* bsp_specs: Add qnolinkcmds.
* ChangeLog: Corrected previous entry to include configure.in.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include
compile.am
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
that contains:
* Removes MKLIB
handling)
converted to automake.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
that converts the unix directory to automake.
Ralf's note: Please check c/src/lib/libbsp/unix/posix/startup/Makefile.am.
I am not sure if it is correct.
Renamed file shmsupp/intr.c in some BSPs to shmsupp/cause_intr.c to
avoid conflict with rtems/src/intr.c (Classic API Interrupt Manager).
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
configuration and unix/posix:
c/src/lib/libc/Makefile.in
only (was completely broken).
Linux-posix.cfg.
of other bsp's/CPU.
cd <srcdir>
and
cd c/src/lib; autoconf
or
CHANGES:
c/Makefile.am removed
still in - remove it?)
(Cygwin support)
REMARK:
inside the build-tree.
APPLYING THE PATCH
autogen
dependencies of "Makefile".
--enable-maintainer-mode.
ncurses, and zlib for RTEMS.
> When I run my script that just repeatedly builds different targets, some
> of them die with an error like this:
> Making all RTEMS_BSP=gen68360 in cpugmake[5]: Entering directory
> `/usr1/rtems/build/build-m68k-rtems/c/src/exec/score/cpu'
> Making all RTEMS_BSP=gen68360 in @RTEMS_CPU@
> /bin/sh: @RTEMS_CPU@: No such file or directory
> gmake[5]: *** [all] Error 1
> gmake[5]: Leaving directory
> It is not always the same variable substitution that fails. Sometimes it
> is @INSTALL@. But reliably, it is a variable substitution that is
> failing.
> Do you have any idea why this happens?
Yep, I think I know what's going on.
AC_SUBST(RTEMS_CPU) is missing in configure.ins, thus @RTEMS_CPU@ in
target.cfg.in doesn't get substituted correctly, causing the bug above. Due
to the redundancy of RTEMS_CPU, other most BSPs don't seem to be affected.
Other similar problems probably exist for the unix/posix bsp and the hppa.1
cpu, because their */tools/*Makefile.ams require RTEMS_CPU, too.
Fixes/Changes:
--target=no_cpu*rtems.
before adding :-)
toplevel/configure.in
files changed to RTEMS_CPU
future.
cd <rtems-source-tree>
preparations for automake.
* aclocal/rtems-top.m4:
all bsp_specs.
on BSPs that install there own tools.
With my most recent automake patch (automake II) we could even simplify more
files below make/, because the host-compiler related parts of those files
aren't used anymore :-.
Whatsoever, the patch below should fix this problem.
Note: This is a mere bug fix, it doesn't move any of the variables involved
to target.cfg nor does it try to eliminate any variable.
description follows:
Description:
config.h.ins)
acpolish
configure scripts
Remarks:
[$(prefix)].
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
and automake.
reorg-bsp_specs.sh script.
significantly.
