* configure.in: Remove.
* include/Makefile.am: Include coverhd.h so tmtests will compile.
* include/.cvsignore: Add bspopts.h*, stamp-h*, coverhd.h.
* bsp_specs: Add qnolinkcmds.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include
compile.am
