* Makefile.am, configure.ac, startup/bspstart.c: Add capability for
bootcard.c BSP Initialization Framework to ask the BSP where it has
memory for the RTEMS Workspace and C Program Heap. These collectively
are referred to as work area. If the BSP supports this, then it does
not have to include code to split the available memory between the
two areas. This reduces the amount of code in the BSP specific
bspstart.c file. Additionally, the shared framework can initialize
the C Library, call rtems_debug_enable(), and dirty the work area
memory. Until most/all BSPs support this new capability, if the BSP
supports this, it should call
RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac. When
the transition is complete, this autoconf macro can be removed.
* shared/bspstart.c, shared/start.S: Add capability for bootcard.c BSP
Initialization Framework to ask the BSP where it has memory for the
RTEMS Workspace and C Program Heap. These collectively are referred
to as work area. If the BSP supports this, then it does not have to
include code to split the available memory between the two areas.
This reduces the amount of code in the BSP specific bspstart.c file.
Additionally, the shared framework can initialize the C Library, call
rtems_debug_enable(), and dirty the work area memory. Until most/all
BSPs support this new capability, if the BSP supports this, it should
call RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac.
When the transition is complete, this autoconf macro can be removed.
* Makefile.am, configure.ac: Add capability for bootcard.c BSP
* startup/bspstart.c: Refactored and renamed initialization routines to
rtems_initialize_data_structures, rtems_initialize_before_drivers,
rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
* shared/bspstart.c: Refactored and renamed initialization routines to
BSPs.
* clock/ckinit.c: Add nanoseconds clock tick granularity support.
* shared/start.S: Spacing.
* Makefile.am: Remove all references to console_reserve_resources and
termios_reserve_resources.
* console/consolereserveresources.c: Removed.
* ChangeLog, Makefile.am: Remove all references to
console_reserve_resources and termios_reserve_resources.
* configure.ac: Fix typo.
* runtest.in: Skip all fatal error tests.
* startup/linkcmds: Add wildcard to gcc_except_table section so
programs compiled with gcc 4.3.x can link.
* runtest.in: sp39 and sp41 lock on sis but run correctly on
tsim/erc32.
* runtest.in: Update to 4.9.
* console/console.c, timer/timer.c: Fix typos in previous commit
uncovered by MP build.
* clock/ckinit.c, include/bsp.h, startup/bspstart.c: Eliminate copies
of the Configuration Table. Use the RTEMS provided accessor macros to
obtain configuration fields.
* shared/bspstart.c: Eliminate copies of the Configuration Table. Use
the RTEMS provided accessor macros to obtain configuration fields.
* clock/ckinit.c, include/bsp.h: Eliminate copies of the Configuration
Table. Use the RTEMS provided accessor macros to obtain configuration
fields.
* shared/include/grcan_spwrtc.h: Removed.
* shared/include/ambapp.h: Sync head and 4.8 branch.
* include/bsp.h: Move interrupt_stack_size field from CPU Table to
Configuration Table. Eliminate CPU Table from all ports. Delete
references to CPU Table in all forms.
* shared/bspstart.c: Move interrupt_stack_size field from CPU Table to
* amba/amba.c, clock/ckinit.c, console/console.c, include/bsp.h,
startup/bspstart.c, timer/timer.c: Move interrupt_stack_size field
from CPU Table to Configuration Table. Eliminate CPU Table from all
ports. Delete references to CPU Table in all forms.
* shared/bspstart.c: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* amba/amba.c, startup/bspstart.c: Moved most of the remaining CPU
Table fields to the Configuration Table. This included
pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* Makefile.am: Moved most of the remaining CPU Table fields to the
Configuration Table. This included pretasking_hook, predriver_hook,
* shared/include/grspw.h, shared/spw/grspw.c: GRSPW SpaceWire Driver.
Fixes typecast to volatile integer instead of to integer. Added
scanning for GRSPW2 Core, The GRSPW2 core is run in legacy mode.
* shared/can/occan.c: LEON2/3 OCCAN CAN driver. Fixes typecast to
volatile integer where needed. Fixes bug where closing the driver and
opening it again could make the driver not starting transmission due
to the software fifo was not cleared.
* rasta/rasta.c: LEON2 PCI RASTA driver. Changes RASTA PCI interrupt to
5 from 4. This is to avoid conflict with the LAN9C111 network MAC
driver using interrupt 4.
* shared/can/grcan.c, shared/can/grcan_rasta.c,
shared/include/ambapp.h: GRCAN CAN driver. Fixes Interrupt
enabling/disabling in the driver, interrupt may not be restored
correctly. Implements the baud rate calculation routine. Removed
unnecessary printk. Fixed scanning to support GRCAN and GRHCAN
hardware. Added GRCAN device number to ambapp.h.
* shmsupp/getcfg.c: Fix spacing.
* clock/ckinit.c, include/bsp.h: Fix spacing.
* runtest.in: Filter out Memory exception error messages.
* clock/ckinit.c: Formatting.
* Makefile.am, shared/can/occan.c, shared/include/ambapp.h: Add initial
i2c and update OC-CAN support.
* shared/i2c/i2cmst.c, shared/include/i2cmst.h: New files.
* Makefile.am, preinstall.am: Add initial i2c and update OC-CAN
support.
* Makefile.am, preinstall.am: Fixes bug in OC-CAN baud rate calculator.
The BTR1 8-bit value was swapped.
* shared/can/occan.c: Fix warning on Diab compiler.
* shared/can/occan.c: Fix Reenable command and fix typo.
* shared/1553/b1553brm.c, shared/can/grcan.c: Remove include of sched.h
* Makefile.am: Add smc91111.rel to libbsp.a
* shared/spw/grspw.c: Remove include of sched.h. It does not appear to
be needed and is unavailable when POSIX is disabled.
* leon_smc91111/leon_smc91111.c: LEON2 SMC91111 initialization: PIO
Interrupt initialization fix and speed rate defaulted to 100Mbit/s
for boards with 50MHz system clock or greater now all defaults to
100Mbit/s
* shared/can/grcan.c, shared/include/debug_defs.h, shared/spw/grspw.c:
Remove use of DEBUG_printf.
* shared/1553/b1553brm.c, shared/can/grcan.c, shared/can/grcan_rasta.c,
shared/can/occan.c, shared/spw/grspw.c, shared/spw/grspw_pci.c,
shared/uart/apbuart.c: Remove warnings.
* console/console.c, leon_greth/leon_greth.c,
leon_smc91111/leon_smc91111.c: Remove warnings.
* leon_smc91111/leon_smc91111.c, rasta/rasta.c: Remove warnings.
* shared/pci/pcifinddevice.c: New file.
