* | 2008-09-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-05 | 2 | -0/+8 |
| | | | | * timer/timer.c: Convert to "bool". | ||||
* | 2008-09-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-05 | 1 | -0/+1 |
| | | | | * console/console.c: Remove bogus decl. | ||||
* | Remove bogus decl. | Ralf Corsepius | 2008-09-05 | 1 | -1/+0 |
* | Convert to "bool". | Ralf Corsepius | 2008-09-05 | 2 | -8/+8 |
* | 2008-09-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-05 | 1 | -0/+4 |
* | Convert to "bool". | Ralf Corsepius | 2008-09-05 | 1 | -5/+5 |
* | Convert to "bool". | Ralf Corsepius | 2008-09-05 | 5 | -26/+26 |
| | | | | * console/console.c, timer/timer.c: Convert to "bool". | ||||
| | | | | * console/console-io.c: Convert to "bool". | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-05 | 1 | -2/+2 |
* | Convert to "bool". | Ralf Corsepius | 2008-09-05 | 5 | -13/+13 |
| | | | | * console/console.c: Convert to "bool". | ||||
* | 2008-09-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-05 | 3 | -0/+12 |
* | Convert to "bool". | Ralf Corsepius | 2008-09-05 | 2 | -3/+3 |
* | Fix broken entry. | Ralf Corsepius | 2008-09-05 | 1 | -1/+1 |
* | 2008-09-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-05 | 1 | -0/+4 |
| | | | | * block/block.c, rtc/rtc.c: Convert to "bool". | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-05 | 2 | -4/+4 |
| | | | | * gba/startup/cpu.c, gba/timer/timer.c: Convert to "bool". | ||||
* | 2008-09-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-05 | 2 | -1/+5 |
| | | | | * timer/timer.c: Use "true" instead of "1" for "bool"s. | ||||
* | 2008-09-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-03 | 2 | -1/+6 |
| | | | | * tod.c: Remove extern. RTC_Present is not defined anywhere. | ||||
* | 2008-09-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-03 | 6 | -9/+21 |
| | | | | * timer/timer.c: Convert using "bool". | ||||
* | 2008-09-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-03 | 19 | -78/+389 |
| | | | | | | | | | * Makefile.am, README, configure.ac, console/85c30.c, console/console.c, console/consolebsp.h, include/bsp.h, include/gen2.h, irq/FPGA.c, irq/irq.c, irq/irq.h, irq/irq_init.c, start/start.S, startup/bspstart.c, startup/genpvec.c, startup/linkcmds, timer/timer.c, tod/tod.c: Initiate update and testing. Runs hello but does not run ticker yet. | ||||
* | 2008-09-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-03 | 17 | -64/+1939 |
| | | | | | | | | | * Makefile.am, configure.ac, console/alloc360.c, console/console.c, console/console.h, console/m68360.h, console/mc68360_scc.c, console/ns16550cfg.c, console/rsPMCQ1.c, console/rsPMCQ1.h, include/bsp.h, irq/irq_init.c, vme/VMEConfig.h: Initiate update and testing. Add missing files. Does not run hello yet. * console/debugio.c, console/polled_io.c, irq/openpic_xxx_irq.c: New files. | ||||
| | | | | | PR 1304/bsps * Makefile.am: Add ../../shared/bsppredriverhook.c. | ||||
* | 2008-09-03 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-03 | 13 | -456/+478 |
| | | | | | | | | | | | * Makefile.am, configure.ac: Rework psim scripts to share code for creating device trees and actually running the tests. Overhaul the device tree generated to always include a block of Flash and a Real-Time Clock. When running MP tests enable the shared memory and semaphore devices. * psim-bottom, psim-gdb-bottom, psim-gdb-top.in, psim-shared, psim-top.in, runtest-bottom, runtest-top.in: New files. * psim, psim-gdb, runtest: Removed. | ||||
* | 2008-09-03 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-03 | 4 | -9/+12 |
| | | | | | | | * Makefile.am, bestcomm/load_task.c, bestcomm/task_api/tasksetup_general.h: Eliminate requirement to build bestcomm as a relocatable lump. This should reduce the minimum footprint considerably. | ||||
* | update to current PPC exception and memory map structure | Thomas Doerfler | 2008-09-03 | 15 | -1589/+1290 |
* | Changed to include new file | Thomas Doerfler | 2008-09-03 | 4 | -1359/+44 |
| | | | | startup/linkcmds.base. Supports small data area now. | ||||
* | Converted to use shared | Thomas Doerfler | 2008-09-03 | 15 | -855/+677 |
| | | | | exception and interrupt code. | ||||
* | Moved general MSCAN functions into | Thomas Doerfler | 2008-09-03 | 2 | -989/+538 |
| | | | | | separate header and source files (include/mscan-base.h and mscan/mscan-base.c). Formatted code. | ||||
* | 2008-09-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-02 | 1 | -0/+6 |
| | | | | | | PR 1302/bsps * vmeUniverse/vmeUniverse.h: Remove _VME_UNIVERSE_DECLARE_SHOW_ROUTINES. | ||||
* | PR 1302/bsps | Ralf Corsepius | 2008-09-02 | 1 | -14/+0 |
* | Eliminate rtems_boolean. | Ralf Corsepius | 2008-09-02 | 1 | -1/+1 |
* | 2008-09-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-02 | 1 | -0/+5 |
| | | | | | * clock/rtc.c, console/inch.c, ne2000/ne2000.c, timer/timer.c: Eliminate rtems_boolean. | ||||
* | Eliminate rtems_boolean. | Ralf Corsepius | 2008-09-02 | 4 | -27/+27 |
* | 2008-09-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-02 | 1 | -0/+4 |
| | | | | * clock/rtc.c, network/ne2000.c: Eliminate rtems_boolean. | ||||
* | Eliminate rtems_boolean. | Ralf Corsepius | 2008-09-02 | 2 | -4/+4 |
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 2 | -11/+11 |
| | | | | | * timerstub.c: Eliminate empty function from every benchmark timer driver. Fix spelling. | ||||
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 3 | -20/+15 |
| | | | | | * timer/timer.c, timer/timerisr.c: Eliminate empty function from every benchmark timer driver. Fix spelling. | ||||
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 44 | -328/+259 |
| | | | | | * timer/timer.c: Eliminate empty function from every benchmark timer driver. Fix spelling. | ||||
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 9 | -60/+42 |
| | | | | | * timer/timer.c, timer/timerisr.S: Eliminate empty function from every benchmark timer driver. Fix spelling. | ||||
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 4 | -24/+15 |
| | | | | | * console/console.c, include/m340timer.h, timer/timer.c: Eliminate empty function from every benchmark timer driver. Fix spelling. | ||||
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 8 | -53/+53 |
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 2 | -11/+10 |
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 4 | -45/+31 |
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 12 | -53/+83 |
| | | | | | * timer/timer.c: Rename timer driver methods to follow RTEMS programming conventions. | ||||
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 6 | -21/+31 |
| | | | | | * timer/timer.c, timer/timerisr.S: Rename timer driver methods to follow RTEMS programming conventions. |
