* | applied patches for PR1117/1118/1119/1120 | Thomas Doerfler | 2006-07-09 | 13 | -359/+985 | |
* | 2006-06-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-06-25 | 4 | -58/+59 | |
| | | | | | * startup/linkcmds, startup/linkcmds-le, startup/linkcmds-le.coff: Add .rela.dyn sections. | |||||
* | 2006-06-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-06-25 | 4 | -26/+44 | |
| | | | | * startup/linkcmds: Add .rela.dyn sections. | |||||
* | 2006-06-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-06-25 | 4 | -0/+59 | |
| | | | | | * startup/linkcmds, startup/linkcmds.rom, startup/linkcmds.rom2ram: Add .rela.dyn sections. | |||||
* | 2006-06-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-06-25 | 4 | -39/+59 | |
| | | | | | * startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Add .rela.dyn sections. | |||||
* | 2006-06-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-06-25 | 6 | -0/+54 | |
* | 2006-06-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-06-24 | 2 | -0/+6 | |
| | | | | * configure.ac: | |||||
* | 2006-06-23 Worth Burruss <worth@motioncontrol.org> | Joel Sherrill | 2006-06-23 | 7 | -38/+101 | |
| | | | | | | | | | | | | | | | | * Makefile.am, README, startup/init5235.c, startup/linkcmds, startup/linkcmdsflash, startup/linkcmdsram: Modify to the mcf5235 eval boards to either load and run from ram using the dBug moniter as the boot deviced (Board setup as shipped from the factory), or it allows the user to Boot his code from flash he loads onto the eval board. The code changes between the two are based on the selected linker script using a variable in the script. The options to the linker are used to override the default linker script and select which options to configure at boot either from flash, or from ram: -qnolinkcmds -T linkcmdsflash If no options are given the standard linker sript assumes dBug was used to set up the board and the user is going to load his program to RAM. | |||||
* | 2006-06-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-06-22 | 2 | -1/+5 | |
| | | | | | PR 1100/bsps * console/debugputs.c: Remove redundant return. | |||||
* | Fix formatting. | Joel Sherrill | 2006-06-21 | 1 | -1/+1 | |
* | Indicate that it's ok to use decoupled cycles to access | Till Straumann | 2006-06-19 | 2 | -2/+10 | |
| | | | | on-board memory from VME. | |||||
* | Added address-modifier codes for BLT/MBLT. | Till Straumann | 2006-06-19 | 2 | -8/+37 | |
* | Only set/access the _BSP_vme_bridge_irq variable on BSPs that | Till Straumann | 2006-06-19 | 2 | -0/+8 | |
| | | | | define BSP_PCI_VME_DRIVER_DOES_EOI and BSP_PIC_DO_EOI. | |||||
* | filter exception vector for altivec and remap 0xf20 to | Till Straumann | 2006-06-19 | 2 | -2/+15 | |
| | | | | assigned vector number alias. | |||||
* | fixed compiler warnings (bspIo.h inclusion, cast of number | Till Straumann | 2006-06-19 | 2 | -3/+10 | |
| | | | | constants to pointers). Enable L1 cache on mvme2100. | |||||
* | Never allow the FPU to be switched on for integer-only tasks | Till Straumann | 2006-06-19 | 2 | -21/+5 | |
| | | | | (new gcc may use FP regs implicitely). | |||||
* | 2006-06-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-06-18 | 2 | -1/+8 | |
| | | | | * README: | |||||
* | 2006-06-02 Jay Monkman <jtm@lopingdog.com> | Jay Monkman | 2006-06-03 | 2 | -7/+5 | |
| | | | | | * shared/irq/irq_init.c: Changed interrupt handling to use shared rtems_irq_connect_data struct. | |||||
* | 2006-06-02 Jay Monkman <jtm@lopingdog.com> | Jay Monkman | 2006-06-03 | 2 | -3/+5 | |
