2018-04-20 | bsps: Move bspreset.c to bsps | Sebastian Huber | 40 | -56/+39 | |
This patch is a part of the BSP source reorganization. Update #3285. | |||||
2018-04-20 | bsps: Move bspclean.c to bsps | Sebastian Huber | 72 | -170/+71 | |
2018-04-20 | motorola_powerpc: Remove headers from *_SOURCES | Sebastian Huber | 1 | -5/+1 | |
This was used by the not supported "make dist". This patch is a part of the BSP source reorganization. Update #3285. | |||||
2018-04-17 | misc arm tcfg: Add dl06, too large for memory | Joel Sherrill | 3 | -0/+3 | |
2018-04-17 | misc tcfg: Use disable-mrfs-tests.tcfg, do not duplicate test list | Joel Sherrill | 3 | -28/+3 | |
2018-04-17 | lpc2362-testsuite.tcfg: Use disable-iconv-tests.tcfg, do not duplicate test list | Joel Sherrill | 1 | -3/+1 | |
2018-04-17 | misc tcfg: Use disable-jffs2-tests.tcfg, do not duplicate test list | Joel Sherrill | 19 | -171/+38 | |
2018-04-17 | generic_or1k: Disable sptls02 until or1k GCC updated from 4.9.x | Joel Sherrill | 1 | -0/+2 | |
Updates #3391. | |||||
2018-04-17 | Multiple BSP tcfg: Disable iconv files. | Joel Sherrill | 32 | -0/+33 | |
2018-04-16 | bsps: Move uart-output-char.c to bsps | Sebastian Huber | 4 | -55/+3 | |
2018-04-16 | bsps: Move stackalloc.c to bsps | Sebastian Huber | 18 | -82/+17 | |
2018-04-16 | bsps: Move bsp-uboot-board-info.c to bsps | Sebastian Huber | 3 | -34/+2 | |
2018-04-16 | bsps: Move bsp-fdt.c to bsps | Sebastian Huber | 5 | -69/+4 | |
2018-04-16 | bsps: Move tod.c to bsps and rename | Sebastian Huber | 15 | -301/+14 | |
2018-04-12 | build: Remove subdir-objects from BSP configure.ac | Sebastian Huber | 83 | -83/+83 | |
The subdir-objects do not work currently due to BSP sources in bsps and c and the existing build tree layout. Update #3387. | |||||
2018-04-12 | bsps: Remove empty gnatinstallhandler.c | Sebastian Huber | 74 | -90/+0 | |
2018-04-12 | bsps: Move bootcard.c to bsps | Sebastian Huber | 84 | -168/+0 | |
2018-04-12 | bsps: Simplify source file path in Makefile.am | Sebastian Huber | 31 | -286/+286 | |
2018-04-12 | bsps: Remove headers from librtemsbsp_a_SOURCES | Sebastian Huber | 43 | -80/+0 | |
2018-04-12 | bsps: Avoid source variables in Makefile.am | Sebastian Huber | 4 | -108/+96 | |
2018-04-12 | bsps: Avoid line continuation in Makefile.am | Sebastian Huber | 62 | -553/+782 | |
2018-04-12 | bsp/mvme5500: Avoid RTEMS_RELLDFLAGS | Sebastian Huber | 3 | -24/+14 | |
2018-04-12 | bsp/motorola_powerpc: Move polled_io.c | Sebastian Huber | 5 | -1597/+2 | |
This file was used by this BSP only. Avoid RTEMS_RELLDFLAGS. This patch is a part of the BSP source reorganization. Update #3285. | |||||
2018-04-12 | bsp/beatnik: Avoid RTEMS_RELLDFLAGS | Sebastian Huber | 15 | -88/+163 | |
Avoid extra CPPFLAGS. | |||||
2018-04-12 | bsps: Move legacy console driver to bsps | Sebastian Huber | 33 | -768/+65 | |
2018-04-12 | bsps: Remove unused console_select_simple.c | Sebastian Huber | 1 | -22/+0 | |
2018-04-11 | configure: Add subdir-objects to all automake flags. | Chris Johns | 100 | -100/+100 | |
