* acinclude.m4: Regenerate.
* configure.ac: RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY]).
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* Makefile.am: Pickup files from ../../sparc/shared instead of
../shared. Reformat.
* Makefile.am: Cosmetics.
* Makefile.am: Merge-in clock/Makefile.am, erc32sonic/Makefile.am,
startup/Makefile.am, console/Makefile.am, gnatsupp/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am.
Use automake compilation rules.
* clock/Makefile.am, erc32sonic/Makefile.am, startup/Makefile.am,
console/Makefile.am, gnatsupp/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am: Remove.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
* Makefile.am: Merge-in clock/Makefile.am, leon_open_eth/Makefile.am,
* clock/Makefile.am, leon_open_eth/Makefile.am, startup/Makefile.am,
* wrapup/Makefile.am: Reflect changes to libcpu.
* startup/Makefile.am: Ditto.
* Makefile.am: Use @RTEMS_BSP_FAMILY@ instead of
$(RTEMS_BSP_FAMILY).
* gnatsupp/Makefile.am: Eliminate VPATH.
* start/.cvsignore: Remove.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* start/Makefile.am: Eliminate VPATH.
* wrapup/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Reworked.
* Makefile.am: Misc cleanups and fixes.
* Makefile.am: Add dirstamp support to preinstallation.
* erc32sonic/Makefile.am: Cosmetics.
* gnatsupp/Makefile.am: Cosmetics.
* start/Makefile.am: Cosmetics.
* leon_open_eth/Makefile.am: Correct paths to automake/*.am..
PR 538/bsps:
* wrapup/Makefile.am: Add leon_open_eth.rel
* gnatsupp/Makefile.am: Remove all-local: $(ARCH).
* leon_open_eth/Makefile.am: Remove all-local: $(ARCH).
* erc32sonic/Makefile.am: Remove all-local: $(ARCH).
* Makefile.am: Fix stupid typo in previous patch.
* Makefile.am: Fix preinstallation of include/coverhd.h.
* acinclude.m4: Reflect changes to bootstrap.
* configure.ac: Remove RTEMS_CHECK_CUSTON_BSP.
Reflect changes to bsp.am.
* bspstart.c: Obsoleting HP PA-RISC port and removing all references.
* bsp_specs: Remove *lib:.
* bspclean.c, bspstart.c: URL for license changed.
* clock/ckinit.c, console/console.c, console/consolereserveresources.c,
console/debugputs.c, include/bsp.h, include/coverhd.h,
include/leon.h, startup/setvec.c, timer/timer.c: URL for license
changed.
include/erc32.h, startup/erc32mec.c, startup/setvec.c, timer/timer.c:
PR 477/networking
* Makefile.am, configure.ac, console/console.c, include/bsp.h,
startup/setvec.c, wrapup/Makefile.am: Add network support and enable
custom power down.
* leon_open_eth/.cvsignore, leon_open_eth/Makefile.am,
leon_open_eth/leon_open_eth.c: New files.
* Makefile.am: Install to @RTEMS_BSP@/tests.
* include/bsp.h: Correct copyright statements.
