* README: Updated.
* console/console.c: Addition of support for shared printk and
no termios.
* include/bsp.h: Addition of second parameter to
rtems_enet_driver_attach. Removed prototypes for printk and
BSP_output_string.
* network/network.c(rtems_enet_driver_attach): Addition of second
parameter to function.
to driver attach routine.
alias simcpu32 that supports the CPU32 simulator in BSVC. At this
point, it is still under development.
That BSP now has a stub clock driver so the tests can link even
if they won't execute. A handful of Makefiles had to be updated
and we had to account for printk.c being a shared file now.
removes warnings from the network.c file and has slight additions
to the configuration file to support Java.
by Till Straumann <strauman@SLAC.Stanford.EDU>. With this
patch, the motorola_shared BSP should also support the MVME2303.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
are now in libcpu. This primarily required moving erc32 specific
information from score/cpu files to libcpu/sparc and the erc32 BSP.
are now in libcpu. This required significant rework of the
score/cpu header files and the creation of multiple header files
and subdirectories in libcpu/i960.
that addresses aspects of the targopts.h multilib related
issues.
* Move targopts.h to libbsp/include, because the current targopts.h
actually is a per-BSP-header and therefore can not stay below exec/.
* Introduce an autoheader generated header file
(exec/score/include/rtems/score/cpuopts.h), which shall take per-cpu
configuration options only.
* Move all autoconf-detectable/configure specified per-cpu
option-defines from targopts.h to cpuopts.h.
* Add Makefiles to the libbsp/shared directory hierarchy.
* The new per-bsp targopts.h in libbsp includes the per-cpu
cpuopts.h. This way, the new targopts.h is kept backward compatible
to the old targopts.h and existing BSPs which (carelessly) include
targopts.h (i386, ppc) should be kept working when using the
multilib-disabled configuration scheme.
* cpuopts.h is not yet complete, because the per-BSP make-targopts
rules from custom/<BSP>.cfg files can not be applied to files below
exec/ when building multilibs.
* All files below exec/ should not include targopts.h anymore, but
should include cpuopts.h instead. However, eliminating inclusion of
targopts.h currently triggers further structural / header file inclusion
related issues, because several ports apply BSP or CPU_MODEL specific
defines from targopts.h below exec/
again neither will unlinked executables. :)
were needed to move exception processing to score/cpu.
from score/cpu to libcpu because the determination of which to use is
based on RTEMS_CPU_MODEL. Thus it can not be determined based solely on
multilib information.
<elkolli@crf.canon.fr> to add support for the mbx860_005b.
_Interrupt_Manager_initialization.
