am, preinstall.am: Install tty_drv.h
* start/start.S: Correct call to boot_card to meet bfin abi by
clearing l0 - l3 and allocating some stack space.
* Makefile.am, README, configure.ac, preinstall.am, start/start.S,
startup/memmap.c: Add csb637 as alias and variant.
* startup/linkcmds.csb637: New file.
* shared/start/start.S: Export crt0 symbol because the debug.S uses
that.
* tod.h, tod.c: Update for new RTC driver interface.
PR 1415/bsps
* startup/bspstart.c, startup/linkcmds: Enable caches and therefore
enable the mmu.
* Makefile.am: Remove junk bsp_reset().
* startup/bspreset.c: Removed.
