See errata of respective chip. Some code-cleanup as well.
Moved prototype for __gnat_install_handler and __gnat_install_handler_common to common header file. Placed header file in bsp namespace.
The PCI and RASTA versions of the uart, spacewire and 1553 drivers directly includes the c-file of the standard versions
of the drivers, but uses a macro to change the name of the driver register function. When the standard version is
used this function should be global, when it is included as part of the PCI and RASTA versions it should be local and
static.
Also signal to compiler that the start variable in lan91cxx_recv is only used when debugging.
Add a local context structure to the SMP lock API for acquire and
release pairs. This context can be used to store the ISR level and
profiling information. It may be later used to enable more
sophisticated lock algorithms, e.g. MCS locks.
There is only one lock that cannot be used with a local context. This
is the per-CPU lock since here we would have to transfer the local
context through a context switch which is very complicated.
Use the interrupt controller timestamping counter for the CPU counter if
available since it runs with a high frequency.
The previous implementation used an instruction cache line size of 0,
this is a bogus value. Use a instruction cache line size of 64 since
the L2 cache may have a line size of 32 or 64. A greater value should
cause no harm.
Use a FLUSH operation for _CPU_cache_invalidate_instruction_range().
This is a preperation step to support the L2 cache.
The SPARC processors supported by RTEMS have no built-in CPU counter
support. We have to use some hardware counter module for this purpose.
The BSP must provide a 32-bit register which contains the current CPU
counter value and a function for the difference calculation. It can use
for example the GPTIMER instance used for the clock driver.
Disabling of interrupts is not enough to ensure mutual exclusion on SMP
configurations.
Rename rtems_smp_process_interrupt() into
_SMP_Inter_processor_interrupt_handler(). Delete unused header file
<rtems/bspsmp.h>.
Rename rtems_smp_secondary_cpu_initialize() into
_SMP_Start_multitasking_on_secondary_processor(). Move declaration to
<rtems/score/smpimpl.h>.
Since the per-CPU SMP lock must be acquired and released to send the
message a single interrupt broadcast operations offers no benefits. If
synchronization is required, then a SMP barrier must be used anyway.
Rename bsp_smp_initialize() into _CPU_SMP_Initialize() since every CPU
port must supply this function.
Merge RTEMS_FATAL_SOURCE_BSP_GENERIC and RTEMS_FATAL_SOURCE_BSP_SPECIFIC
into new fatal source RTEMS_FATAL_SOURCE_BSP. This makes it easier to
figure out the code position given a fatal source and code.
Move vital code out of debug section. Harmonize variable names with
other implementations.
Add _LEON3_Get_current_processor().
The _CPU_Context_switch() is a normal function call. The following
registers are volatile (the caller must assume that the register
contents are destroyed by the callee) according to "SYSTEM V APPLICATION
BINARY INTERFACE - SPARC Processor Supplement", Third Edition: g1, o0,
o1, o2, o3, o4, o5. Drop these registers from the context.
Ensure that offset defines match the structure offsets.
The expression "*pi++" post-increments the pointer (not the value).
This reverts commit 7579e255127ee0cf04901bbab6c1538559053508.
Improve QEMU to support AMBA plug and play instead.
Do not return a status.
Delete _CPU_Context_switch_to_first_task_smp() and use
_CPU_Context_restore() instead.
Avoid usage of the same stack area by multiple secondary processors at
the same time.
Avoid magic delay loops.
Install inter-processor interrupt (IPI) handler before secondary CPUs
are started. This ensures that secondary CPUs fetch the newly installed
handler.
Remove superfluous return statement.
