* configure.ac: Add bspopts.h; Add CPU_CLOCK_RATE_HZ.
* startup/bspstart.c: Replace HZ with CPU_CLOCK_RATE_HZ.
* include/.cvsignore: Add stamp-h* bspopts.h*
* include/bsp.h: Add bspopts.h.
* include/.cvsignore: Add stamp-h*, bspopts.h*.
* clock/Makefile.am, clock/ckinit.c, clock/.cvsignore, Makefile.am,
README, bsp_specs, console/Makefile.am, console/console.c,
console/.cvsignore, include/Makefile.am, include/bsp.h,
include/coverhd.h, include/syscall.h, include/ramdisk.h,
include/.cvsignore, start/Makefile.am, start/start.S,
start/.cvsignore, startup/Makefile.am, startup/bspstart.c,
startup/hw_init.c, startup/linkcmds, startup/linkcmds-le,
startup/linkcmds-le.coff, startup/.cvsignore, timer/Makefile.am,
timer/timer.c, timer/.cvsignore, wrapup/Makefile.am, wrapup/.cvsignore,
configure.ac, .cvsignore, ChangeLog: New files.
Reviewed and updated to latest automake and autoconf standards
by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* configure.in: Remove.
* Makefile.am, README, bsp_specs, .cvsignore, include/Makefile.am,
include/bsp.h, include/coverhd.h, include/sdram.h, include/.cvsignore,
start/Makefile.am, start/start.S, start/.cvsignore, startup/Makefile.am,
startup/bspstart.c, startup/linkcmds, startup/linkcmds.rom,
startup/linkcmds.rom2ram, startup/.cvsignore, wrapup/Makefile.am,
wrapup/.cvsignore, hw_init/Makefile.am, hw_init/hw_init.c,
hw_init/.cvsignore, times, configure.ac: New files.
hw_init/.cvsignore, times, configure.ac, ChangeLog: New files.
* Makefile.am: Use @subdirs@ instead of RTEMS_LIBBSP_CPU_SUBDIR.
* configure.in: AC_PREREQ(2.52), apply RTEMS_CPU_SUBDIRS, remove
* console/85c30.c, startup/bspstart.c: Fix references to delay() and
delay_in_bus_cycles() to add rtems_bsp_ prefix.
* acinclude.m4: New file.
* shared/bootcard.c, shared/main.c: Now call int c_rtems_main()
not main().
* start/start.S: Invoke boot_card() not main().
* old_exception_processing/cpu.h: Renamed delay() to rtems_bsp_delay().
Renamed delay_in_bus_cycles() to rtems_bsp_delay_in_bus_cycles().
* shared/include/cpu.h: Renamed delay() to rtems_bsp_delay().
* shmsupp/lock.c: Renamed delay() to rtems_bsp_delay().
* new_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='.
* old_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/mmu/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/clock/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc8xx/include/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc8xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/include/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/src/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/src/Makefile.am: Use 'CLEANFILES ='.
* include/rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='.
* shmdr/Makefile.am: Use 'PREINSTALL_FILES ='.
* console/Makefile.am: Use 'PREINSTALL_FILES ='.
* residual/Makefile.am: Use 'PREINSTALL_FILES ='.
* irq/Makefile.am: Use 'PREINSTALL_FILES ='.
* motorola/Makefile.am: Use 'PREINSTALL_FILES ='.
* vectors/Makefile.am: Use 'PREINSTALL_FILES ='.
* pci/Makefile.am: Use 'PREINSTALL_FILES ='.
* openpic/Makefile.am: Use 'PREINSTALL_FILES ='.
* bootloader/Makefile.am: Use 'CLEANFILES ='.
* Makefile.am: Use 'TMPINSTALL_FILES ='.
* comm/Makefile.am: Use 'PREINSTALL_FILES ='.
* startup/Makefile.am: Use 'PREINSTALL_FILES ='.
* hared/bootcard.c: Now process C++ global constructors
(_init) as part of the first task execution not in BSP space.
This depends on the toolset defining USE_INIT_FINI so you
have to have the right toolset version.
* include/Makefile.am: fix path to shared/include/coverhd.h.
* Makefile.am: Use SUBDIRS = instead of SUBDIRS += to make
automake-1.5 happy.
* include/rtems/score/Makefile.am: Use CLEANFILES = to make
automake-1.5 happy.
* bsp.am: Use PREINSTALL_FILES = to make automake-1.5 happy.
* wrapup/Makefile: Use GENERIC_FILES = to make automake-1.5 happy.
automake-1.5 happy.
automake-1.5 happy.
* startup/init68360.c: Modifications to make gcc 3.x happy.
* scitab/Makefile.am: Remove stray blank from SCITAB rule.
* README: Bring it more in line with reality.
* ChangeLog: New file.
* network/network.c: Fix to account for return value when
installing interrupts handler.
* startup/linkcmds: Modified to work better with gcc 2.8.1 and
gnat 3.13p.
* include/Makefile.am: Include coverhd.h so tmtests will compile.
* include/bsp.h: Disabled redefinition of
CONSOLE_DRIVER_TABLE_ENTRY. Some "FIXME:" comments added.
* console/config.c: New file. Definitions of externs referenced
from libbsp/shared/console.c.
* console/Makefile.am: Changed VPATH to point to
libbsp/shared. Added config.c to C_FILES and EXTRA_DIST.
* comm/tty_drv.c, comm/uart.c: Correct some minor cut and paste bugs.
* clock/clock.c: Ensure that clock ticks are long enough to
make forward progress. This was modified to improve results
on the RTEMS tests and the ACATS.
gnat 3.13p.
* tools/runtest.in: Recognize debug variant of monitor test.
