* | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-04 | 3 | -4/+14 |
| | | | | * console/console.c, network/network.c: Removed warnings. | ||||
* | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-04 | 2 | -1/+5 |
| | | | | * irq/irq.c: Removed warnings. | ||||
* | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-04 | 4 | -1/+11 |
| | | | | * network/network.c: Removed warnings. | ||||
* | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-04 | 2 | -0/+7 |
| | | | | * console/i8042.c: Removed warnings. | ||||
* | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-04 | 7 | -7/+24 |
| | | | | | | * console/console.c, irq/irq.c, network/if_hdlcsubr.c, network/if_hdlcsubr.h, network/network.c, vectors/vectors_init.c: Removed warnings. | ||||
* | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-04 | 6 | -27/+39 |
* | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-04 | 2 | -2/+4 |
| | | | | * clock/clock.c: Removed warnings. | ||||
* | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-04 | 2 | -0/+5 |
| | | | | * console/console.c: Removed warnings. | ||||
* | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-04 | 3 | -24/+32 |
| | | | | * console/sci.c, spurious/spinit.c: Removed warnings. | ||||
* | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-04 | 6 | -23/+8 |
| | | | | | * console/console.c, i2c/i2cdrv.c, nvram/nvram.c, startup/bspstart.c, tod/ds1307.c: Removed warnings. | ||||
* | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-04 | 3 | -3/+11 |
| | | | | * console/console.c, console/m340uart.c: Removed warnings. | ||||
* | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-04 | 3 | -1/+6 |
| | | | | * console/console.c, network/ne2000.c: Removed warnings. | ||||
* | 2002-11-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-02 | 3 | -2/+7 |
| | | | | * console/console.c, start/start.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 3 | -31/+31 |
| | | | | * console/console.c, start/start.c, startup/efi68k_wd.c: | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 3 | -38/+42 |
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 2 | -4/+8 |
| | | | | * startup/m68k-stub.c: Removed typos. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 4 | -7/+13 |
| | | | | | * irq/irq.c, irq/irq_asm.S, startup/bspstart.c: Fixed typos and removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 2 | -0/+5 |
| | | | | * gnatcommon.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 3 | -1/+11 |
| | | | | * gnatsupp/gnatsupp.c, startup/spurious.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 3 | -5/+8 |
| | | | | * clock/ckinit.c, console/console.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 2 | -2/+8 |
| | | | | * gdbsci/gdbsci.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 3 | -3/+5 |
| | | | | * start/start.S, startup/hw_init.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 2 | -0/+14 |
| | | | | | | * cpu.c: Currently only the mpc8260 BSP supports interrupt nesting. NOTE: These needs to be generalized as the patch is applied to other BSPs. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 4 | -12/+19 |
| | | | | | * clock/p_clock.c, console/console.c, startup/bspstart.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 6 | -12/+20 |
| | | | | | * canbus/canbus.c, clock/p_clock.c, console/console.c, network/network.c, startup/bspstart.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 3 | -2/+6 |
| | | | | * startup/genpvec.c, tod/todcfg.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 2 | -5/+10 |
| | | | | * mips-stub.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 3 | -2/+8 |
| | | | | * startup/bspclean.c, startup/bspstart.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 3 | -0/+7 |
| | | | | * startup/gdb-support.c, startup/linkcmds: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 3 | -3/+6 |
| | | | | * console/conscfg.c, startup/bspstart.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 2 | -199/+203 |
| | | | | * startup/m68k-stub.c: Removed warnings. | ||||
| | | | | * network/network.c, startup/bspclean.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 2 | -10/+15 |
| | | | | * startup/page_table.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 4 | -2/+15 |
| | | | | * startup/bspstart.c: Removed warnings. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 2 | -5/+9 |
| | | | | * m68k-stub.c: Corrected typos. | ||||
* | 2002-11-01 Andy Dachs <a.dachs@sstl.co.uk> | Joel Sherrill | 2002-11-01 | 4 | -377/+484 |
| | | | | | * irq/irq.c, irq/irq_asm.S, irq/irq_init.c: Per PR288, add support for _ISR_Nest_level. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 2 | -2/+7 |
| | | | | | * comm/i386-stub.c: Fixed places where debug_error() was not called with enough arguments. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 2 | -3/+8 |
| | | | | * comm/i386-stub.c: Removed warnings. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 8 | -4/+21 |
| | | | | | | * bootloader/em86.c, console/inch.c, console/polled_io.c, irq/irq.c, motorola/motorola.c, pci/detect_raven_bridge.c, vectors/vectors_init.c: Removed warnings. | ||||
* | 2002-10-31 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-31 | 2 | -76/+81 |
| | | | | * m68k-stub.c: Fixed warnings about multi-line strings in asm. | ||||
* | 2002-10-28 Eugeny S. Mints <Eugeny.Mints@oktet.ru> | Joel Sherrill | 2002-10-28 | 2 | -0/+183 |
| | | | | * ide_ctrl.c: New file. | ||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 168 | -254/+760 |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | ||||
* | 2002-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-09 | 2 | -0/+5 |
| | | | | * .cvsignore: Add autom4te.cache. | ||||
* | 2002-10-04 Jay Monkman <jtm@smoothsmoothie.com> | Joel Sherrill | 2002-10-04 | 2 | -0/+10 |
| | | | | * irq/irq_asm.S: Add FIQ support. | ||||
* | 2002-10-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-02 | 2 | -1418/+4 |
| | | | | * rtems-stub-glue.c: Removed should only be common copy. | ||||
* | 2002-09-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-09-14 | 2 | -0/+7 |
| | | | | | * cpu.c: Include declaration of variable i in ifdef USE_SPRG to eliminate warning. | ||||
* | 2002-09-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-09-14 | 2 | -0/+9 |
| | | | | | * clock/clock.c: Per PR257, remove reference to c3x_set_ie. c4x variant should use c4x_set_iie(). | ||||
* | 2002-09-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-09-14 | 10 | -5/+30 |
| | | | | | * startup/bspstart.c: As part of fixing PR281 on gensh4, a review of all calls to bsp_libc_init() resulted in some cleanup here. | ||||
* | 2002-09-14 Ivan Guzvinec <ivang@opencores.org> | Joel Sherrill | 2002-09-14 | 4 | -4/+12 |
| | | | | | * include/bsp.h, startup/Makefile.am, startup/bspclean.c: Cleanup so the BSP works. |
