* mpc8xx/exceptions/.cvsignore, mpc8xx/exceptions/Makefile.am,
mpc8xx/exceptions/asm_utils.S, mpc8xx/exceptions/raw_exception.c,
mpc8xx/exceptions/raw_exception.h: New files.
* configure.in, mpc6xx/mmu/bat.h, mpc8xx/Makefile.am,
mpc8xx/clock/clock.c,
mpc8xx/console-generic/console-generic.c,
mpc8xx/include/mpc8xx.h, mpc8xx/mmu/mmu.c,
new_exception_processing/cpu.h, shared/include/byteorder.h,
wrapup/Makefile.am: This is conversion of the
mpc8xx CPU to the "new exception processing model."
* clock/.cvsignore, clock/Makefile.am, clock/p_clock.c,
include/8xx_immap.h, include/commproc.h, include/mbx.h,
irq/.cvsignore, irq/Makefile.am, irq/irq.c, irq/irq.h,
irq/irq_asm.S, irq/irq_init.c, vectors/.cvsignore,
vectors/Makefile.am, vectors/vectors.S, vectors/vectors.h,
vectors/vectors_init.c: New files.
* Makefile.am, configure.in, console/console.c,
include/Makefile.am, network/network.c, startup/Makefile.am,
startup/bspstart.c, startup/imbx8xx.c, startup/linkcmds,
startup/mmutlbtab.c, startup/start.S, wrapup/Makefile.am:
The modifications to this BSP reflect the conversion of the
* console/console.c: Added printk() support.
* clock/clockdrv.c, console/conscfg.c, include/bsp.h, start/start.S,
startup/bspstart.c, timer/timer.c: Comments corrected.
* The Generic Mongoose-V BSP uses only the peripherals found on
the Synova Mongoose-V CPU. This is a radiation hardened CPU
based on the LSI Logic 33K.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.in,
clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c,
console/.cvsignore, console/Makefile.am, console/conscfg.c,
start/.cvsignore, start/Makefile.am, start/regs.S, start/start.S,
startup/.cvsignore, startup/Makefile.am, startup/bspstart.c,
startup/linkcmds, timer/.cvsignore, timer/Makefile.am, timer/timer.c,
wrapup/.cvsignore, wrapup/Makefile.am: New files.
* mpc505/ictrl/Makefile.am, mpc6xx/clock/Makefile.am,
mpc6xx/exceptions/Makefile.am, mpc6xx/mmu/Makefile.am,
mpc8xx/include/Makefile.am, new_exception_processing/Makefile.am,
old_exception_processing/Makefile.am, pc403/ictrl/Makefile.am,
shared/include/Makefile.am, shared/src/Makefile.am:
Apply *_HEADERS instead of *H_FILES.
* shared/src/.cvsignore: Add cache.h.
* configure.in: Reworked for Canadian Cross support.
* config.guess, config.sub: Update from subversions.gnu.org.
* README.cdn-X: New file.
* tools/Makefile.am: Remove build, tools from SUBDIRS.
* bsp.am: Fix automake version number in comment.
* .cvsignore: Add stamp-h
* Makefile.am: Add scitab, gdbsci to SUBDIRS.
* include/gdbsci.h: New file.
* include/.cvsignore: Add stamp-h? and bspopts.h*.
* console/Makefile.am: Use shared/console.c.
* console/console-io.c, console/console-support.S: Remove.
* startup/genpvec.c: #include <chain.h> instead of "chain.h", fix
CVS-Id.
* include/chain.h: Remove.
* include/Makefile.am: Remove chain.h.
* startup/genpvec.c: #include <chain.h> instead of "chain.h".
* gdbsci/, scitab/, trap34/: Add directories.
* startup/linkcmds: Remove OUTPUT_FORMAT.
* Makefile.am, README, console/console-io.c, start/start.S,
startup/linkcmds: Update to make shsim closer to functional.
* config.h.in: Automatically generated. Remove from CVS.
* README.EVB7045F: New file.
* README: Additions and corrections.
* include/bsp.h: Switch console to sci0.
* README, clock/Makefile.am, clock/ckinit.c, clock/clock.c:
Clock driver updated to use shell driver mechanism.
* clock/ckinit.c: Removed.
* clock/clock.c: New file.
* setvec.c: Removed unused variables.