This option silences warning with automake-1.16.1 allowing us to upgrade to that version. This change has been tested with automake-1.12.6 and automake-1.16.1. It seems version 1.16.1 configures slower than 1.12.6 for the same source and BSP. The newer versions is 6 second slower. Close #3387. | |||||
2018-04-10 | bsp/lpc24xx: Exclude iconv POSIX tests. | Chris Johns | 1 | -0/+3 | |
These are now built to executables and are too large for this BSP. This change is part of the testsuite Makefile.am reorganization. Update #3382 | |||||
2018-04-09 | bsp/genmcf548x: Fix IRQ support | Sebastian Huber | 1 | -4/+1 | |
2018-04-09 | bsp/csb337: Fix umon support | Sebastian Huber | 1 | -0/+1 | |
2018-04-09 | build: Remove DISTCLEANFILES | Sebastian Huber | 83 | -84/+0 | |
A "make distclean" is not supported. So, it makes no sense to have pure "make distclean" related stuff in the Makefile.am. | |||||
2018-04-09 | bsps: Move generic IRQ support to bsps | Sebastian Huber | 50 | -2019/+91 | |
2018-04-09 | bsps: Remove librtemsbsp.a wrapup | Sebastian Huber | 83 | -2118/+2118 | |
2018-04-09 | bsps: Move VME support to bsps | Sebastian Huber | 14 | -6426/+4 | |
The VME support is only used by powerpc BSPs. This patch is a part of the BSP source reorganization. Update #3285. | |||||
2018-04-09 | bsp: Move umon support to bsps | Sebastian Huber | 7 | -2078/+4 | |
The umon support is only used by the csb337 BSP. This patch is a part of the BSP source reorganization. Update #3285. | |||||
2018-04-05 | bsps/powerpc: Rename to shared-sources.am | Sebastian Huber | 18 | -18/+18 | |
2018-04-05 | bsps/powerpc: Rename to exceptions-sources.am | Sebastian Huber | 17 | -17/+17 | |
2018-04-05 | bsps/m68k: Rename fpsp.am to fpsp-sources.am | Sebastian Huber | 3 | -3/+3 | |
2018-04-05 | bsps/bfin: Rename shared.am to shared-sources.am | Sebastian Huber | 3 | -3/+3 | |
2018-04-04 | bsps: Move libchip to bsps | Sebastian Huber | 2 | -240/+1 | |
2018-04-04 | bsps: Move config macros to RTEMS_BSP_CONFIGURE | Sebastian Huber | 83 | -381/+0 | |
Provide HAS_NETWORKING and HAS_SMP Automake conditionals for all BSPs. This patch is a part of the BSP source reorganization. Update #3285. | |||||
2018-04-04 | bsps: Add shared-sources.am | Sebastian Huber | 83 | -0/+83 | |
2018-04-04 | build: Remove EXTRA_DIST | Sebastian Huber | 93 | -439/+0 | |
A "make dist" is not supported. So, it makes no sense to have pure "make dist" related stuff in the Makefile.am. | |||||
2018-03-28 | Eliminate PowerPC libcpu/page.h | Joel Sherrill | 5 | -5/+9 | |
Started to eliminate warnings and then realized that only one one-line macro in the file was used by a few files. The rest of the file was was not needed. Eliminate the file. Closes #3354. | |||||
2018-03-27 | bsps/riscv: Fix warnings | Sebastian Huber | 2 | -7/+1 | |
2018-03-26 | bsps/m68k: Remove libcpu/m68k | Sebastian Huber | 19 | -20/+0 | |
2018-03-26 | bsps/genmcf548x: Move libcpu content to bsps | Sebastian Huber | 1 | -3/+5 | |
2018-03-26 | bsps/csb360: Move libcpu content to bsps | Sebastian Huber | 1 | -4/+3 | |
2018-03-26 | bsps/mcf5206elite: Move libcpu content to bsps | Sebastian Huber | 1 | -6/+5 | |
2018-03-26 | bsps/m68k: Move fpsp support to bsps | Sebastian Huber | 3 | -5/+3 | |
