* wrapup/Makefile.am: Pick up cache code from libcpu and pick
up .o's instead of .rel's from libcpu.
* startup/boardinit.S: St 32-bit ram width by default.
* ChangeLog, .cvsignore, Makefile.am, bspclean.c, bspstart.c,
gnatcommon.c, start.S: New files. Largely moved from ERC32
BSP to be able to be shared with LEON and other SPARC BSPs.
* Makefile.am, configure.in: Added shared directory as part
of enhancing ERC32 and adding LEON.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs,
configure.in, times, clock/.cvsignore, clock/Makefile.am,
clock/ckinit.c, console/.cvsignore, console/Makefile.am,
console/console.c, console/consolereserveresources.c,
console/debugputs.c, gnatsupp/.cvsignore,
gnatsupp/Makefile.am, gnatsupp/gnatsupp.c,
include/coverhd.h, include/leon.h, start/.cvsignore,
start/Makefile.am, startup/.cvsignore, startup/Makefile.am,
startup/boardinit.S, startup/linkcmds, startup/setvec.c,
startup/spurious.c, timer/.cvsignore, timer/Makefile.am,
timer/timer.c, tools/.cvsignore, tools/Makefile.am,
tools/configure.in, tools/runtest.in, wrapup/.cvsignore,
wrapup/Makefile.am: New file.
* Makefile.am, configure.in, gnatsupp/Makefile.am,
gnatsupp/gnatsupp.c, include/Makefile.am, include/bsp.h,
start/Makefile.am, startup/Makefile.am, startup/setvec.c,
wrapup/Makefile.am:
* erc32sonic: New directory.
* erc32sonic/Makefile.am, erc32sonic/erc32sonic.c,
erc32sonic/.cvsignore: New files.
* include/erc32.h: New file.
* startup/boardinit.S: New file.
Big update of SPARC support for ERC32 and LEON.
Added support for ERC32 without floating point.
Added SONIC support as configured on Tharsys ERC32 board.
The bsp's share various code in the shared directory:
gnat-support, start-up code, etc.
To decrease the foot-print, I removed the 16 kbyte start-up
stack that was put in .bss and never reused once the system
was up. The stack is now put between the heap and the
workspace. To reclaim it, the user can do a rtems_region_extend
to merge the stack to the heap region once the system is up.
* configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros.
* clock/Makefile.am, console/Makefile.am, gnatsupp/Makefile.am,
are now in libcpu. This primarily required moving erc32 specific
information from score/cpu files to libcpu/sparc and the erc32 BSP.
that contains:
* Removes MKLIB
handling)
converted to automake.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
that converts the sparc directory to automake.
Ralf's note: The implementation of libbsp/sparc/* gives a nearly minimal
example of the new configuration scheme.
Addtional major bugs:
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
I just released erc32ccs-2.0.6 which includes some fixes and the
Ada-self optimisation. Remote debugging of Ada programs did not
work due to a conflict between monior and rtems trap handlers.
I have attached a modified gnatsupp.c that makes remote debugging
possible again.
CHANGES:
c/Makefile.am removed
still in - remove it?)
(Cygwin support)
REMARK:
inside the build-tree.
APPLYING THE PATCH
autogen
dependencies of "Makefile".
--enable-maintainer-mode.
+ interrupt masking correction
+ FPU rev.B workaround
+ minor erc32 related fixes
ncurses, and zlib for RTEMS.
to support a.out and ELF.