* include/bsp.h, timer/timer.c: Updated so timer appears to
work and support tm27. I would prefer to time a software
interrupt rather than an use an extra timer though.
* Removing non-function shmsupp directory.
* shmsupp/.cvsignore, shmsupp/Makefile.am, shmsupp/addrconv.c,
shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c: Removed.
* configure.in, Makefile.am, wrapup/Makefile.am
* clockdrv_shell.c (CLOCK_DRIVER_ISRS_PER_TICK): Add support for
multiple ISRs per clock tick. Testing per hacking on mips/jmr3904
clock driver.
* clock/clockdrv.c: Clean up.
* include/bsp.h: Uncomment and fix set_vector() prototype.
* wrapup/Makefile.am: Remove warning missed in shmsupp removal.
* Shared memory support removed since it was non-functional.
* configure.in, Makefile.am, wrapup/Makefile.am: Modified to
reflect above.
* start/start.S: init_exc_vecs is now called mips_install_isr_entries.
* wrapup/Makefile.am: Corrected to reflect new libcpu structure.
* console/vt.c: Added include of <rtems.h> so _CPU_ISR_disable
would be visible.
* include/bsp.h: Added closing brace for extern C.
* scitab/Makefile.am, startup/bspstart.c, configure.in: Removed
rest of make-target-options and moved them to BSP configure options.
* include/bsp.h: Changed <sh/null.h> to <rtems/devnull.h> to reflect
the movement of this component to libmisc.
* wrapup/Makefile.am: /dev/null driver is no longer in libcpu/sh.
would be visible.
* bootloader/Makefile.am: Modified to install bootloader so
make-exe rule can avoid writing to install point or assuming
BSP build tree is available.
* clockdrv_shell.c: Fixed syntax error in fast idle support.
* clock/clock.c: Use shared clock driver shell.
* console/console.c: Removed. Now use shared polling shell.
* console/console-io.c: New file.
* console/Makefile.am: Correct to use shared polling shell.
* startup/bspstart.c: Remove all fast idle references.
* console/console-io.c: Removed unused variable initialized.
* console/console-io.c: Added console_initialize_hardware().
* new_exception_processing/cpu.h, old_exception_processing/cpu.c:
old_exception_processing/cpu.h, Added _CPU_Initialize_vectors().
In particular, spurious vector initialization had to be moved
on old exception processing model.
* clockdrv_shell.c: Added fast idle mode which is enabled by defining
CLOCK_DRIVER_USE_FAST_IDLE.
* console-polled.c: Added console_initialize_hardware() hook.
* ChangeLog: Removed bad entry.
* clock/Makefile.am: Fixed reference to ckinit.c.
* clock/clockdrv.c: Enabled fast idle.
* start/start.S: Added space for vectors on CPU32 configuration.
* startup/bspstart.c: Fixed typo.
* clock: New directory with stub clock driver.
* clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c: New files.
* Makefile.am, configure.in, wrapup/Makefile.am: Modified
to reflect above.
* startup/linkcmds: Set _VBR to 0 to indicate that the vectors are
in RAM not ROM. Thanks to Juan Zamorano <jzamora@fi.upm.es> for
debugging this.
* timer/timer.c: Removed incorrect comments about ERC32.
* timer: New subdirectory.
* timer/.cvsignore, timer/Makefile.am, timer/timer.c: New files.
* tools/ChangeLog: New file.
* Makefile.am: Added tools subdirectory and removed commented out line.
* configure.in: Added tools subdirectory.
* tools: New subdirectory.
* tools/.cvsignore, tools/Makefile.am, tools/configure.in,
tools/runtest: New files -- based on powerpc/psim.
* clock/clockdrv.c: Guessed new value for clock tick. Need to
add fast idle support.
* include/bsp.h: tm27 support initiated.
* start/start.S: Fixed frame/endframe problems on _sys_exit.
* startup/bspstart.c: Increased Workspace size to 4 MBYTES!
* linkcmds: Increased Workspace size to 4 MBYTES!
* Most tests appear to run correctly!
* Makefile.am: Removed unneeded blank line.
* network/network.c: Removed unused variable warnings.
* Makefile.am, configure.in, include/Makefile.am,
wrapup/Makefile.am: Updated to reflect addition of network driver
by Franck Julien <FranckJ@cxr.fr>.
* include/m302_int.h, network/.cvsignore, network/Makefile.am,
network/network.c: New file.
