* console/Makefile.am: Add PREINSTALL_DIRS.
* irq/Makefile.am: Add PREINSTALL_DIRS.
* motorola/Makefile.am: Add PREINSTALL_DIRS.
* openpic/Makefile.am: Add PREINSTALL_DIRS.
* pci/Makefile.am: Add PREINSTALL_DIRS.
* residual/Makefile.am: Add PREINSTALL_DIRS.
* vectors/Makefile.am: Add PREINSTALL_DIRS.
* wrapup/Makefile.am: Reflect changes to libcpu.
* vme/Makefile.am: Add PREINSTALL_DIRS.
* consolex/Makefile.am: Add PREINSTALL_DIRS.
* irq/Makefile.am: Ditto.
* Makefile.am: Remove non-existing file "times" from EXTRA_DIST.
* startup/Makefile.am: Remove non-existing files setvec.c,
bspclean.c, exit.c from EXTRA_DIST.
* timer/Makefile.am: Remove non-existing file timer.c from EXTRA_DIST.
* Makefile.am: Remove non-existing times from EXTRA_DIST.
* start/Makefile.am: Remove non-existing cpuboot.c from EXTRA_DIST.
* configure.ac: Add AM_CONDITIONAL(HAS_FPSP).
* README: Fix minor typo.
* Makefile.am: Remove times from EXTRA_DIST (Non-existant).
* startup/Makefile.am: Remove exit.c, setvec.c from EXTRA_DIST.
* console/Makefile.am: Remove console.c from EXTRA_DIST.
* startup/Makefile.am: Remove bspclean.c, exit.c, setvec.c from
EXTRA_DIST.
* Makefile.am: Remove gdbstub/rtems-stub-glue.c (Non-existent)
* startup/Makefile.am: Remove bogus EXTRA_DIST.
* timer/Makefile.am: Remove bogus EXTRA_DIST.
* clock/Makefile.am: Remove bogus EXTRA_DIST.
* gdbsci/Makefile.am: Remove bogus EXTRA_DIST.
* start/.cvsignore: Remove.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* startup/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* startup/Makefile.am: Ditto.
* console/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* motorola/Makefile.am: Ditto.
* openpic/Makefile.am: Ditto.
* pci/Makefile.am: Ditto.
* residual/Makefile.am: Ditto.
* vectors/Makefile.am: Ditto.
* start/Makefile.am: Ditto.
* bootloader/Makefile.am: Ditto.
* vme/Makefile.am: Ditto.
* start/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* consolex/Makefile.am: Ditto.
* configure.ac: Ditto.
* console/Makefile.am: Ditto.
