* | bsps/x86_64: Add APIC timer based clock driver | Amaan Cheval | 2018-08-13 | 1 | -1/+3 |
| | | | | | | | | | The APIC timer is calibrated by running the i8254 PIT for a fraction of a second (determined by PIT_CALIBRATE_DIVIDER) and counting how many times the APIC counter has ticked. The calibration can be run multiple times (determined by APIC_TIMER_NUM_CALIBRATIONS) and averaged out. Updates #2898. | ||||
* | bsps/x86_64: Add support for RTEMS interrupts | Amaan Cheval | 2018-08-13 | 1 | -0/+4 |
* | bsps/x86_64: Add paging support with 1GiB super pages | Amaan Cheval | 2018-08-13 | 1 | -0/+1 |
* | x86_64/console: Add NS16550 polled console driver | Amaan Cheval | 2018-07-11 | 1 | -0/+2 |
| | | | | | | This addition allows us to successfully run the sample hello.exe test. Updates #2898. | ||||
* | bsp/x86_64: Minimal bootable BSP | Amaan Cheval | 2018-07-11 | 2 | -0/+59 |
Current state: - Basic context initialization and switching code. - Stubbed console (empty functions). - Mostly functional linker script (may need tweaks if we ever want to move away from the large code model (see: CPU_CFLAGS). - Fully functional boot, by using FreeBSD's bootloader to load RTEMS's ELF for UEFI-awareness. In short, the current state with this commit lets us boot, go through the system initialization functions, and then call user application's Init task too. Updates #2898. |
