* runtest.in: Add fileio to list of interactive tests.
* configure.ac: Add BSPOPTS (WORKSPACE_MB, HEAPSPACE_MB).
* shmsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS. Cosmetical
changes.
* configure.ac: Unconditionally check for CXX (Hack to bug in
autoconf > 2.54).
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
* startup/Makefile.am: Do NOT use the standard bootcard.c.
NOTE: With this fix all test including the mptest ran as expected.
* configure.in: Remove.
* acinclude.m4: New file.
* include/Makefile.am: Include coverhd.h so tmtests will compile.
* include/.cvsignore: Add bspopts.h*, stamp-h*, coverhd.h.
* bsp_specs: Add qnolinkcmds.
* ChangeLog: Corrected previous entry to include configure.in.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include
compile.am
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
that contains:
* Removes MKLIB
handling)
converted to automake.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
that converts the unix directory to automake.
Ralf's note: Please check c/src/lib/libbsp/unix/posix/startup/Makefile.am.
I am not sure if it is correct.
Renamed file shmsupp/intr.c in some BSPs to shmsupp/cause_intr.c to
avoid conflict with rtems/src/intr.c (Classic API Interrupt Manager).
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
