* | gen68302: Add doxygen headers. | Toma Radu | 2013-12-30 | 3 | -0/+32 |
* | m32rsim: Add doxygen headers. | Szkocsovszki Zsolt | 2013-12-30 | 3 | -3/+45 |
* | m68k_csb360: doxygen improvement | Toma Radu | 2013-12-30 | 3 | -0/+32 |
| | | | | Add doxygen to the header files in the m68k/cdb360 directory. | ||||
* | libbsp misc: Fix comment formatting | Joel Sherrill | 2013-12-30 | 4 | -36/+33 |
* | m32cbsp: Add doxygen headers. | Szkocsovszki Zsolt | 2013-12-30 | 2 | -1/+31 |
* | i386/pc386: Add doxygen file headers. | Toma Radu | 2013-12-30 | 14 | -7/+119 |
* | h8sim: Add Doxygen directives | Szkocsovszki Zsolt | 2013-12-28 | 2 | -1/+31 |
* | libbsp/m68k: Add doxygen to m68k shared files. | Szkocsovszki Zsolt | 2013-12-26 | 3 | -4/+45 |
* | lm32_milkymist: improve doxygen | Toma | 2013-12-24 | 2 | -0/+24 |
| | | | | Add doxygen to the header files in the /lm32/milymist/include directory. | ||||
* | lm32_evr: improve doxygen | Toma | 2013-12-24 | 4 | -0/+40 |
| | | | | Add doxygen to the header files in the /lm32/lm32_evr/include directory. | ||||
* | bfin_eZKit533: added new doxygen | Daniel Ramirez | 2013-12-24 | 3 | -37/+102 |
* | bfin_TLL6527: added new doxygen | Daniel Ramirez | 2013-12-24 | 4 | -23/+96 |
* | mips/shared: added new doxygen | Daniel Ramirez | 2013-12-23 | 6 | -100/+304 |
* | i386: shared: Add doxygen | Chirayu Desai | 2013-12-23 | 9 | -116/+252 |
* | lm32: Enhance Doxygen #2 | Chirayu Desai | 2013-12-23 | 3 | -10/+29 |
* | lm32: Add doxygen | Chirayu Desai | 2013-12-23 | 21 | -10/+302 |
* | arm_stm32f4: added new doxygen | Daniel Ramirez | 2013-12-22 | 14 | -8/+319 |
* | libbsp/arm: add doxygen to arm shared headers | Szkocsovszki Zsolt | 2013-12-22 | 15 | -0/+127 |
* | arm_xilinx-zynq: added new doxygen | Daniel Ramirez | 2013-12-22 | 6 | -90/+261 |
* | rtl22xx: delete extra temporary file. | Gedare Bloom | 2013-12-22 | 1 | -218/+0 |
* | arm_rtl22xx: added new doxygen | Daniel Ramirez | 2013-12-22 | 3 | -83/+479 |
* | arm_smdk2410: added new doxygen | Daniel Ramirez | 2013-12-22 | 1 | -0/+12 |
* | arm_gp32: added new doxygen | Daniel Ramirez | 2013-12-22 | 2 | -17/+54 |
* | arm_edb7312: added new doxygen | Daniel Ramirez | 2013-12-22 | 3 | -16/+135 |
* | gumstix: added new doxygen | Daniel Ramirez | 2013-12-22 | 3 | -119/+324 |
* | Filesystem: Use default kqfilter and poll handler | Sebastian Huber | 2013-12-20 | 1 | -0/+2 |
* | Filesystem: Add readv/writev handlers | Sebastian Huber | 2013-12-20 | 1 | -1/+3 |
| | | | | | | | | | The readv() and writev() support was implemented in terms of multiple calls to the read and write handlers. This imposes a problem on device files which use an IO vector as single request entity. For example a low-level network device (e.g. BPF(4)) may use an IO vector to create one frame from multiple protocol layers each with its own IO vector entry. | ||||
* | arm/gba: doxygen improvement | Toma | 2013-12-19 | 8 | -19/+69 |
| | | | | | Add doxygen to the header files in the arm/gba include, irq, and console directories. | ||||
* | arm/a9mpcore: Add support to get the clock via a weak linkage function. | Chris Johns | 2013-12-19 | 3 | -3/+46 |
| | | | | | | This allows an application to provide a localised clock freq with needing to go down the BSP opts path. This is important with the Zynq where the Xilinx tools generate the frequency. | ||||
