* clock/clock.c, console/console.c, include/bsp.h, shmsupp/addrconv.c,
shmsupp/cause_intr.c, shmsupp/getcfg.c, shmsupp/lock.c,
shmsupp/mpisr.c, startup/bspclean.c, startup/bspstart.c,
startup/exit.c, startup/setvec.c, timer/timer.c: URL for license
changed.
shmsupp/Makefile.am: Reflect having moved automake.
* configure.ac: Add BSPOPTS (WORKSPACE_MB, HEAPSPACE_MB).
* shmsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include
compile.am
converted to automake.
that converts the unix directory to automake.
Ralf's note: Please check c/src/lib/libbsp/unix/posix/startup/Makefile.am.
I am not sure if it is correct.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
be resolved.
+ variable length messages
+ named devices
+ debug monitor
