path: root/c/src/lib/libbsp/sparc (follow)
* 2001-11-08 Jiri Gaisler <jiri@gaisler.com>Joel Sherrill2001-11-084-14/+32
| | | | | | | | This fix is in response to test results reported by Jerry Needell <jerry.needell@unh.edu> for the SPARC/ERC32 and tracked as PR80. * include/bsp.h: TM27 was not running properly because the ERC32 and LEON cannot nest interrupts at the same level. The BSP test support had to be modified to support using two different interrupt sources.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-127-6/+5
| | | | | * clock/ckinit.c, console/console.c, include/bsp.h, include/leon.h, startup/setvec.c, timer/timer.c: Fixed typo.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-125-0/+166
| | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove.
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-125-159/+0
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1110-0/+35
* 2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-101-0/+5
| | | | | * acinclude.m4: New file. * configure.in: Use RTEMS_BSP_SUBDIR.
* 2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-102-2/+14
* 2001-09-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-284-2/+10
| | | | * include/bsp.h: Renamed delay() to rtems_bsp_delay().
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-278-4/+20
| | | | * include/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-141-0/+4
| | | | * ChangeLog: New file.
* 2001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-162-1/+5
| | | | * tools/runtest.in: Recognize debug variant of monitor test.
* 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-185-4/+16
| | | | | | | * configure.in: Add bspopts.h. * include/.cvsignore: Add bspopts.h*, stamp-h*. * include/Makefile.am: Use *_HEADERS instead of *H_FILES. * include/bsp.h: Include bspopts.h.
* 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-185-4/+23
* 2001-05-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-114-2/+10
| | | | * configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]).
* 2000-04-23 Jiri Gaisler <jiri@gaisler.com>Joel Sherrill2001-04-242-5/+15
| | | | | | * start.S: Modificatins to preserve the current CWP and adjust the WIM accordingly. This improves compatibility with the remote debugger and the mkprom prom-builder.
* 2000-04-23 Jiri Gaisler <jiri@gaisler.com>Joel Sherrill2001-04-234-6/+14
| | | | * console/debugputs.c: Switched to unsigned characters.
* 2000-12-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-062-7/+4
| | | | * console/console.c: Removed console_reserve_resources().
* 2000-12-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-062-0/+7
| | | | * gnatsupp/gnatsupp.c: Added prototype to eliminate warning.
* 2000-11-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-301-0/+2
| | | | * erc32sonic/Makefile.am: Only compile this if networking is enabled.
* 2000-11-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-301-0/+4
* 2000-11-21 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-212-4/+12
| | | | | | | | | * erc32sonic/erc32sonic.c: Minor modifications which enable network interface to come up and work for some time before getting an error in the SONIC driver. The error is a bit random, sometimes MCLGET (m, M_WAIT) tries to access memory way outside the available ram (and traps) while sometimes there is a panic due to RBAE/RXEN.
* 2000-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-154-7/+10
| | | | * Makefile.am: Cleanup.
* 2000-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-152-1/+4
| | | | * include/Makefile.am: Cleanup.
* 2000-11-14 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-154-4/+14
| | | | | * wrapup/Makefile.am: Pick up cache code from libcpu and pick up .o's instead of .rel's from libcpu.
* 2000-11-14 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-152-0/+5
| | | | * startup/boardinit.S: St 32-bit ram width by default.
* 2000-11-13 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-132-0/+7
| | | | | | * ChangeLog, .cvsignore, Makefile.am, bspclean.c, bspstart.c, gnatcommon.c, start.S: New files. Largely moved from ERC32 BSP to be able to be shared with LEON and other SPARC BSPs.
* 2000-11-13 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-133-3/+9
| | | | | * Makefile.am, configure.in: Added shared directory as part of enhancing ERC32 and adding LEON.
* 2000-11-13 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-1340-0/+3121
| | | | | | | | | | | | | | | | | * .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.in, times, clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, console/.cvsignore, console/Makefile.am, console/console.c, console/consolereserveresources.c, console/debugputs.c, gnatsupp/.cvsignore, gnatsupp/Makefile.am, gnatsupp/gnatsupp.c, include/.cvsignore, include/Makefile.am, include/bsp.h, include/coverhd.h, include/leon.h, start/.cvsignore, start/Makefile.am, startup/.cvsignore, startup/Makefile.am, startup/boardinit.S, startup/linkcmds, startup/setvec.c, startup/spurious.c, timer/.cvsignore, timer/Makefile.am, timer/timer.c, tools/.cvsignore, tools/Makefile.am, tools/configure.in, tools/runtest.in, wrapup/.cvsignore, wrapup/Makefile.am: New file.
