* startup/Makefile.am: Add custom compilation rule for
rtems-ctor$(LIB_VARIANT).$(OBJEXT).
* Makefile.am: Misc cleanups and fixes.
* shmsupp/Makefile.am: Cosmetics.
* shmsupp/Makefile.am: Remove all-local: $(ARCH).
* configure.ac: Use AC_PATH_PROG(PERL,perl) instead of
RTEMS_PATH_PERL.
Reflect changes to bsp.am.
* timer/timer.c: Obsoleting HP PA-RISC port and removing all
references.
* clock/clock.c, console/console.c, include/bsp.h, shmsupp/addrconv.c,
shmsupp/cause_intr.c, shmsupp/getcfg.c, shmsupp/lock.c,
shmsupp/mpisr.c, startup/bspclean.c, startup/bspstart.c,
startup/exit.c, startup/setvec.c, timer/timer.c: URL for license
changed.
shmsupp/Makefile.am: Reflect having moved automake.
* runtest.in: Add fileio to list of interactive tests.
* configure.ac: Add BSPOPTS (WORKSPACE_MB, HEAPSPACE_MB).
* shmsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS. Cosmetical
changes.
* configure.ac: Unconditionally check for CXX (Hack to bug in
autoconf > 2.54).
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
* startup/Makefile.am: Do NOT use the standard bootcard.c.
NOTE: With this fix all test including the mptest ran as expected.
* configure.in: Remove.
* include/Makefile.am: Include coverhd.h so tmtests will compile.
* include/.cvsignore: Add bspopts.h*, stamp-h*, coverhd.h.
* bsp_specs: Add qnolinkcmds.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include
compile.am
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
that contains:
* Removes MKLIB
handling)
converted to automake.