| | | | | | * startup/linkcmds: Removed unnecessary global definition of bsp_vector_table. | |||||
* | 2006-06-02 Jay Monkman <jtm@lopingdog.com> | Jay Monkman | 2006-06-03 | 2 | -131/+139 | |
| | | | | * times: Reran timing tests and updated 'times' file. | |||||
* | 2006-06-02 Jay Monkman <jtm@lopingdog.com> | Jay Monkman | 2006-06-03 | 2 | -12/+35 | |
| | | | | * startup/bspstart.c: Fixed PLL calculations. | |||||
* | 2006-06-02 Jay Monkman <jtm@lopingdog.com> | Jay Monkman | 2006-06-03 | 3 | -197/+389 | |
| | | | | | * Makefile.am, console/uart.c, startup/exit.c: Changed UART driver to be interrupt driven, added support for both UARTs. | |||||
* | 2006-06-02 Jay Monkman <jtm@lopingdog.com> | Jay Monkman | 2006-06-03 | 2 | -0/+15 | |
| | | | | | * irq/bsp_irq_init.c: Changed interrupt handling to use shared rtems_irq_connect_data struct. | |||||
* | 2006-06-02 Jay Monkman | Jay Monkman | 2006-06-03 | 2 | -0/+14 | |
* | 2006-06-02 Jay Monkman | Jay Monkman | 2006-06-03 | 2 | -12/+18 | |
| | | | | | * network/network.c: Changed interrupt handling to use shared rtems_irq_connect_data struct. | |||||
* | 2006-06-02 Jay Monkman <jtm@lopingdog.com> | Jay Monkman | 2006-06-02 | 3 | -1/+18 | |
| | | | | | * start/start.S, startup/linkcmds: Defined UNDEF exception stack space. | |||||
* | Formatting. | Joel Sherrill | 2006-06-01 | 1 | -0/+6 | |
* | 2006-05-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-05-31 | 2 | -172/+11 | |
| | | | | * clock/clock.c: Switch to using shared clock driver shell. | |||||
* | Allow single spurious FPGA interrupt. | Eric Norum | 2006-05-15 | 2 | -3/+9 | |
* | Improve handling of unexpected FPGA interrupt conditions. | Eric Norum | 2006-05-15 | 2 | -3/+23 | |
* | 2006-04-12 Konrad Eisele <konrad@gaisler.com> | Joel Sherrill | 2006-04-12 | 2 | -0/+6 | |
| | | | | * include/leon.h: Add LEON_INTERRUPT_EXTERNAL_1 define. | |||||
* | Add default exception handler. | Eric Norum | 2006-04-11 | 2 | -1/+57 | |
* | Fix formatting. | Joel Sherrill | 2006-04-05 | 1 | -2/+2 | |
* | Add missing reset cause bit. | Eric Norum | 2006-03-24 | 2 | -0/+5 | |
* | 2006-03-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-03-22 | 6 | -0/+27 | |
| | | | | * include/.cvsignore: New file. | |||||
* | Misc. cosmetics. | Ralf Corsepius | 2006-03-17 | 17 | -77/+24 | |
* | Remove eof include file | Ralf Corsepius | 2006-03-17 | 79 | -79/+0 | |
* | Regenerate. | Ralf Corsepius | 2006-03-16 | 1 | -2/+6 | |
* | AC_CONFIG_SRCDIR(csb350). | Ralf Corsepius | 2006-03-16 | 1 | -1/+1 | |
* | 2006-03-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-16 | 1 | -1/+3 | |
| | | | | | * configure.ac: AC_CONFIG_SRCDIR(csb350). * acinclude.m4: Regenerate. | |||||
* | New. | Ralf Corsepius | 2006-03-16 | 1 | -0/+58 | |
* | Add preinstall.am | Ralf Corsepius | 2006-03-16 | 1 | -48/+1 | |
* | New (Submission by Bruce Robinson <brucer@pmccorp.com>). | Ralf Corsepius | 2006-03-16 | 23 | -0/+4984 | |
* | Add preinstall.am | Ralf Corsepius | 2006-03-16 | 2 | -100/+2 | |
* | New (Submission by Bruce Robinson <brucer@pmccorp.com>) | Ralf Corsepius | 2006-03-16 | 21 | -0/+3722 | |
* | New. | Ralf Corsepius | 2006-03-16 | 1 | -0/+62 | |
* | New (Submission by Bruce Robinson <brucer@pmccorp.com>). | Ralf Corsepius | 2006-03-16 | 28 | -0/+4472 | |
* | 2006-03-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-16 | 2 | -7/+1 | |
| | | | | * README: Remove (obsolete). | |||||
* | 2006-03-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-16 | 1 | -0/+4 | |
| | | | | * acinclude.m4: Remove p4000. |
