* console/debugputs.c, shmsupp/getcfg.c, shmsupp/lock.c,
timer/timer.c: Use uint32_t instead of rtems_unsigned32/unsigned32.
* console/console.c, timer/timer.c: Use uint32_t instead of
* timer/timer.c: Update timer overhead for start/stop.
* runtest.in: Change toolname to match 4.8.
* shared/bspstart.c, shared/start.S: Use common clock driver template
and eliminate all fast idle code specific to this BSP. This
eliminates a fair amount of code in the BSP clock driver and
bsp_startup. The LEON3 has to do a scan of the AMBA bus to find the
timer so I added the new hook Clock_driver_support_find_timer to
support this. In general, there was some clean up to the file headers
of various files.
* clock/ckinit.c, startup/bspstart.c: Use common clock driver template
of various files.
* clock/ckinit.c: Use common clock driver template and eliminate all
fast idle code specific to this BSP. This eliminates a fair amount of
code in the BSP clock driver and bsp_startup. The LEON3 has to do a
scan of the AMBA bus to find the timer so I added the new hook
Clock_driver_support_find_timer to support this. In general, there
was some clean up to the file headers of various files.
* clock/ckinit.c, console/console.c: Use common clock driver template
of various files.
* Makefile.am: Merge c_rtems_main() into boot_card(). This eliminated a
file and simplified initialization.
* Makefile.am: Remove superfluous -DASM.
* preinstall.am: Install spacewire.h
* clock/ckinit.c, include/leon.h, timer/timer.c, amba/amba.c
fixed up merge from 4.6.6. Correct references to
LEON3_IrqCtrl_Regs_Map.mask[x] and LEON3_Timer_Regs_Map.timer[x].
* amba/amba.c, clock/ckinit.c, include/amba.h, timer/timer.c: Search
for the Timer Register when initializing the amba rather than before
each potential use.
* Makefile.am, include/leon.h: Try to merge rest of 4.6 BSP changes.
* include/spacewire.h: New file.
* Makefile.am: Merge SHM support from 4.6 branch.
* shmsupp/README, shmsupp/addrconv.c, shmsupp/getcfg.c, shmsupp/lock.c,
shmsupp/mpisr.c: New files.
* clock/ckinit.c: Actually call the routine to find the LEON3 time.
* leon_greth/.cvsignore, leon_greth/leon_greth.c: New files.
Missed adding in previous commit of merge.
* clock/ckinit.c, timer/timer.c: Make sure LEON3_Timer_Regs is
initialized for the timer driver.
* ChangeLog, Makefile.am, clock/ckinit.c, include/amba.h,
include/bsp.h: Merge SPARC updates from 4.6 branch. Original
modifications by Gaisler Enterprises.
* startup/linkcmds: Add .rela.dyn sections.
PR 1100/bsps
* console/debugputs.c: Remove redundant return.
* include/leon.h: Add LEON_INTERRUPT_EXTERNAL_1 define.
* startup/linkcmds: Add .gnu.linkonce.b.* section.
* startup/linkcmds: Add sections required by newer gcc versions.
* configure.ac: Remove explicit ampolish3 support (now in
RTEMS_BSP_CONFIGURE).
* configure.ac: Add ampolish3 support.
* Makefile.am: Add preinstall.am.
* shared/start.S: Add include of bspopts.h so SIS quirks will trigger.
* startup/linkcmds: Merge from 4.6 branch. Now the copy_data loop
works.
* configure.ac: Add configuration for ENABLE_SIS_QUIRKS.
* shared/start.S: Backport from rtems-4-6-branch.
* leon_smc91111/leon_smc91111.c, README, timer/timer.c,
startup/ithread.S, startup/setvec.c, startup/spurious.c,
startup/linkcmds, startup/bspstart.c, console/console.c,
console/debugputs.c, console/consolereserveresources.c,
bsp_specs, amba/amba.c, gnatsupp/gnatsupp.c, include/coverhd.h,
include/tm27.h, include/leon.h, include/bsp.h, include/amba.h,
Makefile.am, configure.ac, times, leon_open_eth/leon_open_eth.c
clock/ckinit.c: Backport from rtems-4-6-branch.
startup/setvec.c, startup/spurious.c, startup/linkcmds,
console/console.c, console/debugputs.c,
console/consolereserveresources.c, bsp_specs, gnatsupp/gnatsupp.c,
include/coverhd.h, include/tm27.h, include/leon.h, include/bsp.h,
Makefile.am, configure.ac, times, leon_open_eth/leon_open_eth.c,