* | arm/zynq: Add support for application supplied MMU tables. | Chris Johns | 2013-12-19 | 3 | -31/+63 |
| | | | | | Users can provide a zynq_setup_mmu_and_cache function that sets up the MMU. The Zynq's PL logic means users can vary the MMU. | ||||
* | Fix the broken conflict from the revert. | Chris Johns | 2013-12-19 | 1 | -12/+6 |
* | Revert "bsps/arm: Use ALIGN_WITH_INPUT" | Chris Johns | 2013-12-19 | 3 | -84/+130 |
| | | | | | | | This reverts commit 287bbb65afd24ffc6254ae5f328733213f184205. Conflicts: c/src/lib/libbsp/arm/shared/startup/linkcmds.base | ||||
* | arm_lm3s69xx: improve doxygen | Toma Radu | 2013-12-17 | 7 | -0/+112 |
| | | | | Add doxygen to the header files in the arm/lm3s69xx/include directory. | ||||
* | bsp/genmcf548x: Increase network TX FIFO watermark | Sebastian Huber | 2013-12-16 | 1 | -2/+2 |
| | | | | This prevents frequent transmit FIFO errors. | ||||
* | bsp/genmcf548x: Fix network FIFO error handling | Sebastian Huber | 2013-12-16 | 1 | -576/+439 |
| | | | | | Use a buffer handling similar to the MPC5200B FEC driver to cope with FIFO errors. | ||||
* | bsp/genmcf548x: Use bsp_interrupt_vector_enable() | Sebastian Huber | 2013-12-16 | 3 | -28/+9 |
* | bsp/genmcf548x: Add initial values for INTC_ICRn | Sebastian Huber | 2013-12-16 | 7 | -33/+41 |
| | | | | | According to the manual the application must use unique and non-overlapping level and priority definitions for enabled interrupts. | ||||
* | bsp/genmcf548x: Add interrupt extension support | Sebastian Huber | 2013-12-16 | 4 | -0/+340 |
* | bsps/m68k: Add and use linkcmds.base | Sebastian Huber | 2013-12-16 | 12 | -514/+503 |
* | bsps: Simplify FreeBSD linker sets | Sebastian Huber | 2013-12-16 | 7 | -94/+34 |
* | bsps/arm: Use ALIGN_WITH_INPUT | Sebastian Huber | 2013-12-16 | 3 | -119/+88 |
| | | | | This requires at least Binutils 2.24. | ||||
* | bsps/powerpc: Use ALIGN_WITH_INPUT | Sebastian Huber | 2013-12-16 | 5 | -168/+101 |
* | bsp: Move bspstart.c to sh/shared/startup/ | Szkocsovszki Zsolt | 2013-12-14 | 5 | -4/+4 |
* | arm: Enhance Doxygen for csb336,csb337 and gdbarmsim | Chirayu Desai | 2013-12-14 | 5 | -0/+41 |
* | arm: realview-pbx-a9: Add doxygen | Chirayu Desai | 2013-12-13 | 3 | -0/+50 |
* | PR1960: ERC32_Is_interrupt_masked for ERC32 in erc32.h | Helder Silva | 2013-12-11 | 1 | -1/+1 |
| | | | | | | | | | | The function-like macro ERC32_Is_interrupt_masked defined as: (ERC32_MEC.Interrupt_Masked & (1 << (_source))) The ERC32_MEC is of type ERC32_Register_Map structure and Interrupt_Masked does not exist in structure, instead Interrupt_Mask exists. Update the macro accordingly. | ||||
* | arm/xilinx__zynq: Support application based clock freq. | Chris Johns | 2013-12-10 | 1 | -2/+110 |
| | | | | | | | Provide a weak call to a clock freq routine to allow the application to supply the freq defined in the Xilinx generated source. Add code to calculate the baud rate. | ||||
* | arm/xilinx_zynq: Add bsp_translation_table_end to the linker script. | Chris Johns | 2013-12-10 | 1 | -0/+1 |
* | arm shared: Add bsp_translation_table_end the linker symbols. | Chris Johns | 2013-12-10 | 1 | -0/+1 |
* | doxygen: refactored doxygen in libbsp to illustrate new rule set | Daniel Ramirez | 2013-12-09 | 17 | -41/+111 |
