* configure.ac, include/bspopts.h.in: Make letting boot_card() handle
work area allocation mandatory. Rename
RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to BSP_BOOTCARD_OPTIONS.
* Makefile.am, configure.ac: Make letting boot_card() handle work area
* Makefile.am, start/start.S: bsp_cleanup() had the same code which was
executed when you returned from boot_card() to start.S. So just use
the stub bsp_cleanup() implementation and remove a file.
* startup/bspclean.c: Removed.
* Makefile.am, configure.ac, include/bsp.h, startup/bspstart.c: Rename
existing bsp_reset() to bsp_sysReset() since the prototype did not
match the standard one. Add standard bsp_reset().
* startup/bspreset.c: New file.
* Makefile.am: BSP specific bsp_cleanup() is a dupe of a shared one.
* Makefile.am, configure.ac: BSP specific bsp_cleanup() is a dupe of a
shared one.
* start/start.S: bsp_cleanup() had the same code which was executed
when you returned from boot_card() to start.S. So just use the stub
* Makefile.am: bsp_cleanup() had the same code which was executed when
* shared/bspclean.c: Removed.
* README: Add URL.
* acinclude.m4: New BSP -- lpc24xx.
* include/utility.h: New file.
* Makefile.am, preinstall.am, include/lpc24xx.h, misc/system-clocks.c:
Move utility.h
* bspclean.c, include/bootcard.h: Use standardized bsp_cleanup() which
can optionally print a message, poll for user to press key, and call
bsp_reset(). Using this eliminates the various bsp_cleanup()
implementations which had their own implementation and variety of
string constants.
* bspreset.c, bspreset_fatal.c, bspreset_loop.c: New files.
* Makefile.am, configure.ac: Use standardized bsp_cleanup() which can
string constants.
* shared/console/inch.c, shared/startup/panic.c: Use standardized
bsp_cleanup() which can optionally print a message, poll for user to
press key, and call bsp_reset(). Using this eliminates the various
bsp_cleanup() implementations which had their own implementation and
variety of string constants.
* shared/console/bspreset.c: New file.
* shared/console/reboot.c: Removed.
* Makefile.am, configure.ac, include/bspopts.h.in: Use standardized
* Makefile.am, README.booting, include/bsp.h, startup/bspclean.c,
vectors/exceptionhandler.c: Use standardized bsp_cleanup() which can
string constants.
* startup/reboot.c: Removed.
* include/bsp.h, startup/misc.c: Use standardized bsp_cleanup() which
string constants.
* Makefile.am, include/bsp.h: Use standardized bsp_cleanup() which can
string constants.
* Makefile.am, console/console.c, include/bsp.h: Use standardized
* Makefile.am, configure.ac, console/console.c, include/bsp.h,
startup/bspstart.c: Use standardized bsp_cleanup() which can
string constants.
* include/bsp.h: Use standardized bsp_cleanup() which can optionally
print a message, poll for user to press key, and call bsp_reset().
Using this eliminates the various bsp_cleanup() implementations which
had their own implementation and variety of string constants.
* Makefile.am, configure.ac, console/console-io.c: Use standardized
* Makefile.am, configure.ac, console/inch.c, console/keyboard.c,
* acinclude.m4, shared/comm/console.c: Use standardized bsp_cleanup()
which can optionally print a message, poll for user to press key, and
call bsp_reset(). Using this eliminates the various bsp_cleanup()
string constants.
* Makefile.am, configure.ac, console/uart.c, startup/bspstart.c: Use
standardized bsp_cleanup() which can optionally print a message, poll
for user to press key, and call bsp_reset(). Using this eliminates
the various bsp_cleanup() implementations which had their own
* Makefile.am, startup/bspstart.c: Use standardized bsp_cleanup() which
string constants.
* Makefile.am, configure.ac, console/console.c: Use standardized
* Makefile.am, configure.ac, console/uart.c: Use standardized
* Makefile.am, configure.ac, startup/bspstart.c: Use standardized
* Makefile.am, configure.ac, console/uart.c, startup/bspclean.c,
string constants.
* include/bsp.h, network/network.c: Fix missed name change.
* .cvsignore, include/bspopts.h.in: New files.
unsigned integer literal
shared/startup/linkcmds.base, shared/include/linker-symbols.h, shared/include/start.h, shared/start/start.S: New files.
* bspgetworkarea.c: Fix typo. Add debug printk statements.
* startup/linkcmds: Move WorkAreaBase to be closer to end definition.
* include/bsp.h: Remove define of BSP_ZERO_WORKSPACE_AUTOMATICALLY.
* startup/linkcmds: Add WorkAreaBase.
* bspgetworkarea.c: Augment to optionally know U-Boot.
