This variable must be available for each processor in the system.
Move the _CPU_Context_switch(), _CPU_Context_restore() and
_CPU_Context_switch_to_first_task_smp() code since the method to obtain
the processor index is BSP specific.
Interrupt support for SMP and per-CPU thread dispatch disable level.
As a side-effect the PR2082 is fixed with this and later changes.
The commit restores the _ISR_Handler code to the original version in
"cpukit/score/sparc/cpu_asm.S" in commit
6d42b4c60a4ac686489b793d5df2047c735c7c94. A list of reverted changes
follows.
commit c236082873cb4a2fd42af4ca0868106e1dd65422
Author: Sebastian Huber <sebastian.huber@embedded-brains.de>
Date: Tue Jul 30 15:54:53 2013 +0200
smp: Provide cache optimized Per_CPU_Control
Delete _Per_CPU_Information_p.
This commit was completely reverted.
commit e517714b7cd28807aad4c1afd8c97df72dadb4c1
Author: Jennifer Averett <jennifer.averett@oarcorp.com>
Date: Tue Feb 26 12:31:23 2013 -0600
sparc: Remove dead code that was leftover from SMP development.
commit 47a61aa16f81588f8ffb8ea5cfd1ceba3e9a867a
Author: Joel Sherrill <joel.sherrill@OARcorp.com>
Date: Fri Oct 7 14:35:03 2011 +0000
2011-10-07 Daniel Hellstrom <daniel@gaisler.com>
PR 1933/cpukit
* shared/irq_asm.S: From code inspection I have found the following
issues (most SMP), and some improvements in irq_asm.S. I would need a
long test with interrupts to verify the interrupt handler better,
however I can not see that these patches hurt. Please see comment per
hunk below, One should go through the file to indent delay-slots
correctly, I have fixed some in the patch areas. An extra space is
added in front of delay slots to indicate a delay slot.
commit 0bd3f7e5d12fdbfb5bf4aa4a4169c67bfd92c988
Author: Jennifer Averett <Jennifer.Averett@OARcorp.com>
Date: Thu Jul 28 17:33:07 2011 +0000
2011-07-28 Jennifer Averett <Jennifer.Averett@OARcorp.com>
PR 1801
* shared/irq_asm.S: Modifications to synch the sparc with the smp
working tree.
commit 5d69cd33e9a72cf8c1a24fc9eda7f64d61f10fd1
Date: Wed Mar 16 20:05:30 2011 +0000
2011-03-16 Jennifer Averett <jennifer.averett@OARcorp.com>
PR 1729/cpukit
* shared/irq_asm.S: New file.
The parts modifying the original code of _ISR_Handler were reverted.
Only the content move remains.
Add and use _Per_CPU_Get_by_index() and _Per_CPU_Get_index(). Add
_Per_CPU_Send_interrupt(). This avoids direct access of
_Per_CPU_Information.
Delete bsp_smp_interrupt_cpu().
Add and use _SMP_Get_current_processor() and
rtems_smp_get_current_processor().
Change type of current processor index from int to uint32_t to match
_SMP_Processor_count type.
Termios notifies now the driver about an inactive transmit with the
length argument set to zero.
Rename in rtems_smp_get_processor_count(). Always provide
<rtems/score/smp.h> and <rtems/rtems/smp.h>. Add
_SMP_Get_processor_count(). This function will be a compile time
constant defined to be one on uni-processor configurations. This allows
iterations over all processors without overhead on uni-processor
configurations.
Delete bsp_smp_wait_for(). Other parts of the system work without
timeout, e.g. the spinlocks. Using a timeout here does not make the
system more robust.
Delete bsp_smp_cpu_state and replace it with Per_CPU_State. The
Per_CPU_State follows the Score naming conventions. Add
_Per_CPU_Change_state() and _Per_CPU_Wait_for_state() functions to
change and observe states.
Use Per_CPU_State in Per_CPU_Control instead of the anonymous integer.
Add _CPU_Processor_event_broadcast() and _CPU_Processor_event_receive()
functions provided by the CPU port. Use these functions in
_Per_CPU_Change_state() and _Per_CPU_Wait_for_state().
Add prototype for _SMP_Send_message().
Delete RTEMS_BSP_SMP_FIRST_TASK message. The first context switch is
now performed in rtems_smp_secondary_cpu_initialize(). Issuing the
first context switch in the context of the inter-processor interrupt is
not possible on systems with a modern interrupt controller. Such an
interrupt controler usually requires a handshake protocol with interrupt
acknowledge and end of interrupt signals. A direct context switch in an
interrupt handler circumvents the interrupt processing epilogue and may
leave the system in an inconsistent state.
Release lock in rtems_smp_process_interrupt() even if no message was
delivered. This prevents deadlock of the system.
Simplify and format _SMP_Send_message(),
_SMP_Request_other_cores_to_perform_first_context_switch(),
_SMP_Request_other_cores_to_dispatch() and
_SMP_Request_other_cores_to_shutdown().
Do not call bsp_smp_secondary_cpu_initialize() in
rtems_smp_secondary_cpu_initialize(). This allows more flexibilty in
the BSP low-level code. Specify context requirements for a call to
Call _SMP_Handler_initialize() later and move bsp_smp_initialize() into
_SMP_Handler_initialize(). Change bsp_smp_initialize() prototype to
match integer types of calling context.
Delete rtems_configuration_get_smp_maximum_processors(). Delete
rtems_configuration_smp_maximum_processors variable. Add
maximum_processors field to rtems_configuration_table if RTEMS_SMP is
defined. Add rtems_configuration_get_maximum_processors().
Add CPU port type CPU_Exception_frame and function
_CPU_Exception_frame_print().
The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh,
sparc64, and v850 use an empty default implementation of
Add rtems_exception_frame and rtems_exception_frame_print().
Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions. Use rtems_fatal()
with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc,
and sparc for unexpected exceptions.
Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the
BSP_PRINT_EXCEPTION_CONTEXT define used in the default
bsp_fatal_extension().
Add test sptests/spfatal26.
This is declared in <bsp/bootcard.h> and is the usual function to reset
a board.
The bsp_fatal_extension() will call BSP_fatal_return().
The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
Conflicts:
+ libbsp/sparc/shared/include/pci.h was largely a copy of
an older version of the cpukit pci.h. Removed much of the
contents and included <rtems/pci.h>.
+ sparc/*/pci*.c - Move to <rtems/pci.h> required updating
to use uint32_t for dword accesses.
+ Rename PCI_MULTI_FUNCTION to PCI_HEADER_TYPE_MULTI_FUNCTION
+ Define PCI_HEADER_TYPE_MULTI_FUNCTION in cpukit pci.h and remove
PCI_MULTI_FUNCTION definitions in C files.
+ Move PCI_INVALID_VENDORDEVICEID definitions from various C files
to cpukit pci.h
Some register layout definitions for LEON3 reside in ambapp.h which
does not really has anything to do with device registers. The
register structures has been incorrectly named LEON3_*, the cores
are not only used on LEON3 but on LEON4 and perhaps on LEON5 when
that day comes. Some structures has been renamed according to the
GRLIB core name instead, which CPU that actually use it is not
relevant. Drivers has been updated with the new names.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
