Update #3285.
The file console-polled.h provides the prototypes for the three
required methods when implementing a single port polled console
driver. This paradigm is common on simulators and simple hardware.
+ Updated the BSPs Makefile.am to make console-polled.h available.
+ Regenerated the BSPs preinstall.sm.
+ Updated console support files to include <bsp/console-polled.h>.
+ Updated console support files to make printk() support method static.
Port
+ v850 does not have appear to have any optimized bit scan instructions
+ v850 does have single instructions for wap u16 and u32
+ Code path optimization preferences set
+ Add BSP variants for each GCC CPU model flag and a README
- v850e1 variant does not work (fails during BSP initialization)
BSP for GDB v850 Simulator
+ linkcmds matches defaults in GDB simulator with RTEMS mods
+ crt1.c added from v850 newlib port for __main()
+ BSP exits cleanly
+ printk and console I/O work
+ uses clock tick from IDLE task
+ Tests not requiring real clock ISR work
Documentation
+ CPU Supplment chapter for v850 added
* Makefile.am, configure.ac, console/console-io.c, include/bsp.h,
start/start.S: Create dedicated bsp_reset() and clean up.
* .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac,
preinstall.am, console/console-io.c, console/syscalls.S,
console/trap0.S, include/.cvsignore, include/bsp.h, include/tm27.h,
start/start.S, startup/linkcmds: New files.
* console/console-io.c: Add missing file and remove junk code.
* console/syscalls.S: New file.
* Makefile.am, console/console-io.c, include/bsp.h:
* console/console-io.c, include/bsp.h, startup/bspstart.c: URL for
license changed.
* console/console-io.c: Include rtems/bspIo.h instead of bspIo.h.
* console/console-io.c: Fixed typo.
* console/console-io.c: Added console_initialize_hardware().
by gdb 5.0's i960 simulator) is enough to run hello world.
reduce dependencies and shrink minimum executable size.
PROBLEMS
can/will be fixed.
cfsetispeed().
