path: root/c/src/lib/libbsp/unix/posix (unfollow)
2009-10-14Remove (Abandoned).Ralf Corsepius37-2413/+0
2009-09-152009-09-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-2/+5
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
2009-07-162009-07-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-1/+8
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs have the same options.
2009-07-032009-07-03 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill3-45/+6
* Makefile.am: Switch to shared routine. * startup/setvec.c: Removed.
2009-05-082009-05-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-4/+10
* startup/bspgetworkarea.c: Switch from ssize_t to uintptr_t for bsp_get_work_area() since the work area is larger than a single allocatable object.
2009-04-282009-04-28 Chris Johns <chrisj@rtems.org>Chris Johns2-1/+5
* startup/main.c: Update for boot_card command line change.
2008-12-012008-12-01 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill3-1/+6
* bsp_specs, startup/bspgetworkarea.c: Links hello again.
2008-10-022008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-4/+10
* startup/bspgetworkarea.c: Change size_t to ssize_t on bsp_get_work_area(). On 16-bit architectures, size_t can be 16-bits which would limit the work area to 64K.
2008-09-302008-09-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-2/+4
* Makefile.am: Eliminate bsp.am. Cleanup.
2008-09-292008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-29/+17
* Makefile.am: Eliminate *_SOURCES.
2008-09-292008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-1/+4
* Makefile.am: Remove noinst_PROGRAMS (Unused).
2008-09-262008-09-26 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius3-0/+16
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
2008-09-232008-09-23 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-1/+7
* configure.ac: Make letting boot_card() handle work area allocation mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to BSP_BOOTCARD_OPTIONS.
2008-09-182008-09-18 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-14/+6
* include/bsp.h: Remove prototypes of routines in bootcard.h.
2008-09-182008-09-18 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill6-77/+69
* Makefile.am, configure.ac, startup/bspstart.c: Add bsp_get_work_area() implementation and use more of the BSP Initialization Framework. * startup/bspgetworkarea.c, startup/bsppost.c: New files.
2008-09-182008-09-18 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-12/+4
* include/bsp.h: Remove unnecessary boilerplate comments.
2008-09-162008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-1/+5
* clock/clock.c: Remove unnecessary includes of rtems/libcsupport.h and rtems/libio.h.
2008-09-102008-09-10 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-1/+6
* include/bsp.h: Review of all bsp_cleanup() implementations. In this phase, all prototypes were removed from bsp.h and empty implementations were removed and made to use the shared stub.
2008-09-052008-09-05 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2-32/+7
* clock/clock.c: The Shared Memory Driver no longer requires the special IOCTL in Clock_control. This was a hack which has existed since before the Classic API Timer Manager was implemented. All implementations of and references to Clock_control were removed.
2008-09-05Convert to "bool".Ralf Corsepius1-3/+3
2008-09-052008-09-05 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius1-0/+4
* timer/timer.c: Convert to "bool".
2008-08-312008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-11/+11
* timer/timer.c: Eliminate empty function from every benchmark timer driver. Fix spelling.
2008-08-312008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-7/+12
* timer/timer.c: Rename timer driver methods to follow RTEMS programming conventions.
2008-07-14Cleanup.Ralf Corsepius2-12/+0
2008-05-152008-05-15 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2-11/+14
* startup/bspstart.c: Add capability for bootcard.c BSP Initialization Framework to ask the BSP where it has memory for the RTEMS Workspace and C Program Heap. These collectively are referred to as work area. If the BSP supports this, then it does not have to include code to split the available memory between the two areas. This reduces the amount of code in the BSP specific bspstart.c file. Additionally, the shared framework can initialize the C Library, call rtems_debug_enable(), and dirty the work area memory. Until most/all BSPs support this new capability, if the BSP supports this, it should call RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac. When the transition is complete, this autoconf macro can be removed.
2008-05-142008-05-14 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2-29/+12
* Makefile.am: Rework to avoid .rel files.
2008-05-122008-05-12 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2-1/+12
* startup/bspstart.c: Refactored and renamed initialization routines to rtems_initialize_data_structures, rtems_initialize_before_drivers, rtems_initialize_device_drivers, and rtems_initialize_start_multitasking. This opened the sequence up so that bootcard() could provide a more robust and flexible framework which is easier to explain and understand. This also lays the groundwork for sharing the division of available memory between the RTEMS workspace and heap and the C library initialization across all BSPs.
2008-03-112008-03-11 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-1/+5
* runtest.in: Skip all fatal error tests.
2007-12-122007-12-12 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill4-20/+47
* Makefile.am, startup/bspstart.c: Links and runs again. * console/console-io.c: New file.
2007-12-112007-12-11 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill5-63/+29
* clock/clock.c, include/bsp.h, startup/bspstart.c, startup/rtems-ctor.cc: Eliminate copies of the Configuration Table. Use the RTEMS provided accessor macros to obtain configuration fields.
2007-12-042007-12-04 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill3-22/+7
* include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field from CPU Table to Configuration Table. Eliminate CPU Table from all ports. Delete references to CPU Table in all forms.
2007-12-032007-12-03 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2-22/+9
* startup/bspstart.c: Moved most of the remaining CPU Table fields to the Configuration Table. This included pretasking_hook, predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace, extra_mpci_receive_server_stack, stack_allocate_hook, and stack_free_hook. As a side-effect of this effort some multiprocessing code was made conditional and some style clean up occurred.
2007-09-042007-09-04 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2-1/+6
* runtest.in: Add capture to list of interative tests to skip in batch mode.
2007-08-072007-08-07 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2-15/+5
* preinstall.am: Save changes again to make tagger happy.
2007-08-012007-07-31 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill3-11/+17
* Makefile.am, preinstall.am: You need main() to link all applications. There is no C++ specific way to link currently.
2007-07-242007-07-24 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill3-41/+25
* Makefile.am, startup/main.c: Now can link with C compiler and not require C++ compiler to link. The file rtems-ctor.cc is not being built but if there is a need for C++ code to run on this BSP, then it will have to be addressed. The simplest solution which might work is to check the RTEMS system state before calling bsp_start() in main().
2007-05-072007-05-07 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-2/+3
* startup/bspstart.c: Use uintptr_t for address arithmetics.
2007-05-072007-05-07 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-2/+5
* bsp_specs: Remove -qrtems_debug.
2007-04-172007-04-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* posix/tools/runtest.in: Do not run pppd.exe from batch mode script.
2007-01-262007-01-26 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-1/+5
* Makefile.am: Use MKDIR_P instead of mkdir_p.
2007-01-08Regenerate.Ralf Corsepius1-2/+2
2006-12-022006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius4-2/+10
2006-10-302006-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-2/+10
* startup/rtems-ctor.cc: Conditionally disable non-GCC code.
2006-10-172006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-2/+6
2006-03-17Remove eof include fileRalf Corsepius1-1/+0
2006-01-14Regenerate.Ralf Corsepius1-1/+1
2006-01-12Regenerate.Ralf Corsepius1-0/+4
2006-01-12Remove all-local:.Ralf Corsepius1-2/+0
2006-01-12Regenerate.Ralf Corsepius1-1/+1
