* configure.ac: Add RTEMS_BSPOPTS*(CONSOLE_USE_INTERRUPTS).
Add RTEMS_BSPOPTS*(SIMSPARC_FAST_IDLE).
Remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* include/bsp.h: include bspopts.h.
This fix is in response to test results reported by Jerry Needell
<jerry.needell@unh.edu> for the SPARC/ERC32 and tracked as PR80.
* include/bsp.h: TM27 was not running properly because the ERC32
and LEON cannot nest interrupts at the same level. The BSP test support
had to be modified to support using two different interrupt sources.
* clock/ckinit.c, console/console.c, include/bsp.h, include/leon.h,
startup/setvec.c, timer/timer.c: Fixed typo.
* configure.in: Remove.
* acinclude.m4: New file.
* ChangeLog: New file.
* tools/runtest.in: Recognize debug variant of monitor test.
* start.S: Modificatins to preserve the current CWP and adjust the
WIM accordingly. This improves compatibility with the remote
debugger and the mkprom prom-builder.
* console/debugputs.c: Switched to unsigned characters.
* console/console.c: Removed console_reserve_resources().
* gnatsupp/gnatsupp.c: Added prototype to eliminate warning.
* erc32sonic/Makefile.am: Only compile this if networking is enabled.
* erc32sonic/erc32sonic.c: Minor modifications which enable
network interface to come up and work for some time before
getting an error in the SONIC driver. The error is a bit random,
sometimes MCLGET (m, M_WAIT) tries to access memory way outside the
available ram (and traps) while sometimes there is a panic due
to RBAE/RXEN.
* Makefile.am: Cleanup.
* include/Makefile.am: Cleanup.
* wrapup/Makefile.am: Pick up cache code from libcpu and pick
up .o's instead of .rel's from libcpu.
* startup/boardinit.S: St 32-bit ram width by default.
* ChangeLog, .cvsignore, Makefile.am, bspclean.c, bspstart.c,
gnatcommon.c, start.S: New files. Largely moved from ERC32
BSP to be able to be shared with LEON and other SPARC BSPs.
* Makefile.am, configure.in: Added shared directory as part
of enhancing ERC32 and adding LEON.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs,
configure.in, times, clock/.cvsignore, clock/Makefile.am,
clock/ckinit.c, console/.cvsignore, console/Makefile.am,
console/console.c, console/consolereserveresources.c,
console/debugputs.c, gnatsupp/.cvsignore,
gnatsupp/Makefile.am, gnatsupp/gnatsupp.c,
include/coverhd.h, include/leon.h, start/.cvsignore,
start/Makefile.am, startup/.cvsignore, startup/Makefile.am,
startup/boardinit.S, startup/linkcmds, startup/setvec.c,
startup/spurious.c, timer/.cvsignore, timer/Makefile.am,
timer/timer.c, tools/.cvsignore, tools/Makefile.am,
tools/configure.in, tools/runtest.in, wrapup/.cvsignore,
wrapup/Makefile.am: New file.
* Makefile.am, configure.in, gnatsupp/Makefile.am,
gnatsupp/gnatsupp.c, include/Makefile.am, include/bsp.h,
start/Makefile.am, startup/Makefile.am, startup/setvec.c,
wrapup/Makefile.am:
* erc32sonic: New directory.
* erc32sonic/Makefile.am, erc32sonic/erc32sonic.c,
erc32sonic/.cvsignore: New files.
* include/erc32.h: New file.
* startup/boardinit.S: New file.
Big update of SPARC support for ERC32 and LEON.
Added support for ERC32 without floating point.
Added SONIC support as configured on Tharsys ERC32 board.
The bsp's share various code in the shared directory:
gnat-support, start-up code, etc.
To decrease the foot-print, I removed the 16 kbyte start-up
stack that was put in .bss and never reused once the system
was up. The stack is now put between the heap and the
workspace. To reclaim it, the user can do a rtems_region_extend
to merge the stack to the heap region once the system is up.
* configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros.
* clock/Makefile.am, console/Makefile.am, gnatsupp/Makefile.am,
are now in libcpu. This primarily required moving erc32 specific
information from score/cpu files to libcpu/sparc and the erc32 BSP.
that contains:
* Removes MKLIB
handling)
converted to automake.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
that converts the sparc directory to automake.
Ralf's note: The implementation of libbsp/sparc/* gives a nearly minimal
example of the new configuration scheme.
Addtional major bugs:
