1999-11-19 | Renaming all BSP specific startXXX directories to use the same name (start). | Joel Sherrill | 25 | -44/+44 | |
1999-11-19 | Renaming all BSP specific startXXX directories to use the same name (start). | Joel Sherrill | 17 | -4067/+0 | |
1999-11-19 | Moved startsis to start. | Joel Sherrill | 5 | -409/+6 | |
1999-11-18 | Patch from "John M. Mills" <jmills@tga.com> with subsequent cleanup from | Joel Sherrill | 26 | -58/+2265 | |
Ralf Corsepius <corsepiu@faw.uni-ulm.de> that adds initial Hitachi SH-2 support to RTEMS. Ralf's comments are: Changes: ------ 1. SH-Port: * Many files renamed. * CONSOLE_DEVNAME and MHZ defines removed from libcpu. * console.c moved to libbsp/sh/shared, build in libbsp/sh/<BSP>/console applying VPATH. * CONSOLE_DEVNAME made BSP-specific, replacement is defined in bsp.h * MHZ define replaced with HZ (extendent resolution) in custom/*.cfg * -DHZ=HZ used in bspstart.c, only * Makefile variable HZ used in bsp-dependent directories only. 2. SH1-Port * clock-driver rewritten to provide better resolution for odd CPU frequencies. This driver is only partially tested on hardware, ie. sightly experimental, but I don't expect severe problems with it. * Polling SCI-driver added. This driver is experimental and completly untested yet. Therefore it is not yet used for the console (/dev/console is still pointing to /dev/null, cf. gensh1/bsp.h). * minor changes to the timer driver * SH1 specific delay()/CPU_delay() now is implemented as a function 3. SH2-Port * Merged * IMO, the code is still in its infancy. Therefore I have interspersed comments (FIXME) it for items which I think John should look after. * sci and console drivers partially rewritten and extended (John, I hope you don't mind). * Copyright notices are not yet adapted | |||||
1999-11-17 | Updated copyright notice. | Joel Sherrill | 311 | -620/+311 | |
1999-11-17 | Now allows override of base address via -Ttext command to linker. | Joel Sherrill | 1 | -39/+47 | |
1999-11-17 | New file documenting the on board monitor (PPCBUG) configuration used | Joel Sherrill | 2 | -0/+156 | |
to be able to boot the archives located in powerpc-rtems/c/mcp750/bin. This information was provided by Eric Valette <valette@crf.canon.fr> | |||||
1999-11-16 | Fixed alignment problem on _endtext. | Joel Sherrill | 1 | -0/+1 | |
1999-11-16 | Moved start code from lib/start to libbsp. | Joel Sherrill | 14 | -7/+462 | |
1999-11-16 | Moved start code from lib/start to libbsp. | Joel Sherrill | 5 | -24/+22 | |
1999-11-16 | Minor changes since new Makefile. | Joel Sherrill | 1 | -4/+5 | |
1999-11-16 | Added start subdirectory. | Joel Sherrill | 1 | -1/+1 | |
1999-11-09 | This patch adds the basic framework for the ITRON 3.0 API implementation | Joel Sherrill | 1 | -14/+2 | |
for RTEMS. | |||||
1999-11-09 | Removed. | Joel Sherrill | 5 | -298/+0 | |
1999-11-09 | Now using libchip instead of local precursor to libchip. Untested. | Joel Sherrill | 10 | -2274/+86 | |
1999-11-05 | Patch from Eric Valette <valette@crf.canon.fr> so this will build | Joel Sherrill | 6 | -444/+80 | |
independently of a BSP. | |||||
1999-11-04 | The files in libcpu should not be directly dependent on any BSP. In | Joel Sherrill | 11 | -8/+607 | |
particular, using bsp.h, or getting information from the BSP which should properly be obtained from RTEMS is forbidden. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The changes primarily eliminated the need to include bsp.h and peeking at BSP_Configuration. The use of Cpu_table in each BSP needs to be eliminated. | |||||
1999-11-03 | Typo fixed by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1 | -1/+1 | |
1999-11-02 | Split console_reserve_resources into its own file to reduce dependencies. | Joel Sherrill | 3 | -10/+30 | |
Still need to move debug io routines out. | |||||
1999-11-01 | Removed all references to shared memory driver as it is not supported | Joel Sherrill | 1 | -5/+0 | |
