* | powerpc/mpc55xxevb: Move startup/reset.c to startup/bspreset.c | Chirayu Desai | 2013-11-23 | 2 | -1/+1 |
* | gumstix: Move bsp_reset() to gumstix/startup/bspreset.c | Daniel Ramirez | 2013-11-22 | 3 | -9/+21 |
* | select.h, rtems_select.c, nds select: Add restrict keyword | Daniel Ramirez | 2013-11-20 | 1 | -1/+2 |
* | sparc/../irq-shared.c: Fix compilation for SMP when not LEON3 | Joel Sherrill | 2013-11-14 | 1 | -1/+2 |
* | bsps/arm: Fix Cortex-A9 MPCore nanoseconds handler | Sebastian Huber | 2013-11-14 | 1 | -1/+1 |
* | bsp/realview-pbx-a9: Add Ethernet module memory | Sebastian Huber | 2013-11-13 | 1 | -0/+4 |
* | bsp/ngmp: New BSP variant | Sebastian Huber | 2013-11-13 | 4 | -0/+25 |
* | bsp/leon3: Enable linker script variants | Sebastian Huber | 2013-11-13 | 4 | -4/+11 |
* | bsp/leon3: Delete unused LEON_REG symbol | Sebastian Huber | 2013-11-13 | 1 | -7/+0 |
* | bsp/realview-pbx-a9: Add NULL pointer protection | Sebastian Huber | 2013-10-31 | 4 | -36/+13 |
| | | | | | Qemu Git version 8641136c54d216edb5bb8ef723c754039b4c5cf3 or later is required. | ||||
* | SPARC BSPs: disable interrupts as early as possible | Daniel Hellstrom | 2013-10-31 | 1 | -2/+2 |
| | | | | | | | | | There is no point having interrupts enabled before reaching boot_card() that disables interrupt. We better have it off all the time. It is required to turn off interrupt on secondary CPUs in an SMP system. | ||||
* | LEON3 SMP: remove compiler warning from __delay() declaration | Daniel Hellstrom | 2013-10-31 | 1 | -1/+1 |
* | LEON3 SMP: CPU ack irq on trap vector entry execution | Daniel Hellstrom | 2013-10-31 | 1 | -1/+0 |
* | LEON3_MP ISR: shared-IRQ setup overwrite SMP/MP ISR trap handler | Daniel Hellstrom | 2013-10-31 | 1 | -0/+5 |
| | | | | | | Basically the shared-irq handler overwrite the SMP/MP traphandler previously initialized with set_vector(). That caused IPIs to enter BSP spurious handler. | ||||
* | bsps/arm: Add ARMV7_CP15_START_DEFAULT_SECTIONS | Sebastian Huber | 2013-10-27 | 3 | -82/+46 |
* | bsps/arm: ARMV7_MMU_DATA_READ_WRITE_SHAREABLE | Sebastian Huber | 2013-10-27 | 3 | -36/+18 |
| | | | | | Delete ARMV7_MMU_DATA_READ_WRITE_SHAREABLE and move RTEMS_SMP specific MMU attribute settings to arm-cp15.h. | ||||
* | bsps: Add simple console output char | Sebastian Huber | 2013-10-27 | 3 | -31/+47 |
* | Modify raspberrypi mm_config_table to map GPIO and registers. | Hesham AL-Matary | 2013-10-27 | 1 | -2/+6 |
| | | | | | | | Changes include reverting back to setting all page-table section entries as invalid and modify mm_config_table to apply the correct memory attributes for raspbberypi memory sections at startup. The newly added entry at mm_config_table maps raspberrypi GPIO and other registers found at raspberrypi.h | ||||
* | bsps/arm: Move some MMU bit settings | Sebastian Huber | 2013-10-27 | 2 | -2/+3 |
| | | | | | | | The function arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache() must only set the MMU and cache enable flags. Configuration flags must be set elsewhere. | ||||
* | bsps/arm: Init trans tbl with invalid entries | Sebastian Huber | 2013-10-27 | 1 | -2/+2 |
* | sparc all BSPs: Use function and data sections | Joel Sherrill | 2013-10-24 | 4 | -8/+18 |