* 2000-11-13 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-135-0/+685
* 2000-11-13 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-1319-770/+816
| | | | | | | | | | | | | | | | | | | | | | * Makefile.am, configure.in, gnatsupp/Makefile.am, gnatsupp/gnatsupp.c, include/Makefile.am, include/bsp.h, start/Makefile.am, startup/Makefile.am, startup/setvec.c, wrapup/Makefile.am: * erc32sonic: New directory. * erc32sonic/Makefile.am, erc32sonic/erc32sonic.c, erc32sonic/.cvsignore: New files. * include/erc32.h: New file. * startup/boardinit.S: New file. Big update of SPARC support for ERC32 and LEON. Added support for ERC32 without floating point. Added SONIC support as configured on Tharsys ERC32 board. The bsp's share various code in the shared directory: gnat-support, start-up code, etc. To decrease the foot-print, I removed the 16 kbyte start-up stack that was put in .bss and never reused once the system was up. The stack is now put between the heap and the workspace. To reclaim it, the user can do a rtems_region_extend to merge the stack to the heap region once the system is up.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-096-3/+15
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-026-3/+15
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-012-4/+10
| | | | | | | * startup/bspstart.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. Header file order was cleaned up while doing this.
* 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-272-1/+6
* 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-273-2/+9
| | | | | * configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-058-0/+13
| | | | | | * clock/Makefile.am, console/Makefile.am, gnatsupp/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include compile.am
* Adding ChangeLogs.Joel Sherrill2000-08-103-0/+9
* Reworked score/cpu/sparc so it can be safely compiled multilib. AllJoel Sherrill2000-07-113-4/+40
| | | | | | routines and structures that require CPU model specific information are now in libcpu. This primarily required moving erc32 specific information from score/cpu files to libcpu/sparc and the erc32 BSP.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-1217-53/+53
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-1311-0/+56
| | | | adds .cvsignore.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-083-6/+8
* Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff fromJoel Sherrill2000-01-319-104/+91
| | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams
* Patch rtems-rc-20000118-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-2/+0
| | | | | | | | | | | | | | that contains: * cleanups to configuration files * A reworked gccnewlib.spec.in: I have reformated it for enhanced readability and added more rtems-base packages. It now should be free of any installation conflicts (If there still remain some, they should be regarded as bugs). * A fix to the bin2boot RTEMS_BSP issue (make RTEMS_BSP="pc386 pc486" now works). * removes libbsp/bare/wrapup * Further cleanups
* Now ignores minimum and does not run it.Joel Sherrill2000-01-141-1/+1
* Removed old hack of using Configuration Table entry ticks_per_timesliceJoel Sherrill2000-01-111-24/+19
| | | | | | | being set to 0 to indicate that there should be no Clock Tick. This was used by the Timing Tests to avoid clock tick overhead perturbing execution times. Now the Timing Tests simply leave the Clock Tick Driver out of the Device Driver Table.
* Patch rtems-rc-20000104-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-1021-530/+300
| | | | | | | that converts the sparc directory to automake. Ralf's note: The implementation of libbsp/sparc/* gives a nearly minimal example of the new configuration scheme.
* Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-291-1/+1
| | | | | | | | | | | | | | | | | | | | | | | which (among other things) converted the mptests to automake. SUB_DIRS was used instead of SUBDIRS in some Makefile.ins (apparently a leftover from moving the start* directories) Addtional major bugs: * psxtests/include was empty (incomplete psxtests changes). * bogus handling of *.scn in itrontests (screens/sptests vs. screens/itrontests installation dirs) In addition I have added a few more changes (I couldn't resist) * automake support for itrontests * OPERATION_COUNT support in tmitrontests/ * automake support for tmitrontests * automake suppport for mptests * Some (minor) corrections to several configure.in/Makefile.ams => c/src/tests/ is completly under automake control, now. => we could start to sort out the structural issues with c/src/tests (tests/support, stubdr, tools, get "make dist" working)
* Patch rtems-rc-19991117-9.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-226-7/+6
| | | | | to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib."
* Use PGM consistently.Joel Sherrill1999-11-221-2/+2