yet on the mvme2307. | |||||
1999-11-01 | Removed shmsupp directory as it is not really implemented. | Joel Sherrill | 1 | -6/+1 | |
1999-11-01 | MVME2307 does not really include MP support. | Joel Sherrill | 5 | -311/+0 | |
1999-10-28 | Patch rtems-rc-19991011-3.diff from Ralf Corsepius. | Joel Sherrill | 2 | -2/+33 | |
1999-10-28 | Notes on what to do when merging a BSP. | Joel Sherrill | 1 | -0/+73 | |
1999-10-27 | Patch from Aleksey (Quality Quorum <qqi@world.std.com>) to | Joel Sherrill | 2 | -19/+36 | |
increase ease of application configuration of the pc386 BSP. This patch allows switching the printk console to a serial port and overriding bsp_start by making it a weak alias. | |||||
1999-10-27 | Added $(EXEEXT) in attempt to help Cygwin install process. | Joel Sherrill | 1 | -2/+2 | |
1999-10-27 | Last cleanup to attempt to link. | Joel Sherrill | 2 | -1/+3 | |
1999-10-27 | rxgen960 now compiles -- may not link. | Joel Sherrill | 11 | -42/+32 | |
1999-10-27 | Added CVS Ids and a basic header. More header cleanup needed. | Joel Sherrill | 42 | -9/+174 | |
1999-10-27 | Removed systbl.S save_systbl.c. They were unnecessary. | Joel Sherrill | 3 | -523/+2 | |
1999-10-27 | Removed sctns.S. This file was obviously the output of the compiler. | Joel Sherrill | 2 | -336/+1 | |
1999-10-27 | Replaced Makefile.in's with modified copies of cvme961 to get | Joel Sherrill | 9 | -152/+242 | |
autoconf/automake changes. | |||||
1999-10-27 | Moved timerisr.s to timerisr.S per GNU conventions. | Joel Sherrill | 1 | -0/+0 | |
1999-10-27 | Moved systbl.s to systbl.S per GNU conventions. | Joel Sherrill | 1 | -0/+0 | |
1999-10-27 | Moved sctns.s to sctns.S per GNU conventions. | Joel Sherrill | 1 | -0/+0 | |
1999-10-27 | Moved rxgen_romld.s to rxgen_romld.S per GNU conventions. | Joel Sherrill | 1 | -0/+0 | |
1999-10-27 | Moved ihandler.s to ihandler.S per GNU conventions. | Joel Sherrill | 1 | -0/+0 | |
1999-10-27 | Moved asmstub.s to asmstub.S per GNU conventions. | Joel Sherrill | 1 | -0/+0 | |
1999-10-27 | Moved asmfault.s to asmfault.S per GNU conventions. | Joel Sherrill | 1 | -0/+0 | |
1999-10-27 | The rxgen960 BSP and i960 RPM support was submitted by Mark Bronson | Joel Sherrill | 71 | -0/+6584 | |
<mark@ramix.com> of RAMIX. | |||||
1999-10-26 | Split console_reserve_resources to separate file to reduce | Joel Sherrill | 3 | -7/+42 | |
code size. | |||||
1999-10-26 | Patch from Emmanuel Raguet <raguet@crf.canon.fr> to fix a small bug where | Joel Sherrill | 1 | -1/+1 | |
the receive buffer size was 16 bytes too small. | |||||
1999-10-26 | Modifications from Erik Ivanenko <erik.ivanenko@utoronto.ca> to add | Joel Sherrill | 2 | -5/+17 | |
proper Multiboot signature to pc386 BSP. This enables Grub to recognize the image. | |||||
1999-10-26 | Patch from Erik Ivanenko <erik.ivanenko@utoronto.ca> to fix some | Joel Sherrill | 1 | -28/+68 | |
reported bugs in the start code. | |||||
1999-10-25 | tch from Eric Valette <valette@crf.canon.fr> and Emmanuel Raguet | Joel Sherrill | 2 | -72/+72 | |
<raguet@crf.canon.fr> to fix bugs and make the mcp750 boot RTEMS running the GoAhead web server. | |||||
1999-10-25 | Modified to produce correct output with new version of sis. | Joel Sherrill | 1 | -1/+6 | |
1999-10-11 | Now compiles for coff and elf. | Joel Sherrill | 1 | -65/+185 | |
1999-10-06 | Removed aclocal.m4 generated from aclocal macros | Joel Sherrill | 8 | -2910/+0 | |
1999-10-06 | Removed configure generated from configure.in | Joel Sherrill | 8 | -13321/+0 | |
1999-10-06 | Modified to avoid conflicts on definitions of malloc. newlib 1.8.2 | Joel Sherrill | 1 | -1/+1 | |
now prototypes the malloc family in stdlib.h. This causes conflicts with the way the network stack overrides the definitions of malloc. As best I (being Joel) can tell, commenting stdlib.h out keeps the files compiling and referencing the desired malloc/free but results in more warnings. |
