* | 2006-07-16 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-07-16 | 2 | -0/+8 |
| | | | | * preinstall.am: Install spacewire.h | ||||
* | 2006-07-13 Jerry Needell <jerry.needell@unh.edu> | Joel Sherrill | 2006-07-14 | 5 | -35/+90 |
| | | | | | | * clock/ckinit.c, include/leon.h, timer/timer.c, amba/amba.c fixed up merge from 4.6.6. Correct references to LEON3_IrqCtrl_Regs_Map.mask[x] and LEON3_Timer_Regs_Map.timer[x]. | ||||
* | 2006-07-12 Jerry Needell <jerry.needell@unh.edu> | Joel Sherrill | 2006-07-12 | 5 | -34/+25 |
| | | | | | | * amba/amba.c, clock/ckinit.c, include/amba.h, timer/timer.c: Search for the Timer Register when initializing the amba rather than before each potential use. | ||||
* | 2006-07-12 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-07-12 | 4 | -46/+204 |
| | | | | | * Makefile.am, include/leon.h: Try to merge rest of 4.6 BSP changes. * include/spacewire.h: New file. | ||||
* | 2006-07-12 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-07-12 | 7 | -0/+337 |
| | | | | | | * Makefile.am: Merge SHM support from 4.6 branch. * shmsupp/README, shmsupp/addrconv.c, shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c: New files. | ||||
* | 2006-07-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-07-11 | 2 | -0/+6 |
| | | | | * clock/ckinit.c: Actually call the routine to find the LEON3 time. | ||||
* | 2006-07-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-07-11 | 3 | -0/+78 |
| | | | | | * leon_greth/.cvsignore, leon_greth/leon_greth.c: New files. Missed adding in previous commit of merge. | ||||
* | 2006-07-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-07-11 | 3 | -21/+45 |
| | | | | | * clock/ckinit.c, timer/timer.c: Make sure LEON3_Timer_Regs is initialized for the timer driver. | ||||
* | 2006-07-11 Jerry Needell <jerry.needell@unh.edu> | Joel Sherrill | 2006-07-11 | 5 | -6/+52 |
| | | | | | | * ChangeLog, Makefile.am, clock/ckinit.c, include/amba.h, include/bsp.h: Merge SPARC updates from 4.6 branch. Original modifications by Gaisler Enterprises. | ||||
* | 2006-06-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-06-25 | 6 | -0/+54 |
| | | | | * startup/linkcmds: Add .rela.dyn sections. | ||||
* | 2006-06-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-06-22 | 2 | -1/+5 |
| | | | | | PR 1100/bsps * console/debugputs.c: Remove redundant return. | ||||
* | 2006-04-12 Konrad Eisele <konrad@gaisler.com> | Joel Sherrill | 2006-04-12 | 2 | -0/+6 |
| | | | | * include/leon.h: Add LEON_INTERRUPT_EXTERNAL_1 define. | ||||
* | Remove eof include file | Ralf Corsepius | 2006-03-17 | 7 | -7/+0 |
* | 2006-03-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-03-08 | 6 | -3/+15 |
| | | | | * startup/linkcmds: Add .gnu.linkonce.b.* section. | ||||
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 2 | -2/+6 |
| | | | | * startup/linkcmds: Add sections required by newer gcc versions. | ||||
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 4 | -4/+12 |
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 3 | -3/+3 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 3 | -0/+12 |
* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 3 | -6/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 3 | -3/+3 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 3 | -6/+0 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 6 | -12/+15 |
| | | | | | * configure.ac: Remove explicit ampolish3 support (now in RTEMS_BSP_CONFIGURE). | ||||
* | 2006-01-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-10 | 9 | -151/+33 |
| | | | | | * configure.ac: Add ampolish3 support. * Makefile.am: Add preinstall.am. | ||||
* | 2006-01-10 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-10 | 2 | -0/+5 |