| | | | | This reduces the size of the RTEMS tests on average about 45%. | ||||
* | bsp/stm32f4: Bugfix for I2C driver. | Christian Mauderer | 2013-10-24 | 1 | -1/+1 |
* | bsp/stm32f4: Add a simple I2C-driver. | Christian Mauderer | 2013-10-24 | 10 | -0/+612 |
* | bsp/stm32f4: Bugfix for io-initialisation. | Christian Mauderer | 2013-10-24 | 1 | -1/+1 |
* | bsp/stm32f4: Header for f10xxx EXTI. | Christian Mauderer | 2013-10-24 | 4 | -0/+43 |
* | Shared MMU initialization for ARM BSPs and RaspberryPi MMU support | Hesham AL-Matary | 2013-10-03 | 8 | -31/+156 |
| | | | | | | | Add support for MMU initialization for RaspberryPi. Introduce new shared MMU configuration table that can be used by other BSPs that call the arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache function. Demonstrate the use of the generic table with RaspberryPi. | ||||
* | libbsp/sparc/.../gnatcommon.c: Formatting | Joel Sherrill | 2013-09-30 | 1 | -7/+5 |
* | leon2/.../ckinit.c: Change get nanoseconds handler to static | Joel Sherrill | 2013-09-30 | 1 | -1/+1 |
* | mips/shared/.../clockdrv.c: Change get nanoseconds handler to static | Joel Sherrill | 2013-09-30 | 1 | -4/+3 |
* | uC5282/.../clock.c: Change get nanoseconds handler to static | Joel Sherrill | 2013-09-30 | 1 | -2/+3 |
* | leon3/bsppredriver.c: Add include file to warning | Joel Sherrill | 2013-09-23 | 1 | -0/+1 |
* | leon3/.../ckinit.c: Change get nanoseconds handler to static | Joel Sherrill | 2013-09-23 | 1 | -6/+1 |
* | leon3/.../ckinit.c: Fix missing prototype warnings | Joel Sherrill | 2013-09-22 | 1 | -1/+5 |
* | libbsp/shared/bspinit.c: Fix missing prototype warnings | Joel Sherrill | 2013-09-22 | 1 | -3/+7 |
* | leon3/.../bspstart.c: Fix missing prototype warnings | Joel Sherrill | 2013-09-22 | 1 | -2/+2 |
* | sparc/.../grcan.c: Switch to using RTEMS_COMPILER_UNUSED_ATTRIBUTE | Joel Sherrill | 2013-09-22 | 1 | -8/+6 |
* | leon3/console.c: Fix misisng prototype issues | Joel Sherrill | 2013-09-21 | 1 | -2/+15 |
* | sparc/.../grcan.c: Fix multiple warnings | Joel Sherrill | 2013-09-21 | 1 | -2/+8 |
* | sparc/.../ambapp.h: Add ambapp_get_number_apbslv_devices() prototype | Joel Sherrill | 2013-09-21 | 1 | -0/+4 |
* | sparc/.../occan.c: Fix missing prototype warning | Joel Sherrill | 2013-09-21 | 1 | -0/+2 |
* | sparc/.../ambapp.h: Add ambapp_get_number_ahbslv_devices() prototype | Joel Sherrill | 2013-09-21 | 1 | -0/+6 |
* | sparc/../occan.c: Fix set but unused variable warning | Joel Sherrill | 2013-09-21 | 1 | -2/+1 |
* | sparc irq-shared.c: Fix unused variable warning | Joel Sherrill | 2013-09-21 | 1 | -1/+1 |
* | bsp/stm32f4: Add STM32F10XXX support. | Christian Mauderer | 2013-09-19 | 17 | -145/+758 |
* | leon3/include/bsp.h: Fix spacing | Joel Sherrill | 2013-09-16 | 1 | -1/+0 |
* | m68k/shared/start.S: Fix spacing | Joel Sherrill | 2013-09-16 | 1 | -1/+1 |
* | pc386/console/conscfg.c: Fix spacing | Joel Sherrill | 2013-09-16 | 1 | -3/+3 |
* | raspberrypi.cfg: Remove CVS Id | Joel Sherrill | 2013-09-16 | 1 | -2/+0 |
* | bsps/arm: Fix exception entries | Ric Claus | 2013-09-16 | 1 | -2/+2 |
* | bsp/lm4f120: new BSP to support TI LM4F120 XL LaunchPad board | Karel Gardas | 2013-09-02 | 8 | -11/+121 |
