work with m68k-elf on late model versions of binutils (990901+)
without overlapping or missing section errors.
version of binutils.
conditional that should have been fixed long ago.
gnu.linkonce* sections are included.
and not likely to become so. Comments on each configuration
are below.
+ Force CPU386 - This BSP was developed as part of the initial
port of RTEMS to the i386. This board has been unavailable
for a long time now.
+ GO32 - This BSP and some CPU code supported djgpp v1.x. This
version is now quite old. No one has stepped forward to
update the code to v2.x which may be technically impossible
anyway. More importantly, go32 has been superceded by the pc386 BSP.
fixes related to GDB over TCP/IP debug.
No modifications made.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
initialization is only done once.
in getenv/putenv working all the time without special assistance
from the BSP.
<eric@cls.usask.ca>.
added.
Somehow a nasty bug has made it in sh/start.S ("|", instead of "!", to
begin an asm comment).
I have no idea how this could remain undiscovered for so long (It is in
rtems-4.0.0, too!), however upgrading to binutils from sourceware's CVS
sh-rtems-as chokes on this bug. => I guess, either binutils changed its
conventions or an obvious bug in as has been fixed.
configuration and unix/posix:
c/src/lib/libc/Makefile.in
only (was completely broken).
Linux-posix.cfg.
of other bsp's/CPU.
cd <srcdir>
and
cd c/src/lib; autoconf
or
I'm attaching a big patch for the ts_386ex BSP which adds and includes
the following:
1) Conversion to ELF format + minor code cleanups + documentation.
2) An Ada95 binding to FreeBSD sockets, based on Samuel Tardieu's
adasockets-0.1.3 package. This includes some sample applications.
3) Some Ada and C interfaces to add serial-port debugging to
programs. Comes with examples, too; the Ada one shows how
transparent adding the support can be. Note that Rosimildo sent me
the original C code.
The network stuff is not BSP specific, and could be added to your Ada
code collection. The debugging stuff is specific to the i386. Right
now, everything sits in my "tools" directory.
<raguet@crf.canon.fr>:
- the dec21140 driver code has been hardened (various bug fixed) Emmanuel,
- bug in the mcp750 init code have been fixed (interrupt stack/initial
stack initialization), BSS correctly cleared (Eric V)
- remote debugging over TCP/IP is nearly complete (berakpoints,
backtrace, variables,...) (Eric V),
- exception handling code has also been improved in order to fully
support RDBG requirements (Eric V),
I just released erc32ccs-2.0.6 which includes some fixes and the
Ada-self optimisation. Remote debugging of Ada programs did not
work due to a conflict between monior and rtems trap handlers.
I have attached a modified gnatsupp.c that makes remote debugging
possible again.
initialization typo and make i8259s_cache only accessed from C.
to fix problem reported by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
Date: Fri, 30 Jul 1999 14:53:20 -0500 (CDT)
it is used like this in i386ex/start/start.S
/* set up same values in cache */
start.S: movw $0xFFFB, SYM(i8259s_cache)
I am heading out the door. Any other ideas what could have tripped this?
This instruction appears in a .code16 section. In a .code16 section,
current versions of gas assume that all addresses are 16 bits unless
told otherwise.
If you change the line to
addr32 movw $0xFFFB, SYM(i8259s_cache)
then you will get a 32 bit address reference.
You may want to use addr32 only when NEW_GAS is defined.
cd <srcdir>
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
This file is necessary because the bootloader is compiled with different
options than the basic C library.
to address m68k-rtemself for the MVME167.
Here is the rtems patch I promissed you a long time ago to enable ELF
with m68k. The target name I selected is m68k-rtemself. It preserves the
m68k-rtems COFF target, and is parterned after the other ELF/COFF dual
targets.
The mvme167.cfg file causes the -qelf flag to be used during compilation
if the name of the compiler contains rtemself. This flag is used in the
bsp_specs file to select the elflinkcmds file rather than the linkcmds
file. The former is for ELF, the latter for COFF.
Some patches are required to the mc68040 FPSP code. Some of the
assembler files contain instructions that were rejected by the
m68k-rtemself-as assembler. This is a minor bug in the m68k ELF
assembler, I think.
from Jay Kulpinski <jskulpin@eng01.gdds.com>.
bug report from David Decotigny <David.Decotigny@irisa.fr>:
During the last few days, I've been back working on RTEMS. Let me
remind you that RTEMS didn't boot on our (old) Dell P90 machines (ref:
PC 590) : we could only get a reboot out of them.
1/ The symptoms
Hopefully, the problem was rather deterministic. The stack couldn't be
written correctly : issueing one or more "push" would always push '0'
onto the stack. The way to solve this was to issue a "pop", such as
"pushl eax ; popl eax". After this "pop", the stack would be writeable
again.
BUT, it will be writable for 8 consecutive "push"s. After these 8
"push"s, the other "push"s are wrong again, and a blank push/pop is
needed.
Considering that the L1 cache lines of this pentium are 32 bytes long,
and that 8 long int are 32 bytes long too, it came to us that there
was a problem with the cache.
Actually, the bug of the push could be shown through memory accesses
directly : writing on an not-in-cache mem location would put 0 until
this mem location is accessed through a single "read". Then, the whole
cache line would be right again.
2/ The consequences
Of course, that was the first thing that we've been able to observe ;)
RTEMS could not boot. Actually, when a "call" pushed 0 onto the stack,
the ret could only lead to raise an exception a bit later. Since, in
the early stage, the Interrupt vector points to 0, averything couldn't
get worse : triple fault + reboot.
3/ Explanation
This cache mechanism corruption only appeared after load_segment()
returned (through a jump). Investigating a bit further shows that this
appears /sometimes/ during the PICs initialization.
"Sometimes" proved to be "When writing something with the 4th bit of
%al set". That is "when writing 0x28 or 0xff" for example. Clearing
this bit would just make the things work right.
Actually, this isn't a bug in the proper PIC initialization (which is
quite academic). It came from the "delay" routine, which theoretically
does nothing but writing to an "inexistant" port (0xed), in order to
lose some time.
BUT, in the special case of our Dell P90, it appears that this 0xed
port does something cruel with the cache mechanism when its 4th bit
(aka bit 3 or 0x8) is set.
I didn't investigate this non-standard behaviour of the P90 any
further : I don't know if this is documented, or if it is just another
(known ?) bug of the early Pentiums. Just notice that we have 5 such
machines, and it has the same effect on the cache mechanism.
CHANGES:
c/Makefile.am removed
still in - remove it?)
(Cygwin support)
REMARK:
inside the build-tree.
APPLYING THE PATCH
autogen