| | | | | * shared/start.S: Add include of bspopts.h so SIS quirks will trigger. | ||||
* | 2006-01-10 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-10 | 2 | -9/+14 |
| | | | | | * startup/linkcmds: Merge from 4.6 branch. Now the copy_data loop works. | ||||
* | New. | Ralf Corsepius | 2006-01-10 | 3 | -0/+178 |
* | 2006-01-10 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-10 | 2 | -0/+11 |
| | | | | * configure.ac: Add configuration for ENABLE_SIS_QUIRKS. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-09 | 1 | -2/+0 |
* | Remove. Sync with rtems-4-6-branch. | Ralf Corsepius | 2006-01-09 | 28 | -3531/+0 |
* | Backport from rtems-4-6-branch | Ralf Corsepius | 2006-01-09 | 1 | -7/+58 |
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 1 | -0/+4 |
| | | | | * shared/start.S: Backport from rtems-4-6-branch. | ||||
* | Cosmetics. | Ralf Corsepius | 2006-01-09 | 1 | -7/+7 |
* | Regenerate. | Ralf Corsepius | 2006-01-09 | 1 | -0/+4 |
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 1 | -0/+10 |
| | | | | | | | | | | | * leon_smc91111/leon_smc91111.c, README, timer/timer.c, startup/ithread.S, startup/setvec.c, startup/spurious.c, startup/linkcmds, startup/bspstart.c, console/console.c, console/debugputs.c, console/consolereserveresources.c, bsp_specs, amba/amba.c, gnatsupp/gnatsupp.c, include/coverhd.h, include/tm27.h, include/leon.h, include/bsp.h, include/amba.h, Makefile.am, configure.ac, times, leon_open_eth/leon_open_eth.c clock/ckinit.c: Backport from rtems-4-6-branch. | ||||
* | Backport from rtems-4-6-branch. | Ralf Corsepius | 2006-01-09 | 26 | -0/+2968 |
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 1 | -0/+9 |
| | | | | | | | | | | * leon_smc91111/leon_smc91111.c, README, timer/timer.c, startup/setvec.c, startup/spurious.c, startup/linkcmds, console/console.c, console/debugputs.c, console/consolereserveresources.c, bsp_specs, gnatsupp/gnatsupp.c, include/coverhd.h, include/tm27.h, include/leon.h, include/bsp.h, Makefile.am, configure.ac, times, leon_open_eth/leon_open_eth.c, clock/ckinit.c: Backport from rtems-4-6-branch. | ||||
* | Backport from rtems-4-6-branch. | Ralf Corsepius | 2006-01-09 | 30 | -0/+3428 |
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 2 | -0/+8 |
| | | | | | * Makefile.am, runtest.in, configure.ac: Backport from rtems-4-6-branch. | ||||
* | 2005-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-16 | 3 | -23/+71 |
| | | | | | | * Makefile.am: Merge-in shared/Makefile.am. * ChangeLog: Merge-in shared/ChangeLog. * configure.ac: Remove shared/Makefile.am. | ||||
* | Remove. | Ralf Corsepius | 2005-10-16 | 3 | -58/+0 |
* | 2005-09-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-09-02 | 2 | -0/+8 |
| | | | | | | PR 821/bsps * start.S: Workaround -- just avoid copying non-existent initialized data in ROM to RAM. | ||||
* | 2005-05-26 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-26 | 4 | -4/+12 |
| | | | | * include/bsp.h: New header guard. | ||||
* | Cosmetics. | Ralf Corsepius | 2005-02-16 | 2 | -4/+6 |
* | 2005-01-20 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-20 | 2 | -1/+5 |
| | | | | * bsp_specs: Conditionalize inclusion of crtend/crtn. | ||||
* | Cosmetics. | Ralf Corsepius | 2005-01-20 | 2 | -4/+2 |
* | 2005-01-20 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-20 | 2 | -2/+4 |
| | | | | * Makefile.am: Fix typo. | ||||
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-07 | 4 | -12/+20 |
| | | | | * Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | 2005-01-06 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-06 | 2 | -2/+4 |
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-03 | 4 | -170/+50 |
| | | | | * Makefile.am: Remove build-variant support. | ||||
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 5 | -5/+5 |
