* gnatsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
* erc32sonic/Makefile.am: Use .$(OBJEXT) instead of .o.
* Makefile.am: Add transform and bsptools_bindir hacks.
* configure.ac: Add RTEMS_ENV_RTEMSBSP.
* startup/erc32mec.c: New file.
* startup/Makefile.am: Reflect above.
* include/erc32.h: Converted SCORE_EXTERN to extern.
* tools/runtest.in: Lengthened timeout on test runs.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* include/bsp.h: Change SIS to ERC32_BSP.
* configure.ac: Remove BSPOPTS_*(NO_TABLE_MOVE).
Remove BSPOPTS_*(FPU_REVB).
* wrapup/Makefile.am: Remove tbr.
* configure.ac: Add BSPOPTS_*(NO_TABLE_MOVE).
Add BSPOPTS_*(FPU_REVB).
* wrapup/Makefile.am: Add tbr.
* gnatsupp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* erc32sonic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Remove NETWORKING support.
* wrapup/Makefile.am: Remove NETWORKING support.
* configure.ac: Add RTEMS_BSPOPTS*(CONSOLE_USE_INTERRUPTS).
Add RTEMS_BSPOPTS*(SIMSPARC_FAST_IDLE).
Remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* include/bsp.h: include bspopts.h.
This fix is in response to test results reported by Jerry Needell
<jerry.needell@unh.edu> for the SPARC/ERC32 and tracked as PR80.
* include/bsp.h: TM27 was not running properly because the ERC32
and LEON cannot nest interrupts at the same level. The BSP test support
had to be modified to support using two different interrupt sources.
* clock/ckinit.c, console/console.c, include/bsp.h, include/leon.h,
startup/setvec.c, timer/timer.c: Fixed typo.
* configure.in: Remove.
* acinclude.m4: New file.
* ChangeLog: New file.
* tools/runtest.in: Recognize debug variant of monitor test.
* start.S: Modificatins to preserve the current CWP and adjust the
WIM accordingly. This improves compatibility with the remote
debugger and the mkprom prom-builder.
* console/debugputs.c: Switched to unsigned characters.
* console/console.c: Removed console_reserve_resources().
* gnatsupp/gnatsupp.c: Added prototype to eliminate warning.
* erc32sonic/Makefile.am: Only compile this if networking is enabled.
* erc32sonic/erc32sonic.c: Minor modifications which enable
network interface to come up and work for some time before
getting an error in the SONIC driver. The error is a bit random,
sometimes MCLGET (m, M_WAIT) tries to access memory way outside the
available ram (and traps) while sometimes there is a panic due
to RBAE/RXEN.
* Makefile.am: Cleanup.
* include/Makefile.am: Cleanup.
* wrapup/Makefile.am: Pick up cache code from libcpu and pick
up .o's instead of .rel's from libcpu.
* startup/boardinit.S: St 32-bit ram width by default.
* ChangeLog, .cvsignore, Makefile.am, bspclean.c, bspstart.c,
gnatcommon.c, start.S: New files. Largely moved from ERC32
BSP to be able to be shared with LEON and other SPARC BSPs.
* Makefile.am, configure.in: Added shared directory as part
of enhancing ERC32 and adding LEON.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs,
configure.in, times, clock/.cvsignore, clock/Makefile.am,
clock/ckinit.c, console/.cvsignore, console/Makefile.am,
console/console.c, console/consolereserveresources.c,
console/debugputs.c, gnatsupp/.cvsignore,
gnatsupp/Makefile.am, gnatsupp/gnatsupp.c,
include/coverhd.h, include/leon.h, start/.cvsignore,
start/Makefile.am, startup/.cvsignore, startup/Makefile.am,
startup/boardinit.S, startup/linkcmds, startup/setvec.c,
startup/spurious.c, timer/.cvsignore, timer/Makefile.am,
timer/timer.c, tools/.cvsignore, tools/Makefile.am,
tools/configure.in, tools/runtest.in, wrapup/.cvsignore,
wrapup/Makefile.am: New file.
